Script to Download Phishtank database for SA
gotspatel
Post by gotspatel » 2023-03-23 15:23
Recently came across an SA plugin ifplugin Mail::SpamAssassin::Plugin::Phishing
I have built(modified) a python script to download the csv file for phishing_phishtank_feed which rather is not possible to download by scripting as it requires token to download and they have stopped giving access to their API
SA Plugin options
        phishing_openphish_feed		/etc/spamassassin/feed.txt
        phishing_phishtank_feed		/etc/spamassassin/verified_online.csv
        phishing_phishstats_feed	/etc/spamassassin/phish_score.csv
        body     URI_PHISHING      	eval:check_phishing()
        describe URI_PHISHING      	Url match phishing in feed
        score URI_PHISHING			2.1
        phishing_phishstats_minscore	5
endif
Other database downloads as below
phishing_openphish_feed "https://openphish.com/feed.txt" --Updated 6 hours in Free
phishing_phishstats_feed "https://phishstats.info/phish_score.csv" --Updated every 90 minutes
The problematic database
phishing_phishtank_feed "http://data.phishtank.com/data/online-valid.csv"
Python Script (required python 2.7 minimum, pip and selenium)
from selenium import webdriver
from selenium.webdriver.chrome.options import Options
import os
import time
# Script downloaded from https://www.onlinetutorialspoint.com/selenium/python-selenium-download-a-file-in-headless-mode.html
# modified as per needs
DOWNLOAD_URL = "https://data.phishtank.com/data/online-valid.csv"
download_dir = "C:\\Program Files\\JAM Software\\SpamAssassin for Windows\\etc\\spamassassin\\"
driver_path = "C:\\Scripts\\SpamAssassin\\Download_phish\\chromedriver.exe"
def enable_download(driver):
    driver.command_executor._commands["send_command"] = ("POST", '/session/$sessionId/chromium/send_command')
    params = {'cmd':'Page.setDownloadBehavior', 'params': {'behavior': 'allow', 'downloadPath': download_dir}}
    driver.execute("send_command", params)
def setting_chrome_options():
    chrome_options = Options()
    chrome_options.add_argument("--headless")
    chrome_options.add_argument('--no-sandbox')
    chrome_options.add_experimental_option("prefs", {
        "download.prompt_for_download": False,
        "download.directory_upgrade": True,
        "safebrowsing_for_trusted_sources_enabled": False,
        "safebrowsing.enabled": False
    chrome_options.add_argument('--disable-gpu')
    chrome_options.add_argument('--disable-software-rasterizer')
    return chrome_options;
def isFileDownloaded():
    file_path = download_dir+"\\verified_online.csv"
    while not os.path.exists(file_path):
        time.sleep(1)
    if os.path.isfile(file_path):
        print("File Downloaded successfully..")
if __name__ == '__main__':
    driver = webdriver.Chrome(executable_path=driver_path,options=setting_chrome_options())
    driver.get(DOWNLOAD_URL)
    isFileDownloaded()
The file is updated every hour but it is rate limited to download at every 2 hours only without login through API
Re: Script to Download Phishtank database for SA
Post by palinka » 2023-03-23 18:28
What is this and why is it needed?
gotspatel
Post by gotspatel » 2023-03-24 05:53
2023-03-23 18:28
This is the Driver for chrome (browser) to run --headless (without any window) can be downloaded from HERE
it is needed so that the link will open in a browser mode, which in turn generate a unique token to download this csv file which otherwise will not download by other scripting methods.
Regards,
gotspatel
Post by gotspatel » 2023-03-24 06:33
Just to update
Works only on SpamAssassin V 4.0.0
Post by RvdH » 2023-03-24 09:07
@gotspatel
I must be one of the lucky ones, i have a PhishTank login and thus can download using my api key
Your script seems a bit overkill...can't this be done with wget or curl just as easy?
gotspatel
Post by gotspatel » 2023-03-24 09:28
2023-03-24 09:07
@gotspatel
You sure are the lucky one and we all are also lucky to have you here :mrgreen:
I tried all Powershell, batch script, vbscript, wget and curl, (both on windows and linux) but not working as every time you open the link it generates a new token which is stored in cache, it is being read and if available then only the file is downloaded.
