hMail session corrupted
gestohlen_seele
Post by gestohlen_seele » 2019-07-29 23:51
Hello all, my first post so I apologize if this has been covered. I did search but didn't find anything.
My user is too smart for his own good and did something to corrupt the DB instance. In checking, it was throwing a COM exception and when I tried to go in there, it's now giving incorrect root password. I checked the hmailserver.ini and under the [SQL] area, the password field is blank with passwordencryption=1. I opened MySQL Workbench and it won't let me do anything with the instance until this root password issue is resolved.
Is that parameter correct for encryption? Wouldn't something (in this instance) be as simple as putting another hash in there for a new password?
If anyone has any tips on how to proceed with this, I would greatly appreciate it.
Re: hMail session corrupted
Post by mattg » 2019-07-30 00:14
Are you sure that this is a MySQL database being used
Please show the entire hMaislerver.ini (with passwords REMOVED)
gestohlen_seele
Post by gestohlen_seele » 2019-07-30 00:24
I'm sure it's MySQL, at least that's what it says in here and with the Workbench I try to open for the Session Manager.
ProgramFolder=C:\Program Files\hMailServer
DatabaseFolder=
DataFolder=C:\Program Files\hMailServer\Data
LogFolder=C:\Program Files\hMailServer\Logs
TempFolder=C:\Program Files\hMailServer\Temp
EventFolder=C:\Program Files\hMailServer\Events
[GUILanguages]
Type=MYSQL
Username=root
password=
Port=3306
Server=localhost
Database=hmailserver
Internal=0
[Security]
AdministratorPassword=
Post by mattg » 2019-07-30 01:22
Yep that's an external MySQL
Some versions of MySQL disabled the root password after a set period.
This 'feature' was later removed.
I recall that the fix was to change the date on the local machine - but perhaps check with MySQL support about a work around
The password stored in the hMailserver.ini is a hash, not the actual password
(Base64 encoded I think)
Post by Dravion » 2019-07-30 03:45
Instructions howto setup a new DB-Password in hMailServer.ini (NOT hMailServer Administrator Password).
https://www.hmailserver.com/forum/viewt ... 21&t=33793
