Able to send mail outside but can't receive mail from outside
picho
Post by picho » 2019-02-19 15:59
Hullo Experts,
I am having trouble with my hmail server installation, ever since I set it up and I ran the diagnostics on my hmailserver setup and it passed the diagnostics successfully.
I am able to send emails out to external accounts and they are received but when I try to send emails to accounts hosted on my hmailserver, they never come through,
what could be the problem, I would be glad to receive your assistance because it is quite urgent
thx,
picho
picho
Re: Able to send mail outside but can't receive mail from outside
Post by picho » 2019-02-19 17:00
Hullo experts more information on the problem I am facing
The error message I get when I try sending to my hmailserver account from gmail is
"the recipient server did not accept our requests to connect: gnereic:: failed_precondition: connect error (111) : Connection refused)
This bounced message appeared the following day after trying to reply to an email I sent from my hmailserver account to my gmail account
Post by palinka » 2019-02-19 17:07
Connection refused
  • Your ISP blocks port 25 incoming
  • Your LAN firewall is blocking port 25 incoming
  • Your server's software firewall is blocking port 25 incoming
  • Some other software is blocking or using port 25 incoming
Something in between gmail and hmailserver is blocking your incoming connection on port 25.
picho
Post by picho » 2019-02-19 18:19
Hullo Palinka,
My ISP allows incoming and outgoing port 25 on firewall
My windows server firewall allows both incoming and outgoing port 25 traffic
I have no LAN firewall
The router is configured to allow all traffic.
And I don't have any software using port 25
I really don't know what is blocking the traffic
Post by palinka » 2019-02-19 23:02
picho wrote:
2019-02-19 18:19
Hullo Palinka,
Are you sure your mx records point to your hmailserver?
Post by mattg » 2019-02-20 02:44
Does your router forward mail ports to your hMailserver?
https://www.hmailserver.com/documentati ... om_outside
picho
Post by picho » 2019-02-20 08:42
Yes Mattg,
The technician who set up the cisco 1841 router opened up all ports on the router and therefore the router is not restricting any traffic, the configuration is as below:
Current configuration : 3208 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname UDC-ROUTER
boot-start-marker
boot-end-marker
enable secret 5 $1$pZit$oUTB7tVwuND03QwahkEYO1
aaa new-model
aaa session-id common
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.150.1 192.168.150.10
ip dhcp pool Voice
ip dhcp pool Lan
network 192.168.150.0 255.255.255.0
default-router 192.168.150.4
domain-name write
ip dhcp pool servers
network 192.168.0.0 255.255.255.0
default-router 192.168.0.7
domain-name write
ip dhcp pool cctv
network 192.168.110.0 255.255.255.0
default-router 192.168.110.254
ip dhcp pool user_data
network 192.168.120.0 255.255.255.0
default-router 192.168.120.254
dns-server 41.221.81.132 197.221.148.22
domain-name write
ip dhcp pool voice
network 192.168.130.0 255.255.255.0
default-router 192.168.130.254
ip dhcp pool corperate_wifi
network 192.168.140.0 255.255.255.0
default-router 192.168.140.254
domain-name write
no ip domain lookup
ip domain name udc.go.ug
ip name-server 41.221.81.132
ip name-server 197.221.148.22
multilink bundle-name authenticated
username local privilege 15 secret 5 $1$kbwp$kNdX6qn8eAAF7WkT2XQDC0
archive
log config
hidekeys
interface FastEthernet0/0
ip address 41.221.91.26 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.150.4 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
description sub_servers
encapsulation dot1Q 10
ip address 192.168.0.7 255.255.255.0
interface FastEthernet0/1.2
description sub_cctv
encapsulation dot1Q 110
ip address 192.168.110.254 255.255.255.0
interface FastEthernet0/1.3
description sub_user_data
encapsulation dot1Q 120
ip address 192.168.120.254 255.255.255.0
interface FastEthernet0/1.4
description sub_voice
encapsulation dot1Q 130
ip address 192.168.130.254 255.255.255.0
interface FastEthernet0/1.5
description sub_corperate_wifi
encapsulation dot1Q 140
ip address 192.168.140.254 255.255.255.0
ip default-gateway 41.221.91.25
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 41.221.91.25
no ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source list 2 interface FastEthernet0/0 overload
ip nat inside source list 3 interface FastEthernet0/0 overload
ip nat inside source list 4 interface FastEthernet0/0 overload
ip nat inside source list 5 interface FastEthernet0/0 overload
ip nat inside source list 6 interface FastEthernet0/0 overload
ip nat inside source list 7 interface FastEthernet0/0 overload
access-list 1 permit 192.168.150.0 0.0.0.255
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 3 permit 192.168.110.0 0.0.0.255
access-list 4 permit 192.168.120.0 0.0.0.255
access-list 5 permit 192.168.130.0 0.0.0.255
access-list 6 permit 192.168.140.0 0.0.0.255
access-list 7 permit 192.168.160.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
transport input all
scheduler allocate 20000 1000
end
The router public IP is 41.221.91.26 and you can see that NAT has been enabled, my hmailserver IP on the LAN is 192.168.150.13
So I can't figure out what could be blocking the mails
Post by jimimaseye » 2019-02-20 09:56
That router configuration list doesnt show anything that proves port forwarding is set. It only shows that the internal LAN ip ranges have access to send OUT.
You need port forwarding FROM OUTSIDE forwarding to your hmailserver.
Post by mattg » 2019-02-20 10:25
And port forwarding is different than opening ports
picho
Post by picho » 2019-02-20 10:29
Thank you Jimmisaye,
Will contact the technician to configure the router to enable port forwarding so that mails can come through,
will post an update when this is done,
thanks,
Post by SorenR » 2019-02-20 15:58
You would need something like ...
static (inside,outside) tcp interface smtp 192.168.0.50 smtp netmask 255.255.255.255
static (inside,outside) tcp interface imap4 192.168.0.50 imap4 netmask 255.255.255.255
It's from my (very) old Cisco ASA5505 however it may not fit your 1841... Time to dig out the IOS manual for your router.
