No results in Outlook 2019
gtsolid
Post by gtsolid » 2019-05-27 21:39
Hi everyone!
i just installed Office 2019. In outlook i configured both an hotmail and my hmail account.
The mail can be sent and received, but with the latter i can't mach researches.
i will get the situation attached.
i think it's fully configured, what can i do?
Re: No results in Outlook 2019
Post by mattg » 2019-05-28 00:51
Outlook uses windows search to create indexes, leave it running a while (at least overnight) and try again
gtsolid
Post by gtsolid » 2019-05-28 06:19
Thank you, i'll try this.
I notice that i have many sent mail folders: from Outlook, from Android, from the laptop's Outlook, ecc...
Is there any way to put all together?
Post by mattg » 2019-05-28 06:22
Sure you can merge sent folders, or just move all of the contents of one into the the other, then delete the empty one
You should change the settings in each mail client so that this doesn't happen again though.
