Blocking IP's
jimwatt
Blocking IP's
Post by jimwatt » 2023-05-19 14:00
Is it possible to programatically add IP's to the list of IP's on the autoban list which hmailserver maintains of excessive logins?
Although I drop bad IP's at on the OnEHLO event in VBscript that does not stop them coming and last week I had 8000+ attempts one day basically mailbombing my server.
It seems any response from the server encourages it to continue.
johang
Re: Blocking IP's
Post by johang » 2023-05-19 14:40
jimwatt wrote:
2023-05-19 14:00
take a look at this:
https://hmailserver.com/forum/viewtopic.php?f=9&t=34082
lets cheat darwin out of his legacy, find a cure for cancer...
jimwatt
Re: Blocking IP's
Post by jimwatt » 2023-05-19 21:42
Interesting but not what I want to do.
The attraction of the hMailserver IP blocking is that it auto expires.
Re: Blocking IP's
Post by palinka » 2023-05-19 22:34
jimwatt wrote:
2023-05-19 14:00
Try this.
Private Const hMSPASSWORD = "supersecretpassword"
Function LockFile(strPath)
	Const Append = 8
	Const Unicode = -1
	Dim i
	On Error Resume Next
		For i = 0 To 30
			Err.Clear
			Set LockFile = .OpenTextFile(strPath, Append, True, Unicode)
			If (Not Err.Number = 70) Then Exit For
			Wait(1)
	If (Err.Number = 70) Then
		Err.Clear
	ElseIf (Err.Number <> 0) Then
		Err.Clear
	On Error Goto 0
	Call oApp.Authenticate("Administrator", hMSPASSWORD)
	With LockFile(TEMPDIR & "\autoban.lck")
		Dim oSecurityRange : Set oSecurityRange = oApp.Settings.SecurityRanges.ItemByName("(" & sReason & ") " & sIPAddress)
		If Err.Number = 9 Then
				.LowerIP = sIPAddress
				.UpperIP = sIPAddress
				.Priority = 20
				.Expires = True
				.Save
			AutoBan = True
		On Error Goto 0
		.Close
	Set oApp = Nothing
Sub WhateverYourReasoning(oMessage, oClient, whateverElse)
	' Your criteria for autobanning
	Call AutoBan(oClient.IPAddress, "Your reason for autobanning - " & oClient.IPAddress, 1, "h")
edit - Yes, in the example above I'm only banning for one hour. That's my default autoban expiration.
Re: Blocking IP's
Post by SorenR » 2023-05-20 00:56
We have different approaches to the matter ;-)
SQL statement is compatible with MySQL and MariaDB.
    Dim iUniqueID, strSQL, strDate, SQLDate, oDB : Set oDB = oApp.Database
    strDate = DateAdd(sType, iDuration, Now())
    strSQL = "INSERT INTO hm_securityranges (rangepriorityid, rangelowerip1, rangeupperip1, rangeoptions, rangename, rangeexpires, rangeexpirestime)" & _
             " VALUES (20, INET_ATON('" & sIPAddress & "'), INET_ATON('" & sIPAddress & "'), 0, '(" & sReason & ") " & sIPAddress & "', 1, STR_TO_DATE('" & strDate & "', '%d-%m-%Y %H:%i:%s'))" & _
             " ON DUPLICATE KEY UPDATE rangeexpirestime = STR_TO_DATE('" & strDate & "', '%d-%m-%Y %H:%i:%s');"
    iUniqueID = oDB.ExecuteSQLWithReturn(strSQL)
    If iUniqueID > 0 Then AutoBan = True
    Set oApp = Nothing
    If Result.Value < 1 Then Result.Value = 1
This an example of how I use it... (includes additional undocumented function calls ;-) )
If AutoBan(oClient.IPAddress, "GEO Blocked " & strGeo & " " & strPort, 48, "h") Then EventLog.Write( LPad("GEO Blocked", 15, " ") & vbTab & LPad(oClient.IPAddress, 16, " ") & vbTab & LPad(oClient.Port, 3, " ") & vbTab & strGeo )
To understand recursion, you must first understand recursion.
Re: Blocking IP's
Post by palinka » 2023-05-20 08:09
2023-05-20 00:56
Not really. I just haven't upgraded to autoban 2.0. :mrgreen:
Re: Blocking IP's
Post by SorenR » 2023-05-20 14:39
2023-05-20 08:09
2023-05-20 00:56
If you are using IPV6 (INET6_ATON/INET6_NTOA) you will need to change the SQL statement. As it is now it is IPV4 only.
Re: Blocking IP's
Post by mattg » 2023-05-21 02:05
jimwatt wrote:
2023-05-19 14:00
This is my current method.
This gets called multiple times through my eventhandlers.vbs, and it can also get called stand alone.
I think it works on IPv6 addresses, but I'm not certain.
