How to secure my email from spam?
johndvd122
Post by johndvd122 » 2019-03-11 10:23
How to avoid getting spam emails through contact form in Website?
jim.bus
Re: How to secure my email from spam?
Post by jim.bus » 2019-03-11 11:03
I am not one of the hMailServer gurus on this forum but I set up SPAM protection with my hMailServer installation.
Not knowing exactly what you are referring to in your inquiry. I am assuming you have submitted a contact form email on a website and wish to avoid any SPAM which might come from the website the contact form was submitted to.
I would recommend you get into hMailAdmin and look for Anti-spam under Settings and select expand it by clicking on the + sign next to it.
Then look at the options you have showing. You can find out how they work by clicking on the Help facility for each setting option when you open the option and reading the Help information. There are Blacklist databases, Greylisting settings, and White listing settings. Under Greylisting option there is another White list option. The two White listing settings function slightly differently. One White lists IP Addresses. The other White lists Email IDs or Domains. The Help facility explains how to use these White lists.
This is how I discovered how to use hMailServer's Anti-spam features.
Post by mattg » 2019-03-11 11:05
I would spam filters on your website, including a captcha
Google's recaptcha is free and works really well
what web platform do you run??
Post by jimimaseye » 2019-03-11 13:01
I suspect poster "john" from India might soon have a solution to this 'problem' and will be offering to us any time soon (with a nice web link).
abdrahim999
Post by abdrahim999 » 2019-03-12 00:27
you can use API or NGINX Web Application Firewall
or you can check the ip adresse of the spammer just check google
Reason: link removed as per forum policy
