[PHPMailer] Unable to send mail
NivekLR
Post by NivekLR » 2019-02-09 00:19
Hello to all,
I have installed and configured hMailServer.
I have tried it by roundcube webmail with success for internal and external addresses.
I have configured a PHP script that use PHPMailer to sent mails but the mail never been sent.
The hMailServer Logs show :
"DEBUG"	14328	"2019-02-08 23:00:54.242"	"TCP connection started for session 16"
"SMTPD"	14328	16	"2019-02-08 23:00:54.242"	"127.0.0.1"	"SENT: 220 mail.klr-services.ovh ESMTP"
"SMTPD"	5600	16	"2019-02-08 23:00:54.242"	"127.0.0.1"	"RECEIVED: EHLO www.klr-services.ovh"
"SMTPD"	5600	16	"2019-02-08 23:00:54.242"	"127.0.0.1"	"SENT: 250-mail.klr-services.ovh[nl]250-SIZE 20480000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	5644	16	"2019-02-08 23:00:54.242"	"127.0.0.1"	"RECEIVED: STARTTLS"
"SMTPD"	5644	16	"2019-02-08 23:00:54.242"	"127.0.0.1"	"SENT: 220 Ready to start TLS"
"DEBUG"	14328	"2019-02-08 23:00:54.242"	"Performing SSL/TLS handshake for session 16. Verify certificate: False"
"TCPIP"	5600	"2019-02-08 23:05:54.254"	"TCPConnection - TLS/SSL handshake failed. Session Id: 16, Remote IP: 127.0.0.1, Error code: 335544539, Message: short read"
"DEBUG"	5600	"2019-02-08 23:05:54.254"	"Ending session 16"
I noticed that the error is normal because I have stopped the page loading.
This is my hMailServer report :
2019-02-08   Hmailserver: 5.6.7-B2427
DOMAINS
   "Domain1.com" - klxxxxxxxxxx.ovx               Enabled: True
                                                Private key: d:\wampserver\cert-auth\ca\intermediate\private\dkim.Domain1.com.pkey.pem
                                                Selector:    dkim
IP RANGES
IP: 127.0.0.1 - 127.0.0.1     Priority: 30     Name: My computer
     POP3:  False                              Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries: 10 Mins: 60   Plain Text:        False  Bind: 192.168.1.30
                     Port: 587                                           Loop limit:           5
                     Con. Sec.: StartTLS Required
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   IMAP
       Certificate: D:\WAMPServer\ssl\ca\intermediate\certs\imap.Domain1.com.cert.pem
       Private key: D:\WAMPServer\ssl\ca\intermediate\private\imap.Domain1.com.pkey.pem
   POP
       Certificate: D:\WAMPServer\ssl\ca\intermediate\certs\pop.Domain1.com.cert.pem
       Private key: D:\WAMPServer\ssl\ca\intermediate\private\pop.Domain1.com.pkey.pem
   SMTP
       Certificate: D:\WAMPServer\ssl\ca\intermediate\certs\smtp.Domain1.com.cert.pem
       Private key: D:\WAMPServer\ssl\ca\intermediate\private\smtp.Domain1.com.pkey.pem
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
             TLS 1.2 :   True                Verify Remote SSL/TLS Certs:  False
SslCipherList  :
               0.0.0.0         / 587   / SMTP   -   StartTLS Required   Cert: SMTP
               0.0.0.0         / 993   / IMAP   -   StartTLS Required   Cert: IMAP
               0.0.0.0         / 995   / POP3   -   StartTLS Required   Cert: POP
  Paths:-
    Current:  D:\WAMPServer\logs\mail\hmailserver_2019-02-08.log
    Error:    D:\WAMPServer\logs\mail\ERROR_hmailserver_2019-02-08.log
    Event:    D:\WAMPServer\logs\mail\hmailserver_events.log - Not present
    Awstats:  D:\WAMPServer\logs\mail\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MySQL
Backup directory D:\WAMPBackup\hMailServer is writable.
There are no error logs in the log directory.