I have around 1000 banned IP addresses at any one point in time, mostly for a week at a time
Sub AutobanIP(IPAddress, NumberOfDays, ReasonForBan)
	'custom event
	'uses functions:
	EventLog.Write("Autoban IP Address started for IP = " & IPAddress & " For " & NumberofDays & " days for reason " & Reasonforban)
	Dim oApp
' 		Give this script permission to access all
' 		hMailServer settings.
	Dim i
	On Error Resume next
	For i = 0 To oApp.Settings.SecurityRanges.Count -1
		If IPAddress = oApp.Settings.SecurityRanges.Item(i).LowerIP Then Exit sub
			EventLog.Write("ERROR: EventHandlers.vbs : Function AutoBanIP")
			Err.Clear
	On Error Goto 0
	EventLog.Write("Autoban IP range being set for IP Address " & IPAddress)
	With oApp.Settings.SecurityRanges.Add()
		.lowerip = ipaddress
		.upperip = ipaddress
		.priority = 20
		.allowdeliveryfromlocaltolocal = False
		.allowdeliveryfromlocaltoremote = False
		.allowdeliveryfromremotetolocal = False
		.allowdeliveryfromremotetoremote = False
		.allowimapconnections = False
		.allowsmtpconnections = False
		.allowpop3connections = False
		.expires = True
		.ExpiresTime = DateAdd("d", NumberOfDays, Now())
		.name = ReasonForBan & " - banned for " & NumberOfDays & " days - " & ipaddress & "[" & CreateGUID & "]"
		.save
		If (Err.Number = 0) Then
			EventLog.Write("Autoban IP range saved for IP Address " & IPAddress)
			EventLog.Write("ERROR: EventHandlers.vbs : Function AutoBanIP - Saving")
			Err.Clear
		On Error Goto 0
jimwatt
Re: Blocking IP's
Post by jimwatt » 2023-05-21 13:07
Thanks thats the sort of thing I was looking for;
I need to think about concurrency in processing as the attempts were coming in at 12/second
Although I hold the last bad IP and reject if the same my system log had 4000 entries like this and it kept on going.
SMTPD – 111 – 147.78.103.140 ?
2023-05-15 07:21:45.400
SENT: 220 myserver ESMTP
2023-05-15 07:21:45.448
RECEIVED: HELO win-clj1b0gq6jp.domain
2023-05-15 07:21:47.600
SENT: 554 Rejected due to listed as spam source, see: http://www.sorbs.net
SMTPD – 112 – 147.78.103.140 ?
2023-05-15 07:21:46.495
2023-05-15 07:21:46.543
RECEIVED: EHLO win-clj1b0gq6jp.domain
2023-05-15 07:21:47.669
SENT: 554 Rejected
SMTPD – 113 – 147.78.103.140 ?
2023-05-15 07:21:47.593
2023-05-15 07:21:47.641
2023-05-15 07:21:47.712
SENT: 554 Rejected
Manually firewalling the IP range seems to have solved the problem for the moment.
Re: Blocking IP's
Post by SorenR » 2023-05-21 20:06
jimwatt wrote:
2023-05-21 13:07
That's why I went from API to DB injection. Don't get me wrong, I did build session locking into my first "Function AutoBan()" using the API but updating the database is just so much safer.
To add to the story, I have two servers and if one server bans an IP address ... so does the other via a simple REST (representational state transfer) API using HTTP (IIS) and PHP.
Re: Blocking IP's
Post by RvdH » 2023-05-22 17:12
2023-05-20 14:39
2023-05-20 08:09
2023-05-20 00:56
Afraid that doesn't work for IPv6, as the values are stored differently as (big)int values in rangelowerip1, rangelowerip2 and rangeupperip1, rangeupperip2 in database, not completely sure how that is calculated
IPv4 doesn't use rangelowerip2 and rangeupperip2
IPv6 is a 128-bit number which is too big to stuff into a single BIGINT type, it seems hmailserver splits up a v6 address at the 64-bit boundary, stuff the two halves into dual BIGINT columns.
For example the IPv6 equivalent for localhost is Lower IP ::1 to Upper IP ::1, in hms database stored as:
rangelowerip1 0
rangelowerip2 1
rangeupperip1 0
rangeupperip2 1
The internet range is Lower IP :: to Upper IP ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
rangelowerip1 0
rangelowerip2 0
rangeupperip1 -1
rangeupperip2 -1
jimwatt
Re: Blocking IP's
Post by jimwatt » 2023-07-29 01:43
In the line
2023-05-21 02:05
What does the CreateGUID do? It produces a blank on my server
Re: Blocking IP's
Post by jimimaseye » 2023-07-29 09:53
jimwatt wrote:
2023-07-29 01:43
In the line
2023-05-21 02:05
I suspect it should be doing as it implies but maybe mattg has missed a bit of code out of his posting. You can read about the function here: https://www.hmailserver.com/documentati ... _utilities
Re: Blocking IP's
Post by SorenR » 2023-07-29 17:23
I have used it here...
