hMailServer v5.6.9-B2607 dbVersion 5601 - any other db updates?
megatron4000
Post by megatron4000 » 2023-05-27 19:38
Currently I have
I wanted to update to use the RwT version,
Is there a complete list of DB Changes I should be aware of that the RwT version needs?
According to this thread:
viewtopic.php?p=241608#p241608
There is a DBVersion update for MSSQL that has to be applied and jumps the DB Version to 5606
Is that the only SQL Changes, OR is there a thread dedicated with a list of running changes?
Joe
Re: hMailServer v5.6.9-B2607 dbVersion 5601 - any other db updates?
Post by mattg » 2023-05-29 00:02
RwT Version??
If you mean Ruud's version, detailed in the post that you link to, then that very long thread shows all of the discussion to date, but the newest version is at the end
megatron4000
Post by megatron4000 » 2023-05-29 17:26
Yeah my bad, that was a typo,
I updated the db with the MSSQL script provided and am happy to say that the new build works much better now,
really addresses some critical fixes including for me was the ability to shut down a connection after only a few bad commands because the scum bags are trying to flood with many commands.
