Problem with my certificate for the client
Too
Post by Too » 2019-08-21 12:46
Hi everyone !
The last few days, I lost all my hairs and I need a little help :(
I have an HmailServer and I'm able to send and receive email with some adresses.
But since a few days, I'm not able to add a new account on a mail client (outlook / thunderbird on computer, gmail or K9 on mobile)
The existing accounts are still working perfectly !
Gmail app say on android that my certificate is not valid, and when I ask for details he say => Certificat non fiable (in french, I'm not sure of the exact error syntax in english, but that's mean the certificate is unreliable).
The other client juste refuse to add the new account without any (usefull) explication.
I checked on SSLlabs and my certificate got an A and everything seems to be ok (and the website which share the same certificate is "secure" according to the browsers. (let's encrypt certificate)
I tried many things including
- rising the security by deactivate SSL v3.0 / TLS v1.0 and 1.1
- Update the TCP/IP Ports (25/110/143/465/993/995) with at least StartTLS (optional) for the SMTP 25 to SSL/TLS for SMTP/imap/pop3
- I disabled the RC4 on my server (my certificate was B on ssllabs before that)
- I checked the Ciphers, but the forum say to not touch that thing if we don't know what we are doing (and I don't :D)
- etc...
I also made the diagnostic, but... For me it's not helping :p
If you have any clue to help me to find the solution... Please don't hesitate ! ^^'
ps: nearly forgot...
My biggest fear is that I did something wrong when I extract the certificate and the private key to put them on HmailServer.
The private key is not encrypted that's good, but for the certificate.
Does it require a .pem or a .cer, and also, I heard about fullchain of the certificate that can be needed ? But I'm a bit lost with that.
2019-08-21   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - ocxxx.apx                      Enabled: True
                                                Private key: c:\program files (x86)\hmailserver\data\oppcar.fr\dkim.Domain1.com.pem
                                                Selector:    dkim
   "Domain2.com" - opxxxx.com                     Enabled: True
                                                Private key: c:\program files (x86)\hmailserver\data\oppcar.fr\dkim.Domain2.com.pem
                                                Selector:    dkim
   "Domain3.com" - opxxxx.fr                      Enabled: True
                                                Private key: c:\program files (x86)\hmailserver\data\Domain3.com\dkim.Domain3.com.pem
                                                Selector:    dkim
IP RANGES
IP: 185.110.132.155 - 185.110.132.155     Priority: 8000     Name: BAN -  ip-54-36-176
     SMTP:  False                              Antispam :  False
     POP3:  False                              Antivirus:  False
IP: 181.214.206.189 - 181.214.206.189     Priority: 20     Name: Auto-ban: hakui@oppcar.fr
IP: 181.214.206.190 - 181.214.206.190     Priority: 20     Name: Auto-ban: inga@oppcar.fr
IP: 181.214.206.148 - 181.214.206.148     Priority: 20     Name: Auto-ban: job@oppcar.fr
IP: 181.214.206.192 - 181.214.206.192     Priority: 20     Name: Auto-ban: martijn@oppcar.fr
IP: 181.214.206.144 - 181.214.206.144     Priority: 20     Name: Auto-ban: porsche@oppcar.fr
IP: 181.214.206.191 - 181.214.206.191     Priority: 20     Name: Auto-ban: stacie@oppcar.fr
IP: 93.2.139.196 - 93.2.139.196     Priority: 1     Name: Oppcar headquarter
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      5
                              Minutes to Autoban:         100000  (1 666,67 hours, 69,44 days)
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins: 15   Plain Text:         True  Bind:
                                               Max number commands: 100  Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 3    Use Spamassassin:   False
  Add X-HmailServer-Spam:     True    Check HELO host:    True - 2
  Add X-HmailServer-Reason:   True    Check MX records:   True - 2
  Add X-HmailServer-Subject: False    Verify DKIM:        True - 5
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   mail2.Domain3.com
       Certificate: C:\Admin\Cert\certoppcarletsencryptpublic.cer
       Private key: C:\Admin\Cert\certoppcarletsencryptprivate.pem
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :  False
             TLS 1.1 :  False
SslCipherList  :
               0.0.0.0         / 25    / SMTP   -   StartTLS Optional   Cert: mail2.Domain3.com
               0.0.0.0         / 110   / POP3   -   StartTLS Required   Cert: mail2.Domain3.com
               0.0.0.0         / 143   / IMAP   -   StartTLS Required   Cert: mail2.Domain3.com
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: mail2.Domain3.com
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: mail2.Domain3.com
               0.0.0.0         / 995   / POP3   -   SSL/TLS             Cert: mail2.Domain3.com
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-08-21.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-08-21.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\HmailBackup is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
[Settings]
DisableAUTHList=25
Generated by HMSSettingsDiagnostics v1.96, Hmailserver Forum.