h t t p s://cdn.phishtank.com/datadumps/verified_online.csv? Expires=1679643033&Signature=GyZpNuvHA7Aw9vIVl9Y2RTbEt998FXNc98vkjGR8zhlZoEaz2U~1xKcwgSjxO7KBy7PYRWJvzyI5v2eDIy1KA22tUXpkjutbg2jU437remEF4GTGKuC3iMXoKQ48BwDGgF2NEDoktu1xPVKu55wnqyiu9TtsJWY8HzDALyXOJeCPGLLEqBguqlTNFk-9OLeV6JLbPwvShcWDR1L3x~3OJUoLIPhJoljzXGQxxATQcWp1aeqSpGP5IiXJ8iKb0QQmgXVjyxP12O2FMuttDlhCbmrzlK2JphNb~DCOfuTvMcKXiH5IQuEbJcOrRvophixBJjEYBDGSkAN7goc0bGcuow__&Key-Pair-Id=APKAILB45UG3RB4CSOJA
The important parts highlighted
May be the code can be optimized will try out and post results. also ::TODO:: is logging which I am working on
Is there any option/way where we can get the API login as I tried sending multiple requests by email but no reply yet.
Regards
Post by SorenR » 2023-03-24 14:01
Just brainstorming here...
If I put this http://data.phishtank.com/data/online-valid.csv in the adderss field of my browser it actually downloads the file...
If I use Wget I get a crap message that it cannot save some weirdly named file...
Curl ... well, I got rate limited :roll:
There is also a json dataset that I can get with
wget --no-check-certificate http://data.phishtank.com/data/online-valid.json -o file.json
32 bit windows
Function jsonDecode(jsonString)
    On Error Resume Next
    Dim oSCtrl
    Set oSCtrl = CreateObject(MSScriptControl.ScriptControl)
    oSCtrl.Language = "JScript"
    Set jsonDecode = oSCtrl.Eval("(" & jsonString & ")")
    On Error GoTo 0
64 bit windows + https://github.com/tablacus/TablacusScriptControl
    Dim oSCtrl
    Set oSCtrl = CreateObject(ScriptControl)
    On Error GoTo 0
To understand recursion, you must first understand recursion.
Post by SorenR » 2023-03-24 14:20
Oh... https://phishtank.org/developer_info.php
We require that you use a descriptive User Agent string in your application to identify the application. If your User Agent is blank or generic, you may recieve an increased number of rate limited requests or be redirected to additional security checks.
Post by RvdH » 2023-03-24 14:23
wget has a param for that -U
SA can not work with json dataset
Post by SorenR » 2023-03-24 14:25
WTF ... !!!
C:\WINDOWS\system32>wget -U "phishtank/admin" --no-check-certificate https://data.phishtank.com/data/online-valid.csv
--2023-03-24 13:23:00--  https://data.phishtank.com/data/online-valid.csv
Resolving data.phishtank.com... 104.17.177.85, 104.16.101.75
Connecting to data.phishtank.com|104.17.177.85|:443... connected.
WARNING: cannot verify data.phishtank.com's certificate, issued by `/OU=generated by Avast Antivirus for SSL/TLS scanning/O=Avast Web/Mail Shield/CN=Avast Web/Mail Shield Root':
  Unable to locally verify the issuer's authority.
HTTP request sent, awaiting response... 302 Found
Location: https://cdn.phishtank.com/datadumps/verified_online.csv?Expires=1679660589&Signature=SeEPYsQtJKfCj1pQOOw2dARbM8Fztc7NSw4J5Dbr8PHws0kFX5vt8uILGUY4~nbZiRqx9xdaUtlg6przRK5ks9R3wU8VVEKs6pniOoQ4P87MgWe-oLe8Uj6ihqZ-IluILRcGrzXeGEYg-xIVEuJD5P5gOKJMX5ri7LVT3a7J1xjTLNqwoqksAmmIICj8ZYeP3CfphyhfefHP~pwZanji1Z-gsC4aEVZo2NT085yShj2dNyV9myAD56SnjXpruTtCYTbe3y8O~af3UOfIkWuv3rsCPUdw-6E1GtgdVzlunv6RPiU6mv1jr0Q-WP-NbzCNEbTQgkBTEZZ~qJk0PxxJag__&Key-Pair-Id=APKAILB45UG3RB4CSOJA [following]
--2023-03-24 13:23:00--  https://cdn.phishtank.com/datadumps/verified_online.csv?Expires=1679660589&Signature=SeEPYsQtJKfCj1pQOOw2dARbM8Fztc7NSw4J5Dbr8PHws0kFX5vt8uILGUY4~nbZiRqx9xdaUtlg6przRK5ks9R3wU8VVEKs6pniOoQ4P87MgWe-oLe8Uj6ihqZ-IluILRcGrzXeGEYg-xIVEuJD5P5gOKJMX5ri7LVT3a7J1xjTLNqwoqksAmmIICj8ZYeP3CfphyhfefHP~pwZanji1Z-gsC4aEVZo2NT085yShj2dNyV9myAD56SnjXpruTtCYTbe3y8O~af3UOfIkWuv3rsCPUdw-6E1GtgdVzlunv6RPiU6mv1jr0Q-WP-NbzCNEbTQgkBTEZZ~qJk0PxxJag__&Key-Pair-Id=APKAILB45UG3RB4CSOJA
Resolving cdn.phishtank.com... 104.17.177.85, 104.16.101.75
Connecting to cdn.phishtank.com|104.17.177.85|:443... connected.
