Install Internal mail server only
Good morning, Please forgive my ignorance if this is the wrong place to post this question. I want to set up a hmail server for internal mail use only. This will be used in an isolated network with a single active directory domain. I don't want to send any mail externally or receive any email from external sources. Can someone point me to the correct documentation or make any suggestions for the setup.
Thank you
Thank you
Re: Install Internal mail server only
It can be done and been done many times before.
You simple need a Authoritative DNS-Server in your LAN Network like BIND or Microsofts DNS-Server.
If you are not able to implement the DNS-Server Zone for your local LAN, ask an Admin which knows howto setup
a Authoritative DNS-Server.
Thank you,
Not really... If this is going to be "Internal mail server only" then emails do not leave the server and server always know own domains!Dravion wrote: ↑2022-09-23 22:50It can be done and been done many times before.
IMAP/SMTP connections can easily be done with IP addresses as it is INTERNAL.
Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
“Yeah,” reply the bytes. “Make us a double.”
Yeah, we all know SMTP-Servers works best without a MX record....
- jimimaseye
- Moderator
smtp servers know of their own existence and therefore do not need an mx record.
"Where do i send this letter? I need an atlas. Oh wait... I'm sending it to myself"
jimimaseye wrote: ↑2022-09-27 18:57smtp servers know of their own existence and therefore do not need an mx record.
Yeah, nice. A SMTP-Server which doesn't serve clients, makes total sense^^
- jimimaseye
- Moderator
SMTP doesn't need to know about the clients. Mx records point to the server and that's what the ip address is for (as Soren said).
No, the MX record points to an A record which points to an ip.jimimaseye wrote: ↑2022-09-27 19:12SMTP doesn't need to know about the clients. Mx records point to the server and that's what the ip address is for (as Soren said).
By now, you should really know how this works.
- jimimaseye
- Moderator
I do. And i know how to recognise pointless arguments.
Op had his answer and given two options. He can take either the complicated way or the simple way. It's his choice.
(Why you want to argue with anyone about pointless technicalities heaven only knows. There's enough of that going on around here - you of all people should understand it achieves nothing but animosity).
- New user
hi, i wish i could help you, this is very easy to do. you can even have it configure site-to-site internal mailing system.
