one IP, one domain problem
jahixogicu
Post by jahixogicu » 2019-05-02 19:54
I'm using hmail for few years without any bif problems,
but from today, I domain Account from 1 IP adress stop work,
from other IP, it works, another service on same machine works, if I set Hmail to port that another service work, hmail not
if I try telnet to hmail, it reject connection.
Have you any info, what can be wrong, nothing changed, it start from hour to hour.
jahixogicu
Re: one IP, one domain problem
Post by jahixogicu » 2019-05-02 21:19
in the log, there is this record:
"TCPIP" 5196 "2019-05-02 09:03:57.719" "TCP - YYY.YYY.YYY.YYY connected to XXX.XXX.XXX.XXX:143."
Post by mattg » 2019-05-02 23:38
Check your autoban entries...
Also we would need more of the log please, but it is possible that new infrastructure at the other end s causing this, a new router or modem or even antivirus at the client end of that connection
jahixogicu
Post by jahixogicu » 2019-05-03 11:16
autobans are OK,
but i discover there is not trouble only with on IP but hmail rejecting other servers when delivering messages and some clients too.
interesting is, something arrive, something is returned with hmail closes connection
Post by mattg » 2019-05-03 11:21
Please run this and post the results >> viewtopic.php?f=20&t=30914
Also please include a few minutes of your logs (ensure that all logging is enabled and that there are some messages being rejected in the logs)
jahixogicu
Post by jahixogicu » 2019-05-03 11:28
Hello mattg,
problem is, there are not any log,
connection is cut at the moment of connection,
only log is like this:
Post by mattg » 2019-05-04 01:37
If you have all logging enabled and there is no logs then something else is blocking the connection
Either hardware 'inspecting' mail, or antivirus
