SMTP authentication
PeterChan
SMTP authentication
Post by PeterChan » 2020-05-04 08:26
Is there a way to enable SMTP authentication in hMailserver?
Re: SMTP authentication
Post by jimimaseye » 2020-05-04 09:19
Have you ever considered reading the documentation?
https://www.hmailserver.com/documentati ... ce_iprange
PeterChan
Post by PeterChan » 2020-05-04 10:27
Sorry, due to error encountered below
535 Authentication failed. Restarting authentication process
with hMailserver, what needs to be adjusted to the server/user account? I am using correctly the user account with the password.
Post by RvdH » 2020-05-04 10:54
PeterChan wrote:
2020-05-04 10:27
Apparently you do not :shock:
Post by mattg » 2020-05-05 00:21
Use your email address as the username
Username in the form of 'peter@example.com' and NOT just 'peter'
PeterChan
Post by PeterChan » 2020-05-05 06:24
Yes, I used full account details like
oServer.User = "sender@???.com";
oServer.Password = "???";
oServer.ConnectType = SmtpConnectType.ConnectSSLAuto;
I used EASendMail package for this (in .Net application) but support of EASendMail said that current issue is "account authentication problem" and they could not help further.
Post by mattg » 2020-05-05 09:28
Try connecting with SSL first and see if that works
I've found that .NET SSL settings can often not be what you expect
I don't use EASendMail package though but I have used .NET's built in mail classes
PeterChan
Post by PeterChan » 2020-05-06 08:33
Thanks. Can you share it regarding .NET's built in mail classes?
Post by RvdH » 2020-05-06 11:04
