Authenticated Received Chain (ARC) support
jlight
Post by jlight » 2023-04-25 16:54
Since implementing DMARC on my domains I've had issues with forwarded messages failing DMARC. In researching how to resolve this issue I learned about Authenticated Received Chain (ARC) but could not find any information about ARC regarding hMailServer other than a post from almost 5 years ago (viewtopic.php?t=32606).
Looking at some documentation about ARC it doesn't seem terribly complicated. Can ARC support be added to hMailServer?
http://arc-spec.org/
https://postmarkapp.com/blog/what-is-ar ... ived-chain
Re: Authenticated Received Chain (ARC) support
Post by RvdH » 2023-04-25 17:37
jlight wrote:
2023-04-25 16:54
https://www.hmailserver.com/state