WARNING: cannot verify cdn.phishtank.com's certificate, issued by `/OU=generated by Avast Antivirus for SSL/TLS scanning/O=Avast Web/Mail Shield/CN=Avast Web/Mail Shield Root':
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/csv]
verified_online.csv@Expires=1679660589&Signature=SeEPYsQtJKfCj1pQOOw2dARbM8Fztc7NSw4J5Dbr8PHws0kFX5vt8uILGUY4~nbZiRqx9xdaUtlg6przRK5ks9R3wU8VVEKs6pniOoQ4P87MgWe-oLe8Uj6ihqZ-IluILRcGrzXeGEYg-xIVEuJD5P5gOKJMX5ri7LVT3a7J1xjTLNqwoqksAmmIICj8ZYeP3CfphyhfefHP~pwZanji1Z-gsC4aEVZo2NT085yShj2dNyV9myAD56SnjXpruTtCYTbe3y8O~af3UOfIkWuv3rsCPUdw-6E1GtgdVzlunv6RPiU6mv1jr0Q-WP-NbzCNEbTQgkBTEZZ~qJk0PxxJag__&Key-Pair-Id=APKAILB45UG3RB4CSOJA: No such file or directory
Cannot write to `verified_online.csv@Expires=1679660589&Signature=SeEPYsQtJKfCj1pQOOw2dARbM8Fztc7NSw4J5Dbr8PHws0kFX5vt8uILGUY4~nbZiRqx9xdaUtlg6przRK5ks9R3wU8VVEKs6pniOoQ4P87MgWe-oLe8Uj6ihqZ-IluILRcGrzXeGEYg-xIVEuJD5P5gOKJMX5ri7LVT3a7J1xjTLNqwoqksAmmIICj8ZYeP3CfphyhfefHP~pwZanji1Z-gsC4aEVZo2NT085yShj2dNyV9myAD56SnjXpruTtCYTbe3y8O~af3UOfIkWuv3rsCPUdw-6E1GtgdVzlunv6RPiU6mv1jr0Q-WP-NbzCNEbTQgkBTEZZ~qJk0PxxJag__&Key-Pair-Id=APKAILB45UG3RB4CSOJA' (Result too large).
Post by RvdH » 2023-03-24 14:28
@echo off
cls
set "phishing_phishtank_feed=https://data.phishtank.com/data/online-valid.csv"
set "phishtank_filename=phishtank-feed.csv"
wget -b -q -N -U "phishtank/downloader" -O "%phishtank_filename%" "%phishing_phishtank_feed%"
This works just fine
Whereas:
-O,  --output-document=FILE      write documents to FILE
-N,  --timestamping              don't re-retrieve files unless newer than local
-U,  --user-agent=AGENT          identify as AGENT instead of Wget/VERSION
-b,  --background                go to background after startup
-q,  --quiet                     quiet (no output)
lowercase and uppercase params sometimes have different meanings, eg: case sensitive :!:
Post by SorenR » 2023-03-24 14:43
2023-03-24 14:28
@echo off
cls
Whereas:
I think I'm rate limited 'cause I'm not getting anything... Will try again in an hour or so.
