Vendor cannot connect via SSL
wankel
Post by wankel » 2019-02-12 18:21
Hello all,
I'm having a unique problem.
I have a vendor that needs to connect to my hmailserver to relay using SSL/TLS via port 587 but is unable to connect. Basically the hand shake fails.
It also fails in port 25 using STARTTLS required.
Here is my error in the logs..
TCPConnection - TLS/SSL handshake failed. Session Id: 261, Remote IP: xxx.xxx.xxx.xxx, Error code: 335544539, Message: short read"
They error on their side is:
SOCKET_ERROR: 10060 A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond ;cmd=
We have connect with no issues using plaintext smtp.
I have also tested using a mail client from the outside and also using https://www.checktls.com/TestReceiver to test and no issues.
This could be an issue with their smtp server but I want to research everything on my side.
Could this be an issue with the ciphers that are declared in the hmailserver by default?
Re: Vendor cannot connect via SSL
Post by Dravion » 2019-02-12 18:31
Winsock 10060 is a Timeout Error.
It simply means TCP packets flow is disturbed and TCP RST Restransmits has reached its threshold.
Check with Ping and see if you have Packetloss at pinging to your TCP destination.
wankel
Post by wankel » 2019-02-12 19:37
I will have to open ICMP in the firewall and test..
Post by mattg » 2019-02-12 22:11
you should not have StartTLS Required for port 25
Port 25 should be StartTLS optional
This is a fault with the other end of the connection, in that their machine can't negotiate your SSL / STartTLS connections, either they don't support a TLS version that you require, or they don't have a suitable common cipher,, OR the other machine doesn't do StartTLS
If you need further help Run this and post the results back >> http://www.hmailserver.com/forum/viewto ... 20&t=30914
Also enable all logging, force the connection, wait for at least two minutes or until the connection is closed and include all logs created
wankel
Post by wankel » 2019-02-13 19:24
I have added the additional cipher that the vendor had and I was missing..
Still have the problem.
I'm using hmailserver for special cases to just relay mail and the password encrypted.
Here is my report logs. As much logs as the app is giving..
"DEBUG"	2404	"2019-02-13 12:02:49.145"	"Creating session 3"
"TCPIP"	2404	"2019-02-13 12:02:49.145"	"TCP - 18.208.xxx.xxx connected to 10.xx.xx.xxx:587."
"DEBUG"	2404	"2019-02-13 12:02:49.145"	"TCP connection started for session 2"
"DEBUG"	2404	"2019-02-13 12:02:49.145"	"Performing SSL/TLS handshake for session 2. Verify certificate: False"
"DEBUG"	2404	"2019-02-13 12:03:47.756"	"Creating session 4"
"TCPIP"	2404	"2019-02-13 12:03:47.756"	"TCP - 18.208.xxx.xxx connected to 10.xx.xx.xxx:587."
"DEBUG"	2404	"2019-02-13 12:03:47.756"	"TCP connection started for session 3"
"DEBUG"	2404	"2019-02-13 12:03:47.756"	"Performing SSL/TLS handshake for session 3. Verify certificate: False"
"TCPIP"	2404	"2019-02-13 12:07:50.046"	"TCPConnection - TLS/SSL handshake failed. Session Id: 2, Remote IP: 18.208.xxx.xxx, Error code: 335544539, Message: short read"
"DEBUG"	2404	"2019-02-13 12:07:50.061"	"Ending session 2"
Here is my report
2019-02-13   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - roxxxxxxxxxx                   Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
IP: 18.208.xxx.xxx - 18.208.xxx.xxx     Priority: 30     Name: ProEd
     POP3:  False                              Antivirus:  False
     IMAP:  False                              SSL/TLS:     True
     Local To Local       - False
     Local To External    - False
     External To Local    - False
IP: 10.XX.XX.XXX - 10.XX.XX.XXX     Priority: 25     Name: testboxtools
IP: 159.89.187.50 - 159.89.187.50     Priority: 20     Name: checktls
IP: 204.XX.XX.XXX - 204.XX.XX.XXX     Priority: 15     Name: ExternalTestSite
IP: 10.XX.X.XXX - 10.XX.X.XXX     Priority: 10     Name: MyComputer
IP: 127.0.0.1 - 127.0.0.1     Priority: 5     Name: Localhost
     POP3:   True !! Protocol DISABLED !!      Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
     IMAP:   True !! Protocol DISABLED !!      SSL/TLS:    False
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries: 10 Mins: 30   Plain Text:        False  Bind:
                     Port:  25                                           Loop limit:           5
                     Req Auth: False                                     Recipient hosts:     15
                     Con. Sec.: None
  Routes:
     No routes defined.
POP3
 !! Service Not Enabled !!
