Messages in data folder not delivered
bmanager
Post by bmanager » 2019-03-22 13:18
Hi all,
a mailbox account has been compromised and used from spammer to send out thousands of messages.
I blocked the queue, disabled the account, removed .eml messages from the data root.
Now, I isolated spam from others real messages, and restored them into the data root.
But these real messages are till in the data root and are not delivered to their respective recipients.
Is there something wrong on this? Can I eventually do something to let HMS deliver those messages?
Thanks in advance.
Re: Messages in data folder not delivered
Post by mattg » 2019-03-22 13:43
Have you tried restarting the server?
Sometimes that forces the messages to be picked up
Alternately install thunbderbird on machine with hMailserver, and point SMTP to localhost, and allow all without AUTH for 127.0.01 in IP ranges
Then open the messages in Thunderbird and 'send'
bmanager
Post by bmanager » 2019-03-22 13:54
Hi Matt,
thank for your reply.
Do you mean click on "Pause" / "Resume" button on the server status page?
Or completly restart the server (window server)?
I didnt understand the solution involving Thunderbird..
Post by mattg » 2019-03-22 13:59
Completely restart the windows server
The idea behind the thunderbird thing is just to present the emails as new messages to the server (delivered via SMTP)
How many such messages do you have?
bmanager
Post by bmanager » 2019-03-22 14:17
About 200 messages
bmanager
Post by bmanager » 2019-03-22 16:56
I restarted the server but nothing changed. Please see the attached pic.
Post by mattg » 2019-03-23 00:26
You will need some way to get these messages back into the hMailserver queue...
If you have access to IIS SMTP set that up with a smart host pointing to your hMailserver, and move all of the messages to the pickup folder for IIS SMTP.
Or you will need to install a mail client client like thunderbird on the same machine, configured to use the local machine instance of hMailserver, with hmailserver allowing all connections without AUTH from the localhost IP address in IP ranges, and then OPEN each individual message in hMailserver, and then 'send'
bmanager
Post by bmanager » 2019-03-23 13:08
petersmith69 wrote:
2019-03-23 00:38
try changing your mail id
i believe this is never ending loop of the spammers.
hope you could get rid of the spammers
Him
what do you mean with "try changing your mail id"? Which mail ID?
bmanager
Post by bmanager » 2019-03-23 13:19
2019-03-23 00:26
Sure. But any idea why HMS doesn't pick them up?
2019-03-23 00:26
Any link to a kind of tutorial?
2019-03-23 00:26
I just installed thunderbird, but it does require to configure a mail account and then, if I open a message, thunderbird propose to the send it from the configured account
Thanks Matt
bmanager
Post by bmanager » 2019-03-23 14:00
2019-03-23 00:26
Hi Matt,
I Just configured IIS SMTP (using IIS 6.0 Manager) moved some message to pickup folder, but nothing happened.
IIS SMTP is running on port 26 (HMS is running on port 25).
As i paste a .eml file to pickup folder, this disappear but there's no track on HMS database.
HMS is configured to accept connections from local IP (127.0.0.1).
IIS STMP > Advanced delivery > Smart host: localhost
Any idea?
bmanager
Post by bmanager » 2019-03-23 14:17
But, how is possible that HSM doesn't pick messeges from the data root folder?
If I look in this folder, I can see incoming messages for few instants that are correctly delivered, but messages moved out from this folder and then restored in the same folder without any kind of change are completly ignored.
Please help if you can, thanks.
Post by SorenR » 2019-03-23 14:34
bmanager wrote:
2019-03-23 14:17
That's because all handling is done in memory. The data directory is simply "raw storage".
Using TB or IIS is simply a way to inject old messages into hMailServer.
"message id" I suspect is the header "Message-ID:" and this header value is a unique constraint in hMailServer database. By simply adding a "2" ...
Example:
Message-ID: <708372916.5376819.1482214130995.JavaMail.app@lva1-app8963.prod.linkedin.com>
change to
Message-ID: <2.708372916.5376819.1482214130995.JavaMail.app@lva1-app8963.prod.linkedin.com>
will make the email unknown to hMailServer and hMailServer should process the message as new using any of the options mentioned earlier.
bmanager
Post by bmanager » 2019-03-23 16:00
Hi SorenR,
i tried to open a couple of .eml messages in the root folder and edit the line
Message-ID: <11534694034987814944@google.com>
as
Message-ID: <2.11534694034987814944@google.com>
But nothing changed.
Isn't there a function to import messages to HMS?
Regards
bmanager
Post by bmanager » 2019-03-23 16:35
I'm using Data directory synchronizer (https://www.hmailserver.com/documentati ... rguide_dds) and seems that it's going to solve partially the problem...
It looks like if doesn't import .eml fetched from external mail accounts, can someone confirm that?
Post by SorenR » 2019-03-23 17:08
I just remembered something... Not sure if it still works but here goes...
https://www.hmailserver.com/forum/viewt ... 15#p166615 and onwards. :mrgreen:
Post by mattg » 2019-03-24 03:31
bmanager wrote:
2019-03-23 14:00
The .eml file disappearing is it being being picked up, ready to send
Check your smart host settings in IIS, ensuring that it points back to the local hMailserver.