Post by RvdH » 2023-03-24 14:47
with Api, eg: registered
-U "phishtank/[username]"
https://data.phishtank.com/data/[api-key]/online-valid.csv
@echo off
cls
set "phishtank_username={MYUSERNAME}"
set "phishtank_apikey={MYAPIKEY}"
set "phishtank_feed=https://data.phishtank.com/data/%phishtank_apikey%/online-valid.csv"
wget -b -q -N -U "phishtank/%phishtank_username%" -O "%phishtank_filename%" "%phishtank_feed%"
Post by RvdH » 2023-03-24 15:03
All in One, place wget.exe into C:\Program Files (x86)\SpamAssassin for Windows\etc\spamassassin\
C:\Program Files (x86)\SpamAssassin for Windows\etc\spamassassin\Phishing.cmd (to run with Task Scheduler)
@echo off
cls
set "phishtank_feed=https://data.phishtank.com/data/online-valid.csv"
wget -b -q -N -U "phishtank/downloader" -O "%phishtank_filename%" "%phishtank_feed%"
set "openphish_filename=openphish-feed.txt"
set "openphish_feed=https://openphish.com/feed.txt"
wget -b -q -N -U "openphish/downloader" -O "%openphish_filename%" "%openphish_feed%"
set "phishstats_filename=phishstats-feed.csv"
set "phishstats_feed=https://phishstats.info/phish_score.csv"
wget -b -q -N -U "phishstats/downloader" -O "%phishstats_filename%" "%phishstats_feed%"
C:\Program Files (x86)\SpamAssassin for Windows\etc\spamassassin\Phishing.cf
if (version >= 3.004002)
        phishing_openphish_feed C:\Program Files (x86)\SpamAssassin for Windows\etc\spamassassin\openphish-feed.txt
        phishing_phishtank_feed C:\Program Files (x86)\SpamAssassin for Windows\etc\spamassassin\phishtank-feed.csv
        phishing_phishstats_feed C:\Program Files (x86)\SpamAssassin for Windows\etc\spamassassin\phishstats-feed.csv
        #phishing_phishstats_minscore 5
        #phishing_uri_noparam 1
        describe	URI_PHISHING	Url matches phishing feed
        score		URI_PHISHING	5.0
    endif
endif
Post by RvdH » 2023-03-24 15:44
gotspatel wrote:
2023-03-23 15:23
Do relative paths work? docs say use absolute path (4.0.x), see:
https://spamassassin.apache.org/full/4. ... shing.html
Post by RvdH » 2023-03-25 13:08
Mmm, damn....turns out -N -O {newfilename} params do not work together
WARNING: timestamping does nothing in combination with -O. See the manual
for details.
gotspatel
Post by gotspatel » 2023-04-08 08:37
2023-03-24 15:03
@echo off
cls
    endif
endif
Just an update to this script. (as it needs to wait for downloading to complete ) when running form task scheduler
@echo off
cls
REM wget.exe needs to be in the script folder
set "phishtank_filename=C:\Program Files\JAM Software\SpamAssassin for Windows\etc\spamassassin\phishtank-feed.csv"
wget -b -q -U "phishtank/downloader" -O "%phishtank_filename%" "%phishtank_feed%"
set "openphish_filename=C:\Program Files\JAM Software\SpamAssassin for Windows\etc\spamassassin\openphish-feed.txt"
wget -b -q -U "openphish/downloader" -O "%openphish_filename%" "%openphish_feed%"
set "phishstats_filename=C:\Program Files\JAM Software\SpamAssassin for Windows\etc\spamassassin\phishstats-feed.csv"
wget -b -q -U "phishstats/downloader" -O "%phishstats_filename%" "%phishstats_feed%"
ping -n 10 127.0.0.1 >nul
Post by palinka » 2023-04-08 11:39
gotspatel wrote:
2023-04-08 08:37
You can put it anywhere and place it in the system path. That might be more useful if you want to use it for more than this particular script.
Post by palinka » 2023-04-08 12:13
You could also make these one liners in your schedule task actions and forget about the script altogether.
wget -b -q -U "phishtank/downloader" -O "C:\SpamAssassin\etc\spamassassin\phishtank-feed.csv" "https://data.phishtank.com/data/online-valid.csv"
wget -b -q -U "openphish/downloader" -O "C:\SpamAssassin\etc\spamassassin\openphish-feed.txt" "https://openphish.com/feed.txt"
wget -b -q -U "phishstats/downloader" -O "C:\SpamAssassin\etc\spamassassin\phishstats-feed.csv" "https://phishstats.info/phish_score.csv"
gotspatel
Post by gotspatel » 2023-04-08 12:24
2023-04-08 11:39
gotspatel wrote:
2023-04-08 08:37
Correct :D
Done, in fact just installed UNIXUTILS and added in system path for more unix commands
gotspatel
Post by gotspatel » 2023-04-08 12:25
2023-04-08 12:13
I don't know why but the Phishtank feed sometimes need a wait elase the file is written with 0 bytes :shock:
hence "ping -n 10 127.0.0.1 >nul"
Regards
Post by palinka » 2023-04-08 12:31
gotspatel wrote:
2023-04-08 12:25
2023-04-08 12:13
Regards
Get rid of "-b" and you will be able to pull an exit code. As soon as it goes to background - which is ALWAYS successful - the exit code will always be 0 for success. Removing the background command will force it to complete with an exit code which you can use to find the error.
Allowing it to complete before exiting the task might just solve your issue in the first place.
EXIT STATUS
Wget may return one of several error codes if it encounters problems.
