Newbie help :-)
thierry_b
Newbie help :-)
Post by thierry_b » 2021-05-12 12:05
Sorry for my bad English, I'm French and I just discover hMailServer. Great soft !!
I use below script to save Attachement.
How can I find Account name of "oMessage" ? I want to save attachements relative to account names.
Thanks!
Sub SaveAttachments(oMessage)
' this routine saves file attachments that have the specified
' FileExtensions.
Dim PFolder
Dim SaveFolder 'where to store attachments. This folder must already exist.
SaveFolder = "c:\path_to_folder\" ' trailing slash is required
Dim SavedFile
Dim FileExtensions ' set to the file attachment extensions you want to save
FileExtensions = "(pdf|doc|xml|png|jpg|xls|xlsx|tif)"
Dim oAttachment
Dim oRegExp
Set oRegExp = new RegExp
For oAttachment = 0 to oMessage.Attachments.Count-1
' Test for specified attachments
with oRegExp
.Pattern = "^.*\."& FileExtensions & "$"
.IgnoreCase = True
.Global = False
end with
if (oRegExp.test(oMessage.Attachments(oAttachment).Filename)) Then Sauvegarde toutes les pièces jointes
SavedFile = SaveFolder & Left(Right(oMessage.Filename,42),38) & "." & oAttachment & "." & oMessage.Attachments(oAttachment).Filename
oMessage.Attachments(oAttachment).SaveAs(SavedFile)
' uncomment below to Delete Attachment from message
'oMessage.Attachments(oAttachment).Delete
Set oRegExp = nothing
Re: Newbie help :-)
Post by RvdH » 2021-05-12 12:22
You probably have to loop trough all recipients and then (most likely) only save those attachments for local users, eg:
For oRecipient = 0 to oMessage.Recipients.Count-1
	If oMessage.Recipients(oRecipient).IsLocalUser Then
	accountname = oMessage.Recipients(oRecipient).Address
	End if
thierry_b
Re: Newbie help :-)
Post by thierry_b » 2021-05-12 12:27
I'll try this.
Regards
Thierry
thierry_b
Re: Newbie help :-)
Post by thierry_b » 2021-05-12 12:47
2021-05-12 12:22
	End if
That's TOP :-)
Question : is it possible to change Attachements name before forwarding (list forwarding) ?
Re: Newbie help :-)
Post by RvdH » 2021-05-12 13:43
Renaming, probably not...but i think it might be possible to save & rename the attachment, next delete the attachment and then re-attach the saved and renamed attachment
Re: Newbie help :-)
Post by SorenR » 2021-05-12 14:34
2021-05-12 12:22
	End if
Is the account name and domain not part of the file path in oMessage.Filename ??
thierry_b
Re: Newbie help :-)
Post by thierry_b » 2021-05-13 00:34
2021-05-12 13:43
Ok, I will try this
