Multiple China IPs Appeared in Log
thomas10
Post by thomas10 » 2021-05-18 06:24
Hi Guys,
When I checked the hmail log, I found out that there are a lot of IPs from China have been trying over and over again and ended up authentication failed. Each IP will keep on sending around 20 minutes. I have tried to block those IPs but those IPs kept on changing and trying, resulted my log file size become very big.
I have:-
- Tried turn on greylisting but still the same issue.
- Block IP under IP Range can block the encountered IPs but not the new one, meaning I need to block over and over again.
Currently found that the IPs are starting with 114.x.x.x, 117.x.x.x, 180.x.x.x, 49.x.x.x, 58.x.x.x
Is there any way to tackle this issue? We have China colleagues and customers so block the entire range doesn't seem to be a good choice.
Below is sample of one of the IP that was trying from 12.04am till 12.24am. The log between this timing is very long too so I crop only some part of it.
Appreciated your reply.
"TCPIP"	1432	"2021-05-18 00:04:46.660"	"TCP - 49.75.214.30 connected to
{Edited}"
"SMTPD"	1432	101002	"2021-05-18 00:04:46.660"	"49.75.214.30"	"SENT: 220
{Edited}"
"SMTPD"	3044	101002	"2021-05-18 00:04:46.863"	"49.75.214.30"	"RECEIVED: EHLO
jddif"
"SMTPD"	3044	101002	"2021-05-18 00:04:46.863"	"49.75.214.30"	"SENT:
{Edited} [nl]250-SIZE[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	4540	101002	"2021-05-18 00:04:47.097"	"49.75.214.30"	"RECEIVED: AUTH
LOGIN"
"SMTPD"	4540	101002	"2021-05-18 00:04:47.097"	"49.75.214.30"	"SENT: 334
VXNlcm5hbWU6"
"SMTPD"	3900	101002	"2021-05-18 00:04:47.331"	"49.75.214.30"	"RECEIVED:
Y2hlbndlaQ=="
"SMTPD"	3900	101002	"2021-05-18 00:04:47.331"	"49.75.214.30"	"SENT: 334
UGFzc3dvcmQ6"
"SMTPD"	3044	101002	"2021-05-18 00:04:47.970"	"49.75.214.30"	"RECEIVED: ***"
"SMTPD"	3044	101002	"2021-05-18 00:04:47.970"	"49.75.214.30"	"SENT: 535
Authentication failed. Restarting authentication process."
"SMTPD"	4540	101002	"2021-05-18 00:04:48.189"	"49.75.214.30"	"RECEIVED: EHLO
nkzhz"
"SMTPD"	4540	101002	"2021-05-18 00:04:48.189"	"49.75.214.30"	"SENT:
"SMTPD"	3900	101002	"2021-05-18 00:04:48.423"	"49.75.214.30"	"RECEIVED: AUTH
LOGIN"
"SMTPD"	3900	101002	"2021-05-18 00:04:48.423"	"49.75.214.30"	"SENT: 334
VXNlcm5hbWU6"
"SMTPD"	3044	101002	"2021-05-18 00:04:48.657"	"49.75.214.30"	"RECEIVED:
Y2hlbndlaQ=="
"SMTPD"	3044	101002	"2021-05-18 00:04:48.657"	"49.75.214.30"	"SENT: 334
UGFzc3dvcmQ6"
"SMTPD"	1432	101002	"2021-05-18 00:04:48.891"	"49.75.214.30"	"RECEIVED: ***"
"SMTPD"	1432	101002	"2021-05-18 00:04:48.891"	"49.75.214.30"	"SENT: 535
"SMTPD"	3900	101002	"2021-05-18 00:04:49.671"	"49.75.214.30"	"RECEIVED: EHLO
tndsj"
"SMTPD"	3900	101002	"2021-05-18 00:04:49.671"	"49.75.214.30"	"SENT:
"SMTPD"	3044	101002	"2021-05-18 00:04:49.905"	"49.75.214.30"	"RECEIVED: AUTH
LOGIN"
"SMTPD"	3044	101002	"2021-05-18 00:04:49.905"	"49.75.214.30"	"SENT: 334
VXNlcm5hbWU6"
"SMTPD"	1432	101002	"2021-05-18 00:04:50.139"	"49.75.214.30"	"RECEIVED:
Y2hlbndlaQ=="
"SMTPD"	1432	101002	"2021-05-18 00:04:50.139"	"49.75.214.30"	"SENT: 334
UGFzc3dvcmQ6"
"SMTPD"	3900	101002	"2021-05-18 00:04:50.357"	"49.75.214.30"	"RECEIVED: ***"
"SMTPD"	3900	101002	"2021-05-18 00:04:50.357"	"49.75.214.30"	"SENT: 535
"SMTPD"	1432	101002	"2021-05-18 00:04:50.576"	"49.75.214.30"	"RECEIVED: EHLO
vieyv"
"SMTPD"	1432	101002	"2021-05-18 00:04:50.576"	"49.75.214.30"	"SENT:
{Edited}[nl]250-SIZE[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	1432	101002	"2021-05-18 00:04:50.778"	"49.75.214.30"	"RECEIVED: AUTH
LOGIN"
"SMTPD"	1432	101002	"2021-05-18 00:04:50.778"	"49.75.214.30"	"SENT: 334
VXNlcm5hbWU6"
"SMTPD"	4540	101002	"2021-05-18 00:04:51.012"	"49.75.214.30"	"RECEIVED:
Y2hlbndlaQ=="
"SMTPD"	4540	101002	"2021-05-18 00:04:51.012"	"49.75.214.30"	"SENT: 334
UGFzc3dvcmQ6"
"SMTPD"	3900	101002	"2021-05-18 00:04:51.215"	"49.75.214.30"	"RECEIVED: ***"
"SMTPD"	3900	101002	"2021-05-18 00:04:51.215"	"49.75.214.30"	"SENT: 535
"SMTPD"	1432	101002	"2021-05-18 00:04:51.418"	"49.75.214.30"	"RECEIVED: EHLO