0 No problems occurred.
1 Generic error code.
2 Parse error---for instance, when parsing command-line options, the .wgetrc or .netrc...
3 File I/O error.
4 Network failure.
5 SSL verification failure.
6 Username/password authentication failure.
7 Protocol errors.
8 Server issued an error response.
With the exceptions of 0 and 1, the lower-numbered exit codes take precedence over higher-numbered ones, when multiple types of errors are encountered.
In versions of Wget prior to 1.12, Wget’s exit status tended to be unhelpful and inconsistent. Recursive downloads would virtually always return 0 (success), regardless of any issues encountered, and non-recursive fetches only returned the status corresponding to the most recently-attempted download.
Right now I'm working on a powershell function to handle this so I can add it to my nightly backup script. :D
gotspatel
Post by gotspatel » 2023-04-08 12:56
2023-04-08 12:31
:mrgreen: See I was just motivating you to update the backup script.
waiting soon an update. :D
Post by palinka » 2023-04-08 13:39
gotspatel wrote:
2023-04-08 12:56
2023-04-08 12:31
OK, I just finished writing it. Give me a few days to test it. Requires wget in the system path.
I ran into the 0 byte file issue while testing on fake urls (in order to generate an error code). You might want to remove the -b and try to figure out what's going on. I might run into the same issue. I'm thinking about how to deal with that. The problem is the file is created first, then the download attempt is made. So maybe I could download to a temp file, and if the download was successful I would overwrite the local file. That way, if it fails, you don't end up with a 0 byte file that does nothing (or potentially worse) for your SA operation.
Post by RvdH » 2023-07-26 17:34
phishstats.info is no more :(
Post by palinka » 2023-07-26 22:04
2023-07-26 17:34
Are you sure? It would not download twice last week, but it worked for me last night.
Post by RvdH » 2023-07-26 22:14
i get ERR_NAME_NOT_RESOLVED
And last it downloaded was some parking website html
https://github.com/apache/spamassassin/ ... 73a2447730
Post by palinka » 2023-07-26 23:15
Non-authoritative answer:
Address:  199.59.243.224
Aliases:  phishstats.info
Son of a bitch... Here's what I've been "downloading successfully".
<!doctype html>
<html data-adblockkey="MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBANDrp2lz7AOmADaN8tA50LsWcjLFyQFcb/P2Txc58oYOeILb3vBw7J6f4pamkAQVSQuqYsKx3YzdUHCvbVZvFUsCAwEAAQ==_jF6xGMSgrVgdK+tS0Y4DG/GMdRPEnUa/3ObF/ExZ3QLo26EumVtBPmVQTXHwQVz0zE0Mr9FLfq1vgtZUtxvAuA==" lang="en">
<head>
    <meta charset="utf-8">
    <meta name="viewport" content="width=device-width, initial-scale=1">
    <link rel="icon" href="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAAAABCAIAAACQd1PeAAAADElEQVQI12P4//8/AAX+Av7czFnnAAAAAElFTkSuQmCC">
    <link rel="preconnect" href="https://www.google.com" crossorigin>
</head>
<body>
<div id="target" style="opacity: 0"></div>
<script>window.park = "eyJ1dWlkIjoiOTc3NTRmNzgtZDc4OC00N2U5LWI2OTItZTAyZTQ3YTZkYWEwIiwicGFnZV90aW1lIjoxNjkwMzQzOTIzLCJwYWdlX3VybCI6Imh0dHBzOi8vcGhpc2hzdGF0cy5pbmZvL3BoaXNoX3Njb3JlLmNzdiIsInBhZ2VfbWV0aG9kIjoiR0VUIiwicGFnZV9yZXF1ZXN0Ijp7fSwicGFnZV9oZWFkZXJzIjp7InJlZmVyZXIiOlsiIl19LCJob3N0IjoicGhpc2hzdGF0cy5pbmZvIiwiaXAiOiIyMDUuMTg1LjEyMy4xMTgifQo=";</script>
<script src="/js/parking.2.106.5.js"></script>
</body>
</html>
Post by RvdH » 2023-07-27 09:34
ERR_NAME_NOT_RESOLVED was caused by AdGuard Home on my pi :lol:
Post by palinka » 2023-09-23 20:00
Looks like phishstats is back.
Did SA ever put it back into phishing.pm?
Post by palinka » 2023-09-24 10:16
Looks like I spoke too soon. Sort of. You still cannot download the csv, but you can query the database. However, they both limit max results per query and rate limit queries, so its basically impossible to get the entire database.
Anyway, it still looks dead. The last db entry is from Aug 8.
https://phishstats.info:2096/api/phishing?_sort=-date
