Hardening hMailServer - The ongoing saga!
Re: Hardening hMailServer - The ongoing saga!
Hey palinka,
perhaps you can help me by another question.
Can i exclude IPs from beeing checked from the script? Like whitelisting or so?
If it's possible, how can i do this?
Thank you!
Thank you!
Sure. There's a couple of ways.
First, always exclude local mail and backup from tests that should be for incoming mail, or tests for untrusted IPs.
Sub OnClientConnect(oClient)
REM - Exclude Backup-MX & local LAN from test
If (Left(oClient.IPAddress, 12) = "184.105.182.") Then Exit Sub ' junkemailfilter.com backup mx
If (Left(oClient.IPAddress, 11) = "192.168.22.") Then Exit Sub ' local LAN
If oClient.IPAddress = "127.0.0.1" Then Exit Sub ' localhost
' Continue processing incoming connections
Secondly, I made a whitelisting function to check IPs against WL-RBLs. This requires RvdH's DNS Resolver: https://d-fault.nl/files
Function IsWhitelisted(strIP) : IsWhitelisted = False
Dim a : a = Split(strIP, ".")
Dim strLookup, strRegEx
Dim IsWLMailSpike, IsWLHostKarma, IsWLNSZones, IsWLSPFBL, IsWLSpamDonkey, IsWLIPSWhitelisted
strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".rep.mailspike.net")
strRegEx = "^127\.0\.0\.(19|20)$" '18=Good, 19=Very Good, 20=Excellent Reputation
IsWLMailSpike = Lookup(strRegEx, strLookup)
strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".hostkarma.junkemailfilter.com")
strRegEx = "^127\.0\.0\.(1|5)$" '1=Good, 5=NoBL
IsWLHostKarma = Lookup(strRegEx, strLookup)
strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".wl.nszones.com")
strRegEx = "^127\.0\.0\.5$" '5=whitelisted
IsWLNSZones = Lookup(strRegEx, strLookup)
strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".dnswl.spfbl.net")
strRegEx = "^127\.0\.0\.(2|3|4|5)$" '2=excellent rep, 3=indispensable public service, 4=corp email (no marketing), 5=safe bulk mail
IsWLSPFBL = Lookup(strRegEx, strLookup)
strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".dnsbl.spamdonkey.com")
strRegEx = "^126\.0\.0\.0$" '126.0.0.0=whitelisted
IsWLSpamDonkey = Lookup(strRegEx, strLookup)
strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".ips.whitelisted.org")
strRegEx = "^127\.0\.0\.2$" '2=whitelisted
IsWLIPSWhitelisted = Lookup(strRegEx, strLookup)
If (IsWLMailSpike OR IsWLHostKarma OR IsWLNSZones OR IsWLSPFBL OR IsWLSpamDonkey OR IsWLIPSWhitelisted) Then ISWhitelisted = True
If NOT(IsWhitelisted(strIP)) Then
' do stuff here to non-whitelisted IPs
-- or - like above --
If IsWhitelisted(strIP) Then Exit Sub
Yeah this is what i am looking for.palinka wrote: ↑2022-04-29 21:10Secondly, I made a whitelisting function to check IPs against WL-RBLs. This requires RvdH's DNS Resolver: https://d-fault.nl/files
I use the IsWhitelisted function to exclude from geoip testing with the idea that I can ban many countries with geoip, but still allow whitelisted IPs from banned countries through.Code: Select all
Function IsWhitelisted(strIP) : IsWhitelisted = False Dim a : a = Split(strIP, ".") Dim strLookup, strRegEx Dim IsWLMailSpike, IsWLHostKarma, IsWLNSZones, IsWLSPFBL, IsWLSpamDonkey, IsWLIPSWhitelisted With CreateObject("DNSLibrary.DNSResolver") strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".rep.mailspike.net") End With strRegEx = "^127\.0\.0\.(19|20)$" '18=Good, 19=Very Good, 20=Excellent Reputation IsWLMailSpike = Lookup(strRegEx, strLookup) With CreateObject("DNSLibrary.DNSResolver") strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".hostkarma.junkemailfilter.com") End With strRegEx = "^127\.0\.0\.