jdwxw"
"SMTPD"	1432	101002	"2021-05-18 00:04:51.418"	"49.75.214.30"	"SENT:
"SMTPD"	4540	101002	"2021-05-18 00:04:51.652"	"49.75.214.30"	"RECEIVED: AUTH
LOGIN"
"SMTPD"	4540	101002	"2021-05-18 00:04:51.652"	"49.75.214.30"	"SENT: 334
VXNlcm5hbWU6"
"SMTPD"	3900	101002	"2021-05-18 00:04:51.886"	"49.75.214.30"	"RECEIVED:
Y2hlbndlaQ=="
"SMTPD"	3900	101002	"2021-05-18 00:04:51.886"	"49.75.214.30"	"SENT: 334
UGFzc3dvcmQ6"
"SMTPD"	1432	101002	"2021-05-18 00:04:52.089"	"49.75.214.30"	"RECEIVED: ***"
"SMTPD"	1432	101002	"2021-05-18 00:04:52.104"	"49.75.214.30"	"SENT: 535
"SMTPD"	4540	101002	"2021-05-18 00:04:52.822"	"49.75.214.30"	"RECEIVED: EHLO
oygda"
"SMTPD"	4540	101002	"2021-05-18 00:04:52.822"	"49.75.214.30"	"SENT:
"SMTPD"	3900	101002	"2021-05-18 00:04:53.025"	"49.75.214.30"	"RECEIVED: AUTH
LOGIN"
"SMTPD"	3900	101002	"2021-05-18 00:04:53.025"	"49.75.214.30"	"SENT: 334
VXNlcm5hbWU6"
"SMTPD"	3044	101002	"2021-05-18 00:04:53.259"	"49.75.214.30"	"RECEIVED:
Y2hlbndlaQ=="
"SMTPD"	3044	101002	"2021-05-18 00:04:53.274"	"49.75.214.30"	"SENT: 334
UGFzc3dvcmQ6"
"SMTPD"	3900	101002	"2021-05-18 00:04:53.493"	"49.75.214.30"	"RECEIVED: ***"
"SMTPD"	3900	101002	"2021-05-18 00:04:53.493"	"49.75.214.30"	"SENT: 535
"SMTPD"	1432	101002	"2021-05-18 00:04:53.680"	"49.75.214.30"	"RECEIVED: EHLO
ixgqo"
"SMTPD"	1432	101002	"2021-05-18 00:04:53.680"	"49.75.214.30"	"SENT:
"SMTPD"	3044	101002	"2021-05-18 00:04:53.883"	"49.75.214.30"	"RECEIVED: AUTH
LOGIN"
"SMTPD"	3044	101002	"2021-05-18 00:04:53.883"	"49.75.214.30"	"SENT: 334
VXNlcm5hbWU6"
"SMTPD"	3044	101002	"2021-05-18 00:04:54.101"	"49.75.214.30"	"RECEIVED:
Y2hlbndlaQ=="
"SMTPD"	3044	101002	"2021-05-18 00:04:54.101"	"49.75.214.30"	"SENT: 334
UGFzc3dvcmQ6"
"SMTPD"	3900	101002	"2021-05-18 00:04:54.351"	"49.75.214.30"	"RECEIVED: ***"
"SMTPD"	3900	101002	"2021-05-18 00:04:54.351"	"49.75.214.30"	"SENT: 535
"SMTPD"	3044	101002	"2021-05-18 00:04:54.569"	"49.75.214.30"	"RECEIVED: EHLO
axrml"
Re: Multiple China IPs Appeared in Log
Post by mattg » 2021-05-18 06:59
A few things
#1 That is hMailserver doing it's job (rejecting malicious attempts)
#2 turn your SMTP >> maximum number of invalid commands down to 3
#3 don't assume that all IPs that match what you say are from China or are malicious. One of my IPs would match that list
You could also turn off AUTH for port 25, if you can get all of your users to submit mail via port 587 or 465, and just leave port 25 for receiving outside mail to your server
thomas10
Post by thomas10 » 2021-05-18 08:22
2021-05-18 06:59
A few things
Hi Matt,
Lovely, the max number of invalid command was greyed due to the Disconnect client after too many invalid commands is Unticked. Perhaps will try that.
Another question, how do you think about the autoban feature, yes this will ban certain IP that has too many invalid logon attempt. But is it possible to ban the IP of a genuine email, meaning a false positive? :oops:
Post by jimimaseye » 2021-05-18 08:43
thomas10 wrote:
2021-05-18 08:22
No... unless you are trying to set up an email client as new and forgot the password (a highly unlikely situation) or you use a webmail service and haven't set the ip range correctly. https://www.hmailserver.com/documentati ... ce_autoban
thomas10
Post by thomas10 » 2021-05-19 03:44
2021-05-18 08:43
thomas10 wrote:
2021-05-18 08:22
ok. Will try for the "Disconnect client after too many invalid commands" & "Maximum number of invalid commands" first. For this part, if the client was disconnected after too many invalid command, how long will it be disconnected? Because I don't see any timer to state there. :oops:
Post by jimimaseye » 2021-05-19 08:45
Read the link.
vidiot
Post by vidiot » 2021-05-19 20:20
You may be interested in this script: viewtopic.php?f=7&t=33447&p=208961&hili ... AN#p208961
I've run it for years, and it is effective. Eventually, on Win2012R2 at least, the firewall scope will fill up and you'll need to add another rule, but a small price to pay!