HMAILSERVER.INI
Program folder:  D:\WAMPPlugins\hMailServer\
Database folder:
Data folder:     D:\WAMPPlugins\hMailServer\Data
Log folder:      D:\WAMPServer\logs\mail
Temp folder:     D:\WAMPPlugins\hMailServer\Temp
Event folder:    D:\WAMPPlugins\hMailServer\Events
Type=              MYSQL
Username=          klr-mail
Port=              3309
Server=            database.Domain1.com
Internal=          0
And this is my PHP code :
<?php
	// Fichiers nécessaires à l'envoi du mail
	require 'phpmailer/PHPMailer.php';
	require 'phpmailer/Exception.php';
	require 'phpmailer/SMTP.php';
	use PHPMailer\PHPMailer\PHPMailer;
	// Création d'une nouvelle instance
	$mail = new PHPMailer(true);
	// Configuration du serveur de mesagerie
	$mail->isSMTP();
	$mail->Host = 'smtp.Domain1.com';
	$mail->SMTPAuth = true;
	$mail->Username = "noreply@Domain1.com";
	$mail->Password = "xxxxxxxxxxx";
	$mail->SMTPSecure = 'tls';
	$mail->Port = 587;
	// Configuration de la sécurité
	$mail->SMTPOptions = array(
		'ssl' => [
			'verify_peer' => true,
			'verify_depth' => 3,
			'allow_self_signed' => true,
			'cafile' => 'd:/wampserver/ssl/ca/intermediate/ca-chain.cert.pem',
	$mail->SMTPAutoTLS = false;
	// Configuration du débogage
	$mail->SMTPDebug = 2;
	$mail->Debugoutput = 'html';
	// Configuration de l'en-tête du mail
	$mail->isHTML(true);
	$mail->Subject = 'Confirmation de votre adresse de messagerie';
	$mail->setFrom('noreply@Domain1.com', 'No Reply');
	$mail->addAddress($Email);
	// Configuration du contenu du mail
	$mail->Body = $Body;
	$mail->AltBody = $AltBody;
	if (!$mail->send()) {
		echo "Mailer Error: " . $mail->ErrorInfo;
The PHPMailer is configured as roundcube so I don't understand why the script is blocked like this :(
Kind regards,
Re: [PHPMailer] Unable to send mail
Post by Dravion » 2019-02-09 00:29
In hMailAdmin enable logging, logout from hMailAdmin, stop the hMailServer Service,
go c:\Program Files (x86) \hMailServer\logs (or where you installed hMailServer) and delete
all files within the log Folder.
Start hMailAdmin and click connect, this will autostart the hMailServer service.
Try to send an Email with PHPMailer and take a look at your new hMailServer logfiles which
should contain the circumstances of your Problem.
Post by mattg » 2019-02-09 02:10
That error is because your PHP system and your hmailserver can't agree on a protocol or a cipher, or that your self signed cert isn't trusted by your PHP system
Is OpenSSL loaded in PHP?
Other hints here >> https://github.com/PHPMailer/PHPMailer/ ... leshooting
NivekLR
Post by NivekLR » 2019-02-09 10:21
Thanks for your answers.
@Dravion - Resetting the Log file does not show more information...
@mattg - I have used the command :
echo (extension_loaded('openssl')?'SSL loaded':'SSL not loaded')."\n";
And SSL loaded appears.
I have already followed the link you mentioned but nothing works...
How I check the cipher used by my PHP system ?
Kind regards,
Post by mattg » 2019-02-10 02:13
Does anything else use port 587 on your hmailserver?
if not change it to no security, and change your php mailer to no security on the connection and confirm that it works.
My guess is that you have a self signed or otherwise untrusted certificate on your hMailserver, that your PHP system doesn't like.
A few ways around that, so depending on where you got the cert etc
NivekLR
Post by NivekLR » 2019-02-10 11:59
Thanks mattg, I finished to solve the issue by founding a mistake in the certificate path... I am boring myself 😋
Kind regards,
