Logging in WITHOUT the @domain.net (for squirrelmail)
SiC_Goat
Post by SiC_Goat » 2004-10-16 02:09
For an example of what this will look like go to http://mail.neopians.net
Open up squirrelmail's root folder
Open up the src folder
Open up the file login.php with wordpad (dreamweaver if you have it)
Select all and hit DELETE
Copy and Paste the following code into the file and save
<?php
 * login.php -- simple login screen
 * Copyright (c) 1999-2004 The SquirrelMail Project Team
 * Licensed under the GNU GPL. For full terms see the file COPYING.
 * This a simple login screen. Some housekeeping is done to clean
 * cookies and find language.
 * $Id: login.php,v 1.98.2.3 2004/04/19 20:23:29 kink Exp $
/* Path for SquirrelMail required files. */
define('SM_PATH','../');
/* SquirrelMail required files. */
require_once(SM_PATH . 'functions/strings.php');
require_once(SM_PATH . 'config/config.php');
require_once(SM_PATH . 'functions/i18n.php');
require_once(SM_PATH . 'functions/plugin.php');
require_once(SM_PATH . 'functions/constants.php');
require_once(SM_PATH . 'functions/page_header.php');
require_once(SM_PATH . 'functions/html.php');
require_once(SM_PATH . 'functions/global.php');
require_once(SM_PATH . 'functions/forms.php');
 * $squirrelmail_language is set by a cookie when the user selects
 * language and logs out
set_up_language($squirrelmail_language, TRUE, TRUE);
 * Find out the base URI to set cookies.
if (!function_exists('sqm_baseuri')){
    require_once(SM_PATH . 'functions/display_messages.php');
$base_uri = sqm_baseuri();
 * In case the last session was not terminated properly, make sure
 * we get a new one.
sqsession_destroy();
header('Pragma: no-cache');
do_hook('login_cookie');
/* Output the javascript onload function. */
$header = "<script language=\"JavaScript\" type=\"text/javascript\">\n" .
          "<!--\n".
          "  function squirrelmail_loginpage_onload() {\n".
          "    document.forms[0].js_autodetect_results.value = '" . SMPREF_JS_ON . "';\n".
          "    var textElements = 0;\n".
          "    for (i = 0; i < document.forms[0].elements.length; i++) {\n".
          "      if (document.forms[0].elements[i].type == \"text\" || document.forms[0].elements[i].type == \"password\") {\n".
          "        textElements++;\n".
          "        if (textElements == " . (isset($loginname) ? 2 : 1) . ") {\n".
          "          document.forms[0].elements[i].focus();\n".
          "          break;\n".
          "        }\n".
          "      }\n".
          "    }\n".
          "  }\n".
          "// -->\n".
          "</script>\n";
$custom_css = 'none';
displayHtmlHeader( "$org_name - " . _("Login"), $header, FALSE );
echo '<body text="#000000" bgcolor="#FFFFFF" link="#0000CC" vlink="#0000CC" alink="#0000CC" onload="squirrelmail_loginpage_onload();">' .
     "\n" . addForm('redirect.php', 'POST');
$username_form_name = 'login_username';
$password_form_name = 'secretkey';
$domain_form_name = 'login_domain';
do_hook('login_top');
$loginname_value = (sqGetGlobalVar('loginname', $loginname) ? htmlspecialchars($loginname) : '');
/* If they don't have a logo, don't bother.. */
if (isset($org_logo) && $org_logo) {
    /* Display width and height like good little people */
    $width_and_height = '';
    if (isset($org_logo_width) && is_numeric($org_logo_width) &&
     $org_logo_width>0) {
        $width_and_height = " width=\"$org_logo_width\"";
    if (isset($org_logo_height) && is_numeric($org_logo_height) &&
     $org_logo_height>0) {
        $width_and_height .= " height=\"$org_logo_height\"";
echo html_tag( 'table',
    html_tag( 'tr',
        html_tag( 'td',
            '<center>'.
            ( isset($org_logo) && $org_logo
              ? '<img src="' . $org_logo . '" alt="' .
                sprintf(_("%s Logo"), $org_name) .'"' . $width_and_height .
