Yoshy
- New user
Post
by Yoshy » 2004-07-20 04:05
I`m running hmailserver on a win2k pro box. I`m using a package from Foxserv with Apache, PHP and MySQL. I was running version 2.0 of hmailserver but i had a funny problem: If i sent a mail from hwebmail the body dissappeard when the recipient tried to read it with outlook, and that was my only problem. Since a new version were available i thought it would be a good idea to try this, but now i got another funny problem: When i send a mail from outlook the body dissappears when im trying to read it with hwebmail
The problem i had with 2.0 is now gone...
hmailserver is installed on c:\program files\hmailserver
PHPwebmail is located in c:\foxserv\www\PHPwebmail
Whats wrong ?
I`m sorry about my bad english
polarunion
- Normal user
Post
by polarunion » 2004-07-20 07:30
1: download the
latest hmailserver.
2: squirrelmail is better for your use...
download the hmailserver squirrelmail mod and follow the directions.. you'll be a happy camper..
see
http://www.concept4.ca/diy
- Developer
Post
by martin » 2004-07-20 08:22
Woha. Someone is really using 2.0? You should really upgrade to the latest version and use squirrelmail instead as polarunion suggested.
hWebMail isn't supported any more, since it was just stupid to have a own webmail system when there are other great open source webmail already availible...
Yoshy
- New user
Post
by Yoshy » 2004-07-20 15:29
I have allready upgraded to the latest version of hmailserver !
I`ll try squirrelmail
Yoshy
- New user
Post
by Yoshy » 2004-07-20 15:41
WOW, squirrelmail rules !!
Easy setup, no problems whatsoever !
thanks alot
