hmailserver.com website IP banning?
Post by palinka » 2023-06-05 20:13
Weird thing happened just now. I could not connect to hmailserver.com - error timeout. OK, maybe the site is down temporarily. Try later, still the same. Then I had to connect to my VPN for work and hmailserver.com worked fine (including user login). Turned off VPN - timeout. Turned it back on - works fine.
I tried from my phone (wifi off) and no problem there either.
Is my IP banned? My user account is certainly NOT banned. Does this site even do IP banning?
Re: hmailserver.com website IP banning?
Post by palinka » 2023-06-05 20:16
Also, I did NSLOOKUP hmailserver.com while I was not connected to VPN and it returned
Non-authoritative answer:
Address: 212.71.251.76
So it doesn't seem to be any issue with DNS either.
Post by RvdH » 2023-06-05 21:37
I think i had these timeouts yesterday or the day before for about a hour or so, not repeated since
Post by palinka » 2023-06-05 22:14
Weird. Seems to be working now.
It was weird because it only didn't work on my router IP. VPN and mobile worked fine.
