how to use Hmailserver on the WAN Network
alainbcm
Post by alainbcm » 2023-09-22 09:31
I use hmailserver on my LAN network, I would like to know how to use it on the WAN Network
thanks
Re: how to use Hmailserver on the WAN Network
Post by jimimaseye » 2023-09-22 09:38
Go back up one page on this form and read:
"PLEASE READ THIS BEFORE POSTING"
Start there.
Post by Dravion » 2023-09-22 10:31
alainbcm wrote:
2023-09-22 09:31
thanks
Hi Alain and Welcome to the Forum.
Right now you need to know that hMailServer is not directly designed to be used on WAN Networks like the Internet or a Company Intranet/Extranet. Remote connections (for Administration and API-Script's) can only be made possible by using something like a SSH-Tunnel or a VPN-Software and static routing to your hMailServer Machine. For example you can use something like the Linux Subsystem for Windows or Cygwin to install a SSH-Server Software on your hMailServer Computer
and tunnel the Windows COM/DCOM connections between your hMailServer Server Computer and your Windows Remote Client-Computer to archive something you asked for.
A while ago i made a Guide/Tutorial how to access a hMailServer via a SSH-Tunnel connection, which you can find here:viewtopic.php?f=21&t=33559
Rohan
Post by Rohan » 2023-12-15 10:36
Is it possible to have same solution if I am using dynamic IP.
Post by mattg » 2023-12-17 04:04