Re: Problem with my certificate for the client
Post by Dravion » 2019-08-21 14:04
The common Problem for this type of Error is that your SSL-Certificate's Common name (CO) doesn't match your SMTP-Servers Fully Qualified Host name
provided by your DNS-Server.
To solve such an error, you need to create a new SSL-Certificate with matches exactly your SMTP-Servers Host and Domain name.
For example:
If your DNS hMailServers Host name is:
smtp.donaldduck.com
Than your SSL-Common name (CO) needs to be:
smtp.donaldduck.com
You cannot change your SSL-Certificate Common name if it is already issued, so be carefull
if you create a new SSL-Certificate.
PS:
Thunderbird and Outlook only accepting SSL-Certificate signed by a know, public Root CA.
Such a CA could be Verisign, Thwarte, Commodo etc. You buy a SSL-Certificate by an cheap CA it could happen
Outlook or Thunderbird doesn't recognize such Root CA's and this will result in Email SSL-Certificate Client Warning.
If you create your own, private CA, you can request and sign your SSL-Certificates by yourself, but in this case you need to Import your
Private CA's Root certificate into Windows Truststore (for Outlook) and in Mozilla's Trust Store (for Thunderbird) to satisfy the Certificate chain.
There are other Email Clients out there like TheBat! which doesn't has any Root CA what so ever included.
TheBat! will warn always for SSL-Certificates and your need to maintain a Root CA-List manually.
Too
Post by Too » 2019-08-21 14:54
Thank you for you answer Dravion.
In my case the smtp adress is not the common name but an alternative names and if I understand it well, that can be the problem. (the common name is for the www.)
If I create a new SSL certificate with smtp as common name and www. as an alternative name, that will be ok, or I can have the same kind of issue with the browsers ?
It's better to have a SSL certificate per "names" ? (sorry for that dummy question)
Also, regarding the last part of your answer, I tought let's encrypt was a trustfully source for "internet". It's not the case, just a basic thing (a little more than self signed ?)
I'm going to try the new SSl certificate thing, I will post here my results :)
Post by mattg » 2019-08-21 15:08
I have no trouble with Lets Encrypt certificates
Try to get one in the correct name
Too
Post by Too » 2019-08-21 16:12
Hi again guys !
It took me a little time but it's working, still not perfect but working !
I was able to add my account to Gmail / outlook, but for Gmail, the certificate was still "unreliable" (again, maybe not the real traduction I have the error in french).
So it's work (and my hair begin to grow again), but there is something I can do to be more thrustworthy for Gmail or not ? At first, I was on your side @mattg, but maybe it's because of let's encrypt like @Dravion suggested ?
Or something on my server like a protocole to deactivate or in the SSL certificate a little somthing I need to add / do ?
Anyway many thanks !
Post by Dravion » 2019-08-21 19:32
Too wrote:
2019-08-21 14:54
As an arlternative name, that will be ok, or I can have the same kind of issue with the browsers ?
Be carefull with this alernative Ommon Name thing.
It tested such SSL-Certificates multiple times but atleast
hMailServer 5.6.7 32 or 64-Bit builds with OpenSSL 1.0.2.x
or LibreSSL 2.9.x/3.x will cause Errors in hMailServer Main Error log and it cannot compute such SSL Certificstes.
Wildcard Certificates are working out ok, but alternative CO naming should theoretically work hMailServer 5.7
official built OprnSSL 1.1.x instead OpenSSL 1.0.2.x.
Post by mattg » 2019-08-22 01:07
There is some hints here
viewtopic.php?f=21&t=29763
Too
Post by Too » 2019-08-22 12:00
2019-08-22 01:07
Sorry, by Gmail, I meant the Gmail App, when I add my own account to received my Email on it.
The only one who put my email on the spam folder is Hotmail, but I already begin to do things for that (with the link you provide :p )
Dravion wrote:
2019-08-21 19:32
Ok noted thanks ! I made a separate certificate to be sure :).
jim.bus
Post by jim.bus » 2019-08-22 12:38
I use Let's Encrypt Certificates in my B2425 x86 32 bit hMailServer with no problem.
Let's Encrypt for my Certificate produces three files. I use the cert.pem file for the certificate file and privkey.pem for the private key file.
My hMailServer hostname is specified as a Subject Alternative Name (SAN) in the Let's Encrypt Certificate.
I have no trouble with Email Servers or Outlook accepting my Let's Encrypt Certificates used in hMailServer.
