Receiving email from any subdomain.
Hey there. I had a pleasant experience with hmailserver after spending days trying to set up postfix to no avail.
I was wondering if I could have any subdomain forward to a root email using a rule or script?
I found this was related: https://www.hmailserver.com/forum/viewtopic.php?t=20444
Although he only needed to forward to a catch all email, I need to forward to the appropriate user.
Example:
bloxxite@this.is.an.example.com -> bloxxite@example.com
Thank you!
Example:
Thank you!
Re: Receiving email from any subdomain.
You can have aliases on your domain. Check Names in domain settings.
I have multiple users and would like to forward from their subdomain of choice to the root domain to their account.
I can't do wildcard subdomains in aliases, plus if there were, I would have to create a new alias per user.
Alright, I'm gonna learn VBScript and make an SMTP External to External handler myself. Thank you!
When I am done hopefully I can edit this post to include my code.
How will you receive the message if there is no mx record for this.is.an.example.com?
I can do * for my MX record.
- Senior user
That's weird, because my server is getting the HELO from gmail when I do a subdomain like that.
It just thinks that the "To" is external so it wants authentication.
not all dns servers accept the input " * for mx record " but some surely do ( it is ok by for example https://tools.ietf.org/html/rfc1912 section 2.7 and https://tools.ietf.org/html/rfc4592#section-2.2.1 ) but be sure to know what to expect from it, 1 caveat could be.. there can only be 1 of info@, suport@, webmaster@, and so forth.
No, most DNS server don't reduce it to the first subdomain level only. So *.example.com will also serve a.b.c.d.example.com.mikedibella wrote: ↑2020-08-06 02:00Remember that *.example.com will only catch an.example.com, not is.an.example.com or this.is.an.example.com.
On wildcard certificates you're right. *.example.com is only valid for this first subdomain level.
- Senior user
Yup, that's where I got my circuits crossed.On wildcard certificates you're right. *.example.com is only valid for this first subdomain level.
