Change oder Update From
much_r
Post by much_r » 2020-04-29 14:13
is there a possibility to change "From" with the email address of the local user?
Example:
From (Senderaddress) = "test@rubner.com" or "empty From"
User in hMailserver = "mailuser@company.com"
Change "test@rubner.com" to "mailuser@company.com" and then send
Or even change "empty From" to "mailuser@company.com" and then send
Thanks and greetings
Michael
Re: Change oder Update From
Post by RvdH » 2020-04-29 14:17
Why you would like to do something like that?
much_r
Post by much_r » 2020-04-29 14:39
thanks for the answer :-)
An important application unfortunately sends mails with empty senders. Unfortunately I can't change that ...
Our SPAM filter blocks emails with empty senders.
Greetings
Michael
Post by RvdH » 2020-04-29 14:46
What are we talking about? The Envelope From or the Message From?
Hint :!:
	if Len(oMessage.FromAddress)=0 Then
		oMessage.FromAddress = "new@example.com"
		oMessage.From = "<new@example.com>"
		oMessage.save
	end if
much_r
Post by much_r » 2020-04-29 16:10
That is exactly what I have been looking for.
Many thanks
best greetings
Post by katip » 2020-04-29 21:41
you can also try General Rules.
if From contains "test@rubner.com"
Set Header value From "mailuser@company.com"
empty From is tricky. to identify only outgoing mails you have to lookup a header in Custom header field such as Message-ID which (usually) contains your domain name or better a specific header added by your sending application (or even Subject if it adds something significant there).
if From doesn't contain "@" and Custom header field X-Yz contains "something significant"
much_r
Post by much_r » 2020-05-26 18:41
Hi katip
Thank you.
The solution with the script works very well.
Greetings
