SMTP-Only Certain Domains?
HarryR
Post by HarryR » 2020-07-16 15:09
I've been looking around and not finding anything on this exact question, is there a way to block certain protocols for domain names registered in hMail?
Scenario:
I have about 6 or 7 domains attached to hmail, some of these domains have their own IMAP / POP3 hosted on their own servers and are simply using my hmail to send e-mails.
When sending e-mails to their own domains (From: no-reply@domain.com To: info@domain.com) - I'm getting an error message with "User not found" assuming that the username (of the recipient) doesn't exist on my hmail setup - which is correct.
Is there any way to say "if this domain, send to external server"?
Thanks in advance,
Harry.
Web developer for cinema and alcohol chains across the world.
My own site can be found at https://harryrichards.co.uk
Re: SMTP-Only Certain Domains?
Post by palinka » 2020-07-16 15:17
Setup a route for domain.com that connects directly to domain.com's server.
Then create a global rule if to contains domain.com, then use route.
Post by mattg » 2020-07-16 15:50
just creating the route is enough
no need for the global rule
