Special Chars like ° è in Subject
Wichert
Post by Wichert » 2021-06-14 13:52
we have some Scripts witch change the E-Mail Body in the right Format for us.
Now i have the Problem that the Topic has following chars and the rule wont work. (France special Chars)
Original Subject: "701 N° de pièce 2018006532"
I want search for "701 N° de piéce" and change it to e.g. "Facture"
My code works fine with normal Chars.
if Left(oMessage.Subject,15) = "701 N° de pièce" Then
  oMessage.Subject = "Facture" & right(oMessage.Subject,len(oMessage.Subject)-15)
End if
I hope someone can help me.
Best Regards
Re: Special Chars like ° è in Subject
Post by katip » 2021-06-14 14:37
have a look at this:
https://www.rapidtables.com/code/text/ascii-table.html
try ChrW(232) and 176 (or 186, not sure) in your script.
if Left(oMessage.Subject,15) = "701 N" & ChrW(176) & " de pi" & ChrW(232) & "ce" Then
maybe it works..
HMS 5.7.0, MariaDB 10.4.10, SA 3.4.2, ClamAV 0.103.2
Post by SorenR » 2021-06-14 14:38
katip wrote:
2021-06-14 14:37
maybe it works..
Or RegEx..
(i'm away from my computer)
Wichert
Post by Wichert » 2021-06-22 10:31
that is exactly what i need.
Thanks a lot for you help.
Best Regards
Wichert
