Issue to port
PeterChan
Issue to port
Post by PeterChan » 2020-04-15 11:09
What to further enable, due to issue like
Microsoft Telnet> o localhost 465
Connecting To localhost...Could not open connection to the host, on port 465: Connect failed
I've already enabled TCP and UDP In/out rule on this port. Why does error happen?
Re: Issue to port
Post by jimimaseye » 2020-04-15 11:24
PeterChan
Re: Issue to port
Post by PeterChan » 2020-04-15 15:10
What is password to run it?
Re: Issue to port
Post by mattg » 2020-04-15 15:30
your hmailserver administrator password
PeterChan
Re: Issue to port
Post by PeterChan » 2020-04-16 04:18
Please help to report below
2020-04-15   Hmailserver: 5.6.7-B2425
DOMAINS
     (No Domains Entered)
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Host: Domain0.com         Empty sender:       True  Batch recipients:   100
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-04-15.log
SYSTEM TESTS
Database type: MSSQL
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=          ws_login
Port=              0
Server=            WIN-429I3QNHOQT\EXPR2012
Internal=          0
Generated by HMSSettingsDiagnostics v1.99, Hmailserver Forum.
Re: Issue to port
Post by jimimaseye » 2020-04-16 10:10
You are trying to connect on port 465 but you do not have port 465 configured (as shown above).
Try connecting on one if the ports configured.
PeterChan
Re: Issue to port
Post by PeterChan » 2020-04-16 12:16
Thanks. How to configure port 465?
Re: Issue to port
Post by RvdH » 2020-04-16 17:22
PeterChan wrote:
2020-04-16 12:16
Come on! Really?
https://www.hmailserver.com/documentati ... _tcpipport