                ' /><br />' . "\n"
            html_tag( 'table',
                html_tag( 'tr',
                    html_tag( 'td',  "\n" .
                        html_tag( 'table',
                            html_tag( 'tr',
                                html_tag( 'td',
                                    _("Name:") ,
                                'right', '', 'width="30%"' ) .
                                html_tag( 'td',
				    addInput($username_form_name, $loginname_value),
                                'left', '', 'width="*"' ) .
								html_tag( 'td',
								_("@") ,
								'center', '', 'width="*"' ) .
								html_tag( 'td',
					addSelect($domain_form_name, $login_domains) ,
								'left', "", 'width="*"' )
								 . "\n" .
                            html_tag( 'tr',
                                html_tag( 'td',
                                    _("Password:") ,
                                html_tag( 'td',
				    addPwField($password_form_name).
				    addHidden('js_autodetect_results', SMPREF_JS_OFF).
				    addHidden('just_logged_in', '1'),
                        'center', '#ffffff', 'border="0" width="100%"' ) ,
                    'left', '#FFFFFF' )
                html_tag( 'tr',
                    html_tag( 'td',
                        '<center>'. addSubmit(_("Login")) .'</center>',
                    'left' )
            '', '#ffffff', 'border="0" width="350"' ) . '</center>',
        'center' )
'', '#ffffff', 'border="0" cellspacing="0" cellpadding="0" width="100%"' );
do_hook('login_form');
echo '</form>' . "\n";
do_hook('login_bottom');
echo "</body>\n".
     "</html>\n";
Close the file
Back to the SRC folder
Open up the file redirect.php
Select all and press DELETE
Copy and paste the following code
<?php
* redirect.php
* Derived from webmail.php by Ralf Kraudelt <kraude@wiwi.uni-rostock.de>
* Prevents users from reposting their form data after a successful logout.
* $Id: redirect.php,v 1.72.2.4 2004/04/16 15:13:51 tokul Exp $
require_once(SM_PATH . 'functions/prefs.php');
require_once(SM_PATH . 'functions/imap.php');
/* Before starting the session, the base URI must be known. Assuming */
/* that this file is in the src/ subdirectory (or something).        */
$location = get_location();
session_set_cookie_params (0, $base_uri);
sqsession_is_active();
sqsession_unregister ('user_is_logged_in');
sqsession_register ($base_uri, 'base_uri');
/* get globals we me need */
sqGetGlobalVar('login_username', $login_username);
sqGetGlobalVar('secretkey', $secretkey);
sqGetGlobalVar('login_domain', $login_domain);
sqGetGlobalVar('js_autodetect_results', $js_autodetect_results);
if(!sqGetGlobalVar('squirrelmail_language', $squirrelmail_language) || $squirrelmail_language == '') {
	$squirrelmail_language = $squirrelmail_default_language;
/* end of get globals */
set_up_language($squirrelmail_language, true);
/* Refresh the language cookie. */
setcookie('squirrelmail_language', $squirrelmail_language, time()+2592000,
          $base_uri);
if (!isset($login_username)) {
    include_once(SM_PATH .  'functions/display_messages.php' );
    logout_error( _("You must be logged in to access this page.") );
    exit;
if (!isset($login_domain)) {
    logout_error( _("You must be select a domain to connect to.") );
    exit;
if (!sqsession_is_registered('user_is_logged_in')) {
    do_hook ('login_before');
    $onetimepad = OneTimePadCreate(strlen($secretkey));
    $key = OneTimePadEncrypt($secretkey, $onetimepad);
    sqsession_register($onetimepad, 'onetimepad');
    /* remove redundant spaces */
    $login_username = trim($login_username);
    /* Verify that username and password are correct. */
    if ($force_username_lowercase) {
        $login_username = strtolower($login_username);
		$login_username .= "@".$login_domain;
    $imapConnection = sqimap_login($login_username, $key, $imapServerAddress, $imapPort, 0);
    $sqimap_capabilities = sqimap_capability($imapConnection);
    sqsession_register($sqimap_capabilities, 'sqimap_capabilities');
    $delimiter = sqimap_get_delimiter ($imapConnection);
    sqimap_logout($imapConnection);
    sqsession_register($delimiter, 'delimiter');
    $username = $login_username;
    sqsession_register ($username, 'username');
    setcookie('key', $key, 0, $base_uri);
    do_hook ('login_verified');
/* Set the login variables. */
$user_is_logged_in = true;
$just_logged_in = true;
/* And register with them with the session. */
sqsession_register ($user_is_logged_in, 'user_is_logged_in');
sqsession_register ($just_logged_in, 'just_logged_in');
/* parse the accepted content-types of the client */
$attachment_common_types = array();
$attachment_common_types_parsed = array();
sqsession_register($attachment_common_types, 'attachment_common_types');
sqsession_register($attachment_common_types_parsed, 'attachment_common_types_parsed');
$debug = false;
if ( sqgetGlobalVar('HTTP_ACCEPT', $http_accept, SQ_SERVER) &&
    !isset($attachment_common_types_parsed[$http_accept]) ) {
    attachment_common_parse($http_accept, $debug);
/* Complete autodetection of Javascript. */
$javascript_setting = getPref
    ($data_dir, $username, 'javascript_setting', SMPREF_JS_AUTODETECT);
$js_autodetect_results = (isset($js_autodetect_results) ?