(1|5)$" '1=Good, 5=NoBL IsWLHostKarma = Lookup(strRegEx, strLookup) With CreateObject("DNSLibrary.DNSResolver") strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".wl.nszones.com") End With strRegEx = "^127\.0\.0\.5$" '5=whitelisted IsWLNSZones = Lookup(strRegEx, strLookup) With CreateObject("DNSLibrary.DNSResolver") strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".dnswl.spfbl.net") End With strRegEx = "^127\.0\.0\.(2|3|4|5)$" '2=excellent rep, 3=indispensable public service, 4=corp email (no marketing), 5=safe bulk mail IsWLSPFBL = Lookup(strRegEx, strLookup) With CreateObject("DNSLibrary.DNSResolver") strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".dnsbl.spamdonkey.com") End With strRegEx = "^126\.0\.0\.0$" '126.0.0.0=whitelisted IsWLSpamDonkey = Lookup(strRegEx, strLookup) With CreateObject("DNSLibrary.DNSResolver") strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".ips.whitelisted.org") End With strRegEx = "^127\.0\.0\.2$" '2=whitelisted IsWLIPSWhitelisted = Lookup(strRegEx, strLookup) If (IsWLMailSpike OR IsWLHostKarma OR IsWLNSZones OR IsWLSPFBL OR IsWLSpamDonkey OR IsWLIPSWhitelisted) Then ISWhitelisted = True End Function If NOT(IsWhitelisted(strIP)) Then ' ' do stuff here to non-whitelisted IPs ' End If -- or - like above -- REM - Exclude Backup-MX & local LAN from test If (Left(oClient.IPAddress, 12) = "184.105.182.") Then Exit Sub ' junkemailfilter.com backup mx If (Left(oClient.IPAddress, 11) = "192.168.22.") Then Exit Sub ' local LAN If oClient.IPAddress = "127.0.0.1" Then Exit Sub ' localhost If IsWhitelisted(strIP) Then Exit Sub
Do i have to put this in "Eventhandler.vbs" or "Handler.vbs"?
And where can i define the whitelisted IPs, for example 94.105.266.80?
It goes in eventhandlers.vbs.udgesbou wrote: ↑2022-04-30 16:11Yeah this is what i am looking for.palinka wrote: ↑2022-04-29 21:10Secondly, I made a whitelisting function to check IPs against WL-RBLs. This requires RvdH's DNS Resolver: https://d-fault.nl/files
Thanks![]()
YOU don't define anything. These are public RBLs doing the checking for you. They define their own whitelists.
Okay, but i one IP i want to exclude from checking.
Is this what i have to do?
If (Left(oClient.IPAddress, 12) = "94.105.266.80") Then Exit Sub ' MY IP THAT I WANT TO EXLUDE
Greetings
Yes.udgesbou wrote: ↑2022-04-30 20:37Okay, but i one IP i want to exclude from checking.
Sub OnClientConnect(oClient) REM - Exclude Backup-MX & local LAN from test If (Left(oClient.IPAddress, 12) = "94.105.266.80") Then Exit Sub ' MY IP THAT I WANT TO EXLUDE If (Left(oClient.IPAddress, 11) = "192.168.22.") Then Exit Sub ' local LAN If oClient.IPAddress = "127.0.0.1" Then Exit Sub ' localhost ' ' Continue processing incoming connections ' End Sub
Greetings
For specific IP useudgesbou wrote: ↑2022-04-30 20:37
Greetings
If oClient.IPAddress = "94.105.266.80" Then Exit Sub ' MY IP THAT I WANT TO EXLUDE
HMS 5.6.9 B2607.56 on Windows Server 2016 Core VM.
Hey,
since two days i can't connect to my hMailServer via Outlook, Android Mail or so.
I think one reason could be my geoblocking. I only allowed ip addresses from germany.
But in my "hmailserver_events.log" i only get these results:
The hmailserver.log looks like this at 11:43:14:
I only got "zz". I tried it from differet IPs from Germany, but i only got "zz" and not "de". It is since the 04.12.2022.
Can anyone help me, how i can fix that?
Thanks in advance
12260 "2022-12-06 11:14:24.036" "- GeoLookup(60.217.75.70) = zz"
4252 "2022-12-06 11:43:14.268" "- GeoLookup(91.15.34.229) = zz"
4252 "2022-12-06 11:43:34.471" "- GeoLookup(80.187.102.198) = zz"
"DEBUG" 4252 "2022-12-06 11:43:14.236" "Creating session 38"
"TCPIP" 4252 "2022-12-06 11:43:14.252" "TCP - 91.15.34.229 connected to MYIPADDRESS:465."
