SMTP relayer
steph
SMTP relayer
Post by steph » 2019-02-06 15:16
Hi all,
Is there a way to write a "run function" (Action) for a particular account's rule for "not using the defined SMTP relayer" while sending out but rather "using hMailserver SMTP itself" ?
Example
Critera -> "From" equals to "Value" (Value = some email address)
Action (Run function) -> use local SMTP instead of defined SMTP relayer
Cheers,
Stéphane
Re: SMTP relayer
Post by mattg » 2019-02-06 15:54
The opposite is possible, but not that way round
You could use SMTP route, but that would require another machine to do the sending
mikedibella
Re: SMTP relayer
Post by mikedibella » 2019-02-06 18:33
Or possibly run a different relay (i.e. MS-SMTP) on the same machine on a custom port and use a route to forward to that MTA, and then use MX lookup for next-hop.
steph
Re: SMTP relayer
Post by steph » 2019-02-07 19:46
mikedibella wrote:
2019-02-06 18:33
Thanks for your comments gents.
I ended setting up a second SMTP server on another internal server (Windows Server 2012 r2 Virtual SMTP service).
But not working.. DNS problem I guess.. grrr
Cheers,Stéphane
Re: SMTP relayer
Post by mattg » 2019-02-08 05:00
Are you forwarding from 1st to 2nd server?