    $js_autodetect_results : SMPREF_JS_OFF);
/* See if it's set to "Always on" */
$js_pref = SMPREF_JS_ON;
if ($javascript_setting != SMPREF_JS_ON){
    if ($javascript_setting == SMPREF_JS_AUTODETECT) {
        if ($js_autodetect_results == SMPREF_JS_OFF) {
            $js_pref = SMPREF_JS_OFF;
    } else {
/* Update the prefs */
setPref($data_dir, $username, 'javascript_on', $js_pref);
/* Compute the URL to forward the user to. */
$redirect_url = 'webmail.php';
if ( sqgetGlobalVar('session_expired_location', $session_expired_location, SQ_SESSION) ) {
    sqsession_unregister('session_expired_location');
    $compose_new_win = getPref($data_dir, $username, 'compose_new_win', 0);
    if ($compose_new_win) {
        $redirect_url = $session_expired_location;
    } elseif ( strpos($session_expired_location, 'webmail.php') === FALSE ) {
        $redirect_url = 'webmail.php?right_frame='.urldecode($session_expired_location);
    unset($session_expired_location);
/* Write session data and send them off to the appropriate page. */
session_write_close();
header("Location: $redirect_url");
/* --------------------- end main ----------------------- */
function attachment_common_parse($str, $debug) {
    global $attachment_common_types, $attachment_common_types_parsed;
    $attachment_common_types_parsed[$str] = true;
     * Replace ", " with "," and explode on that as Mozilla 1.x seems to
     * use "," to seperate whilst IE, and earlier versions of Mozilla use
     * ", " to seperate
    $str = str_replace( ', ' , ',' , $str );
    $types = explode(',', $str);
    foreach ($types as $val) {
        // Ignore the ";q=1.0" stuff
        if (strpos($val, ';') !== false)
            $val = substr($val, 0, strpos($val, ';'));
        if (! isset($attachment_common_types[$val])) {
            $attachment_common_types[$val] = true;
Close that file
Back to SRC folder
Go back one dir to the root folder
Open up the config folder
Open up the file config.php
Below the line
$domain                 = 'neopians.net';
Add the following
$login_domains			= array();
Where you just added the $login_domains array you will add each domain you wish to be able to log into, each domain should be enclosed in apostrophes ( ' ) and seperated by a comma ( , ) looking like this
$login_domains			= array('domain1.net', 'domain2.com');
If you only add one domain name to the array the domain will apear as text next to the login name field, otherwise it will appear as a dropdown menu with the first domain in the array being the default domain
- Goat[/url]
casualonejp
Works Great! One thing though...
Post by casualonejp » 2005-05-22 09:51
How can you make it to where the domain is hidden instead of showing @domain.com on the outside of the textbox?
cmurphy54
Post by cmurphy54 » 2005-05-22 16:56
There are several plugins for squirrel mail that already accomplish the above goal without requiring that you modify the source so drastically. Look into using either the Virtual Host Login plugin or the Login Alias plugin.
