Allow sender without @domain
tanaki
Post by tanaki » 2023-04-07 13:32
I am looking for solution how to allow hmailserver to accept messages with "MAIL FROM:" missing the domain part ( te "@...." part). Also if such message arrives I want to be able to append a domain part.
I tried catching the event "OnClientConnect" , but no message header is available. The event "OnSMTPData" doesn't work as well , because hmailserver SMTPD closes session before calling it.
Any suggestions are welcome.
Re: Allow sender without @domain
Post by SorenR » 2023-04-07 14:46
tanaki wrote:
2023-04-07 13:32
In which case would "MAIL FROM: <JOHN_DOE>" be true?
RFC say:
      "MAIL FROM:" ("<>" / Reverse-Path) [SP Mail-parameters] CRLF
And "Reverse-Path" is defined by:
      Reverse-path = Path
      Forward-path = Path
      Path = "<" [ A-d-l ":" ] Mailbox ">"
      A-d-l = At-domain *( "," A-d-l )
            ; Note that this form, the so-called "source route",
            ; MUST BE accepted, SHOULD NOT be generated, and SHOULD be
            ; ignored.
      At-domain = "@" domain
      Mail-parameters = esmtp-param *(SP esmtp-param)
      Rcpt-parameters = esmtp-param *(SP esmtp-param)
      esmtp-param     = esmtp-keyword ["=" esmtp-value]
      esmtp-keyword   = (ALPHA / DIGIT) *(ALPHA / DIGIT / "-")
      esmtp-value     = 1*(%d33-60 / %d62-127)
            ; any CHAR excluding "=", SP, and control characters
      Keyword  = Ldh-str
      Argument = Atom
      Domain = (sub-domain 1*("." sub-domain)) / address-literal
      sub-domain = Let-dig [Ldh-str]
      address-literal = "[" IPv4-address-literal /
                            IPv6-address-literal /
                            General-address-literal "]"
      Mailbox = Local-part "@" Domain
      Local-part = Dot-string / Quoted-string
            ; MAY be case-sensitive
      Dot-string = Atom *("." Atom)
      Atom = 1*atext
      Quoted-string = DQUOTE *qcontent DQUOTE
      String = Atom / Quoted-string
To understand recursion, you must first understand recursion.
Post by mattg » 2023-04-11 02:44
tanaki wrote:
2023-04-07 13:32
How will you know the domain to append?
Does the GUI switch 'allow empty sender address' in SMTP >> RFC compliance achieve what you want?
If you are talking about client connections to the SMTP server for OUTGOING mail, what you need to set is the 'default domain' on the advanced tab
