Read headers from .eml on disk
cblaze22
Post by cblaze22 » 2019-05-08 14:00
How can I load a .eml from disk and read the headers of it? I am trying to do this in the OnDeliverMessage method.
Re: Read headers from .eml on disk
Post by mattg » 2019-05-08 14:04
Try this
	For i = 1 To oMessage.Headers.Count
		txt = "Message Subject is: " & oMessage.Subject & "   Header #" & i & " name is: " & oMessage.Headers.Item(i-1).Name
		txt = txt & " value is: " & oMessage.Headers.Item(i-1).Value
		EventLog.write txt
	Next 'i
Post by SorenR » 2019-05-08 14:23
2019-05-08 14:04
Try this
		EventLog.write txt
	Next 'i
That's not what he want...
He want us to write the code to read the eml file (from oApp.status.UndeliveredMessages) from .\hmailserver\data so that he can prioritize his emails...
I think you should merge ALL of his posts regarding this topic into one new thread and if he keeps creating new threads ... a mild BAN might be in order. He's all over the forum.
Fellow says he's a programmer and yet he is still clueless despite us trying to explain how ends meet inside hMailServer.
Oh and cblaze22... OnDeliverMessage is NOT a method... It's a TRIGGER
Actions handled by OnDeliverMessage based from the list (oApp.status.UndeliveredMessages) will affect all BUT THE ACTUAL message. When OnDeliverMessage is triggered the message triggering OnDeliverMessage is NOT YET in the queue. So, the functionality will always be one message behind the current.
cblaze22
Post by cblaze22 » 2019-05-08 15:09
This is a totally seperate question. If someone else wants to do a read of a file from disk and read the header, this email will come up. This is not being all over the place, but a distinct question. Yes I will take this answer and merge it into the other code we are working on. However, this question should be taken in context as distinct and could help someone in the future.
"Fellow says he's a programmer and yet he is still clueless despite us trying to explain how ends meet inside hMailServer." makes no sense. Being a programmer doesnt follow necessarily you know how a program works off hand or can read between the lines on incomplete documentation. Come on man. Also a TRIGGER in a broad sense is a METHOD, geez.
I know OnDeliverMessage does that, did I say otherwise? Please stick to our thread, this one is about reading a file from disk and reviewing the headers. You are the one all over the place and I believe a mild ban should be put in place.
Post by SorenR » 2019-05-08 15:53
Well... I'm a genius...
Dim a, b, i, Match, Matches, Done, oMail
Call oApp.Authenticate("Administrator", "BIG SECRET")
Done = False
Do Until Done
   '   List all messages in queue
   Matches = Split(oApp.status.UndeliveredMessages, vbNewLine)
   For Each Match in Matches
      WScript.Echo "**********"
      WScript.Echo Match
      WScript.Echo ""
      '   Fields are TAB delimited
      b = Split(Match, vbTab)
      For Each a in b
         WScript.Echo a
      WScript.Echo ""
      '   Create dummy message to hold current queued message
      Set oMail = CreateObject("hMailServer.Message")
      '   Copy queued message into dummy message and reload
      strFilename = oMail.Filename
         .CopyFile b(5), strFilename, True
      oMail.RefreshContent
      '   Voila! List all headers
      For i = 0 To oMail.Headers.Count-1
         WScript.Echo Right("0" & i, 2) & " " & oMail.Headers(i).Name & ": " & oMail.Headers(i).Value
      WScript.Echo ""
      '   !!! WARNING !!! DO NOT SAVE MESSAGE !!!
      '   oMail.Save
      Set oMail = Nothing
   WScript.Sleep(1000)
   Done = True
Loop
WScript.Quit 0
Code runs in a CMD window on the server.
cblaze22
Post by cblaze22 » 2019-05-08 16:21
Yes you certainly are. Lets continue this in our main thread on this, this handles the reading headers from file on disk