    If oMessage.HeaderValue("Message-Id") = "" Then
        With CreateObject("hMailServer.Utilities")
            oMessage.HeaderValue("Message-Id") = "<" & Mid(.GenerateGUID, 2, 36) & "@" & Split(oMessage.FromAddress,"@")(1) & ">"
Perhaps your version is based on a function/sub in the script?
Re: Blocking IP's
Post by mattg » 2023-07-30 02:05
jimwatt wrote:
2023-07-29 01:43
In the line
2023-05-21 02:05
It adds a random unique string to the end of the IP range name, to stop errors where multiple ranges for the same IP were trying to be written at once
Re: Blocking IP's
Post by jimimaseye » 2023-07-30 14:07
2023-07-30 02:05
jimwatt wrote:
2023-07-29 01:43
In the line
2023-05-21 02:05
I think he is saying that it is a function that is not working (nothing is produced). Likely because its a function you have created called 'CreateGUID' but haven't included it in your snippet of code.
Re: Blocking IP's
Post by mattg » 2023-07-31 23:18
Oh, you mean like this
Function CreateGUID
  Dim TypeLib
  Set TypeLib = CreateObject("Scriptlet.TypeLib")
  CreateGUID = Mid(TypeLib.Guid, 2, 36)
I can't even remember stealing that code, and I didn't record where I stole it from...
lonance
Re: Blocking IP's
Post by lonance » 2023-10-02 01:23
Hey guys,
I've been getting hammered by Chinese IP addresses... mostly trying to find an actual username on the server.
So I get a LOT of these in the logs.
"SENT: 550 Unknown user"
How can I autoban these IP addresses in HmailServer after several attempts that return that error?
I've started putting them in the firewall to block at FW. But that's getting tiresome.
Does the Beta Version have that capability builtin to the IP autoban or will I need to do some scripting?
Re: Blocking IP's
Post by palinka » 2023-10-02 17:31
lonance wrote:
2023-10-02 01:23
Hey guys,
Built in autoban should work fine.
https://www.hmailserver.com/documentati ... ce_autoban
Or you could try this script: https://hmailserver.com/forum/viewtopic ... 20&t=38573
lonance
Re: Blocking IP's
Post by lonance » 2023-10-02 19:53
Unfortunately, autoban doesn't come into play here since its not trying passcodes. It's sending a RCPT TO - to random usernames@domain.com trying to find a real user.
I'll check out the script you reference and see if that may help.
thanks.
Re: Blocking IP's
Post by palinka » 2023-10-02 22:12
lonance wrote:
2023-10-02 19:53
thanks.
I see. Yes, the script works well. But it will only work when its an IP that actually returns. Many bot nets are so big that you'll never see the same IP twice. If these connections are all coming from the same group of servers (repeated connections), then it should work very well for you.
lonance
Re: Blocking IP's
Post by lonance » 2023-10-03 01:05
2023-10-02 22:12
lonance wrote:
2023-10-02 19:53
thanks.
I've got the script partially working. It is collecting IP addresses but not pushing them into the hMailServer Autoban list. I also was trying to setup your IDS Viewer code. I can logon and then it shows a blank page. No header or foot, nothing. Could be related to the same issues as the autoban push.
I'm using MYSQL separate from the hMailServer... I downloaded an MYSQL ODBC connector for Windows, but I think it's 64 bit and I may need 32 bit. But the script is writing data to the IDS table using that connector.... hmmm.
Re: Blocking IP's
Post by SorenR » 2023-10-03 01:49
lonance wrote:
2023-10-03 01:05
2023-10-02 22:12
lonance wrote:
2023-10-02 19:53
thanks.
So, you got the handler set up in Windows Scheduler?
lonance
Re: Blocking IP's
Post by lonance » 2023-10-03 20:08
2023-10-03 01:49
lonance wrote:
2023-10-03 01:05
2023-10-02 22:12
Actually, I found that it does work. No, I don't have it in Scheduler yet. I was manually running the script from the desktop, but I wasn't seeing anything since I didn't have any IP addresses over 2 times in the DB until my cell phone email checked email several times and then it got blocked! :lol:
I've been looking over many of your scripts and others so that I can add GeoIP blocking. I want it to automagically put those CN and RU IPs in the autoban list.
I like the idea of logging all those IP addresses as well and was trying to do the PHP code that Palinka has to view them... not having any luck with that.
Re: Blocking IP's
Post by palinka » 2023-10-03 20:29
lonance wrote:
2023-10-03 20:08
You need to add the part that deletes IDS entries for successful logons. You need a custom hmailserver build or version 5.7 for that, which has the event Sub OnClientLogon(oClient).