"DEBUG" 4252 "2022-12-06 11:43:14.252" "Executing event OnClientConnect"
"DEBUG" 4252 "2022-12-06 11:43:14.268" "Event completed"
"DEBUG" 4252 "2022-12-06 11:43:14.268" "Ending session 37"
Thanks in advance
Looks like countries.nerd.dk has some issue, might be temporary or maybe it is permanently gone (don't think it was maintained actively anyway)
; <<>> DiG 9.16.34 <<>> 100.232.204.81.zz.countries.nerd.dk TXT
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 47380
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
; COOKIE: 98c1cb9aed04b11101000000638f23d8396910e6ca9806ce (good)
;; QUESTION SECTION:
;100.232.204.81.zz.countries.nerd.dk. IN TXT
;; Query time: 15 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Tue Dec 06 12:13:28 W. Europe Standard Time 2022
;; MSG SIZE rcvd: 92
Maybe you could substitute it with country.junkemailfilter.com?
; <<>> DiG 9.16.34 <<>> 100.232.204.81.country.junkemailfilter.com TXT
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16008
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
; COOKIE: ebb327ea90df677401000000638f2515af071c78656b0bd3 (good)
;100.232.204.81.country.junkemailfilter.com. IN TXT
;; ANSWER SECTION:
100.232.204.81.country.junkemailfilter.com. 21600 IN TXT "nl"
;; Query time: 1633 msec
;; WHEN: Tue Dec 06 12:18:45 W. Europe Standard Time 2022
;; MSG SIZE rcvd: 114
;; Got answer:
;; Got answer:
;; ANSWER SECTION:
Oh okay, thanks for your very fast research and reply.RvdH wrote: ↑2022-12-06 13:15Looks like countries.nerd.dk has some issue, might be temporary or maybe it is permanently gone (don't think it was maintained actively anyway)
;; Got answer:
Is there any alternatie known which could possibly use?
EDIT:
Oh this could be an option, so i have to change "zz.countries.nerd.dk" to "country.junkemailfilter.com"?RvdH wrote: ↑2022-12-06 13:15Maybe you could substitute it with country.junkemailfilter.com?
;; Got answer:
;; ANSWER SECTION:
I think there is a slight difference between them for England, if i remember right is discovered by countries.nerd.dk as "uk" whereas country.junkemailfilter.com returns "gb" (might be more irregularities)
Yep, that should be enough
Okay, but i would only allow connections from germany anyway, so i would only need the return for germany. Is it possible to research this somewhere? Or is it "de"?
Okay so it should look like this?:
EventHandlers.vbs
Function GetDatabaseObject()
Set GetDatabaseObject = oApp.Database
Function GeoLookup(strIP) : GeoLookup = "zz"
Dim a, element, group, strLookup
strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & "country.junkemailfilter.com")
If Trim(strLookup) = "" Then
EventLog.Write( "- GeoLookup(" & strIP & ") = " & GeoLookup )
Exit Function
group = Split(strLookup, vbCrLf)
If UBound(group) > 0 Then
For Each element In group
If (Trim(element) <> "") Then EventLog.Write( "- GeoLookup(" & strIP & ") = " & element )
GeoLookup = group(0)
'********** hMailServer Triggers **********
' Exclude local LAN from test
If (Left(oClient.IPAddress, 12) = "MYIPADDRESS") Then Exit Sub ' MEDIUM Cloud
If (Left(oClient.IPAddress, 10) = "192.168.0.") Then Exit Sub ' Local
' Only allow non-SMTP connect from "Rigsfællesskabet"/"Naalagaaffeqatigiit"/"Ríkisfelagsskapurin" = The Danish Realm.
' zz = N/A, dk = Denmark, gl = Greenland, fo = Faroe Islands
If (oClient.Port <> 25) Then
If (InStr("de", GeoLookup(oClient.IPAddress)) = 0) Then
' Add unauthorized access to IDS registry
Call idsAddIP(oClient.IPAddress, oClient.Port)
Result.Value = 1
Exit Sub
' Only test SMTP traffic on defined ports 25, 587 and 465.
' Register IP address in IDS registry.
