C/C++ Unit Test's for hMailServer
Post by Dravion » 2019-08-04 21:22
This Topic will discuss hMailServers ongoing Unit Test procedures
For more informations about Unit Tests read: https://en.wikipedia.org/wiki/Test-driven_development
Goals of Unit Testing
*Unit testing improves the quality of the code; it identifies every defect which may have aroused, before code is sent further for integration testing.
*Since the bugs are found early in unit testing, it helps reducing the effort of later bug fixing.
*Unit Testing provides a basic Documentation for Developers to learn the code and understand the inner workings.
Popular Unit Test Frameworks
Google Test (stand alone, independent Unit Testing System
https://github.com/google/googletest/
Boost Test (comes with BOOST)
https://www.boost.org/doc/libs/1_70_0/l ... index.html
Stackoverflow discussion Google Test vs. BOOST Tests
https://stackoverflow.com/questions/477 ... -framework
Re: C/C++ Unit Test's for hMailServer
Post by martin » 2019-08-05 11:25
From what I've read Google Test seems to be the easiest to use, and it has a permissive license s i think we should try that one. I think we should just implement this on the master-branch and not in previous versions.
Martin Knafve
martin@hmailserver.com
https://twitter.com/knafve
Post by Dravion » 2019-08-05 12:10
Ok, i will start as soon as you pushed your latest comits to the master branch.