IMAP
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   eforwarder
       Certificate: d:\certs\eforwarder.crt
       Private key: d:\certs\eforwarder.key
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
             TLS 1.2 :   True                Verify Remote SSL/TLS Certs:  False
SslCipherList  :
TLS_ECDHE_ECDSA_WITH_AES_256_GCM- TLS_ECDHE_ECDSA_WITH_AES_128_GCM- TLS_ECDHE_RSA_WITH_AES_256_GCM_S
TLS_ECDHE_RSA_WITH_AES_128_GCM_S- TLS_DHE_RSA_WITH_AES_256_GCM_SHA- TLS_DHE_RSA_WITH_AES_128_GCM_SHA
TLS_ECDHE_ECDSA_WITH_AES_256_CBC- TLS_ECDHE_ECDSA_WITH_AES_128_CBC- TLS_ECDHE_RSA_WITH_AES_256_CBC_S
TLS_ECDHE_RSA_WITH_AES_128_CBC_S- TLS_ECDHE_ECDSA_WITH_AES_256_CBC- TLS_ECDHE_ECDSA_WITH_AES_128_CBC
TLS_ECDHE_RSA_WITH_AES_256_CBC_S- TLS_ECDHE_RSA_WITH_AES_128_CBC_S- TLS_DHE_RSA_WITH_AES_256_CBC_SHA
TLS_DHE_RSA_WITH_AES_128_CBC_SHA- TLS_RSA_WITH_AES_256_GCM_SHA384 - TLS_RSA_WITH_AES_128_GCM_SHA256
TLS_RSA_WITH_AES_256_CBC_SHA256 - TLS_RSA_WITH_AES_128_CBC_SHA256 - TLS_RSA_WITH_AES_256_CBC_SHA
TLS_RSA_WITH_AES_128_CBC_SHA    - TLS_RSA_WITH_3DES_EDE_CBC_SHA   - TLS_DHE_DSS_WITH_AES_256_CBC_SHA
TLS_DHE_DSS_WITH_AES_128_CBC_SHA- TLS_DHE_DSS_WITH_AES_256_CBC_SHA- TLS_DHE_DSS_WITH_AES_128_CBC_SHA
TLS_DHE_DSS_WITH_3DES_EDE_CBC_SH- TLS_RSA_WITH_RC4_128_SHA        - TLS_RSA_WITH_RC4_128_MD5
TLS_RSA_WITH_NULL_SHA256        - TLS_RSA_WITH_NULL_SHA           - ECDHE-RSA-AES128-GCM-SHA256
ECDHE-ECDSA-AES128-GCM-SHA256   - ECDHE-RSA-AES256-GCM-SHA384     - ECDHE-ECDSA-AES256-GCM-SHA384
DHE-RSA-AES128-GCM-SHA256       - DHE-DSS-AES128-GCM-SHA256       - kEDH+AESGCM
ECDHE-RSA-AES128-SHA256         - ECDHE-ECDSA-AES128-SHA256       - ECDHE-RSA-AES128-SHA
ECDHE-ECDSA-AES128-SHA          - ECDHE-RSA-AES256-SHA384         - ECDHE-ECDSA-AES256-SHA384
ECDHE-RSA-AES256-SHA            - ECDHE-ECDSA-AES256-SHA          - DHE-RSA-AES128-SHA256
DHE-RSA-AES128-SHA              - DHE-DSS-AES128-SHA256           - DHE-RSA-AES256-SHA256
DHE-DSS-AES256-SHA              - DHE-RSA-AES256-SHA              - AES128-GCM-SHA256
AES256-GCM-SHA384               - ECDHE-RSA-RC4-SHA               - ECDHE-ECDSA-RC4-SHA
AES128                          - AES256                          - RC4-SHA
HIGH                            - !aNULL                          - !eNULL
!EXPORT                         - !DES                            - !3DES
!MD5                            - !PSK;
               0.0.0.0         / 587   / SMTP   -   SSL/TLS             Cert: eforwarder
  Paths:-
    Current:  D:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-02-13.log
    Error:    D:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-02-13.log - !! ERRORS PRESENT !!
    Event:    D:\Program Files (x86)\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  D:\Program Files (x86)\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Program folder:  D:\Program Files (x86)\hMailServer\
Database folder: D:\Program Files (x86)\hMailServer\Database
Data folder:     D:\Program Files (x86)\hMailServer\Data
Log folder:      D:\Program Files (x86)\hMailServer\Logs
Temp folder:     D:\Program Files (x86)\hMailServer\Temp
Event folder:    D:\Program Files (x86)\hMailServer\Events
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
wankel
Post by wankel » 2019-02-13 19:34
So this start to work using StartTLS optional but wouldn't that downgrade to standard plain text if it fails?
Should I be using port 465 with SSL only?
Post by Dravion » 2019-02-13 20:35
wankel wrote:
2019-02-13 19:34
Yes.
And thats completely ok for Port 25.
If this where not the case than all unencrypted arriving Emails would be dropped with or without notification of the sender.
Thats a complete diffrent debatte.
465 as well as 587 SMTP is for sending Emails from Your Outlook or Thunderbird App to hMaiServer while Port 25 is for Mailserver to other Mailserver communication.
Post by mattg » 2019-02-13 23:24
However the 'standard' is that port 587 is StartTLS required, and that port 465 (where used) is SSL
The difference being
SSL negotiates the security of the connection in the first instance immediately when trying to connect
StartTLS makes the connection, and then sets the security before any usernames or passwords are exchanged
