Howto: Reset your hMailServer.in DB-Password
Post by Dravion » 2019-04-13 02:23
If you need to reset your hMailServer.ini DB-Password, use the utility attached below or download the Source code from Github
and compile it yourself.
How to use it:
01) Unzip and start hDBHasher.exe by doublelick
02) Type in your new Password in the field "New DB-Password"
03) Click Generate
04) Select and copy (STRG+C) the values in "Generated DB-Password hash"
05) Paste the copied value into hMailserver.ini after Password=
06) Login to your DB-Server and change your hMailServer DB-User Password to the same Password as shown in "New DB-Password
07) Stop/Start/Restart hMailServer Windows Server
08) Login into hMailServerAdmin with your old hMailServer Adminpassword, not your DB-Users Password
Step 1
Step 2
hDBHasher Download
https://github.com/Dravion/hDBHasher/re ... ag/1.0.0.1
Luna Moon
Re: Howto: Reset your hMailServer.in DB-Password
Post by Luna Moon » 2019-05-05 09:35
Oh, thank you for the step-by-step. Now it can't go wrong anymore. Really thank you for taking the time to post something like this. It's helping a beginner like me a lot! :)
Post by Dravion » 2019-05-05 11:13
Your welcome :D
