Get status code of error message
cblaze22
Post by cblaze22 » 2019-05-05 04:01
Is there a strongly typed way to get the status code of a bounced email from?
   Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
I know I can parse the message below but thought there was an easier way. Also if I had to parse the string what is [nl]?
"Error Type: SMTP[nl] Remote server (35.173.65.153) issued an error.[nl] hMailServer sent: [nl] Remote server replied: 421 spr-ibgw-5001a.stratus.cloudmark.com cmsmtp SMTP server not available AUP#1330[nl]"
Re: Get status code of error message
Post by mattg » 2019-05-05 04:13
nl = New Line
OnDeliveryFailed is only for incoming messages that accepted by hMailserver
It fires for me ONLY when a global rule deletes a message
cblaze22
Post by cblaze22 » 2019-05-05 05:03
Sorry I am not following these comments
Post by mattg » 2019-05-05 09:08
OnDeliveryFailed (the sub you referenced) is only for mail being sent to your hmailserver, it is not for messages that get bounced by other servers.
I suspect that you are wanting to track messages that are bounced by other servers.
The ONLY way that you can do is by parsing the log files
cblaze22
Post by cblaze22 » 2019-05-05 15:35
Are you sure about this?
We received this message below in our logs from that method. That seems like a message from a delivery fail?
Post by mattg » 2019-05-06 02:05
How do you know that it came from that method?
cblaze22
Post by cblaze22 » 2019-05-06 02:55
Cause I wrote it?????????
EventLog.Write(sErrorMessage)
Post by mattg » 2019-05-06 03:33
You are correct
I just forced the same message to fail, and it did log for me too. I obviously don't have many failures, I couldn't find one so far this month when I looked earlier.
Mine logged
2019-05-06 11:28:47.371  OnDeliveryFailed:- test   matt@example.com   sdsfjkld@jhfjksfyjdsyjhg.com   Error Type: SMTP
   Error Description: No mail servers appear to exists for the recipient's address.
   Additional information: Please check that you have not misspelled the recipient's email address.
