Route for Distribution List
Monarch75
Post by Monarch75 » 2019-03-29 11:29
Hi...
does anyone know how to configure hmail in a way that it uses a certain smtp-server (route) to send out mails to external emailsadresses configured in a distribution list?
Re: Route for Distribution List
Post by katip » 2019-03-29 13:14
why would you like to send out bulk mail via an SMTP server other then that in your SMTP setup?
solution is easy but first your answer pls.
Monarch75
Post by Monarch75 » 2019-03-29 13:33
The SMTP-Server configured as SMTP Relayer (smtp.gmail.com) replaces the outgoing-emailAdress with the one that is associated with the gmail-account. Thats ok for most cases. But if I want to send out mails to email-adresses configured in certain distribution list, I want hmail to route the mails through a smtp-server that does not do it.
Post by katip » 2019-03-29 14:18
i understand that you already have access to a decent SMTP service.
i'd suggest you use it as your default SMTP relayer instead of Google. so you won't need to route anything.
about the other workaround i prefer to stay noncommittal. one of the mods may or may not offer other solutions.
Monarch75
Post by Monarch75 » 2019-03-29 14:39
Thank you for your time, but thats not what I want.
tunis
Post by tunis » 2019-06-13 08:27
I don't use distribution list but you might use global rule.
I have setup a route based on sender.
Criteria
Use AND
From Contains test@domain.com
To Not contains @domain.com
Actions
Send using route NameOfYourRoute
Post by mattg » 2019-06-13 10:22
I think just a plain SMTP route would achieve the planned objective