If (InStr("|25|587|465|", oClient.Port) > 0) Then Call idsAddIP(oClient.IPAddress, 0)
'* Sub OnHELO(oClient)
'* End Sub
This is the actuall EventHandlers.vbs:
strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.countries.nerd.dk")
Exit Function
Result.Value = 1
Exit Sub
'* End Sub
it is "de"
; <<>> DiG 9.16.34 <<>> 229.34.15.91.country.junkemailfilter.com TXT
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 37014
; COOKIE: 7129c829559b875901000000638f28e333e400f7fa7c13bd (good)
;229.34.15.91.country.junkemailfilter.com. IN TXT
;; ANSWER SECTION:
229.34.15.91.country.junkemailfilter.com. 21600 IN TXT "de"
;; Query time: 281 msec
;; WHEN: Tue Dec 06 12:34:59 W. Europe Standard Time 2022
;; MSG SIZE rcvd: 112
;; Got answer:
;; ANSWER SECTION:
https://wiki.junkemailfilter.com/index. ... _DNS_ListsCountry Code List
Junk Email Filter now provides a country code IP lookup. Just used the standard IP lookup (reversed) and read the TXT record and it returns a 2 character country code.
4.3.2.1.country.junkemailfilter.com TXT
Return code of "zz" means the country is unknown.
Thank you!
I tried this EventHandlers.vbs Config, but the result is still "zz"
strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.country.junkemailfilter.com")
Exit Function
Result.Value = 1
Exit Sub
'* End Sub
Or it ".zz.country.junkemailfilter.com" the wrong address?
Yes, read above
strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".country.junkemailfilter.com")
OMG, now it works, i can connect to my hMailServerRvdH wrote: ↑2022-12-06 14:09Code: Select all
With CreateObject("DNSLibrary.DNSResolver") strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".country.junkemailfilter.com") End With
Thank you very very much for for help and your patience.
In hmailserver_events.log i got still the result "zz", but i can connects and receive and send mails. I dont know why i got no "de" as result?
That sounds weird, did you reload scripts?udgesbou wrote: ↑2022-12-06 14:18OMG, now it works, i can connect to my hMailServerRvdH wrote: ↑2022-12-06 14:09Code: Select all
Ah, i see... EventLog.Write is only called when none or multiple entries are returned.... not for successful lookups
Not even sure if multiple is possible here, the lookup against nerds.dk had the odd behavior to sometimes return multiple results, example: "nl" and "eu"
Yeah, I reload Scripts and restart hmailserver, but still result "zz"
Oh dear, I don't know what that meanRvdH wrote: ↑2022-12-06 15:53Ah, i see... EventLog.Write is only called when none or multiple entries are returned.... not for successful lookups
It only logs failures as said before, if you like to log successful lookups change the function like:
Exit Function
EventLog.Write( "- GeoLookup(" & strIP & ") = " & group(0))
That works pretty well, thank you very very much my friendRvdH wrote: ↑2022-12-06 15:58It only logs failures as said before, if you like to log successful lookups change the function like:
Function GeoLookup(strIP) : GeoLookup = "zz" Dim a, element, group, strLookup a = Split(strIP, ".") With CreateObject("DNSLibrary.DNSResolver") strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".country.junkemailfilter.com") End With If Trim(strLookup) = "" Then EventLog.Write( "- GeoLookup(" & strIP & ") = " & GeoLookup ) Exit Function End If group = Split(strLookup, vbCrLf) If UBound(group) > 0 Then For Each element In group If (Trim(element) <> "") Then EventLog.Write( "- GeoLookup(" & strIP & ") = " & element ) Next Else EventLog.Write( "- GeoLookup(" & strIP & ") = " & group(0)) GeoLookup = group(0) End If End Function
Link is brokenSorenR wrote: ↑2019-01-28 17:09ActiveX object DNSLibrary can be obtained from https://d-fault.nl/files/DNSResolverCom ... .3.exe.zip
I see that RvdH has listed newer versions
I created a redirect DNSResolverComponent_1.3.exe.zip to DNSResolverComponent_1.3.1.2.exe.zipmattg wrote: ↑2022-12-09 02:55Link is brokenSorenR wrote: ↑2019-01-28 17:09ActiveX object DNSLibrary can be obtained from https://d-fault.nl/files/DNSResolverCom ... .3.exe.zip
DNSResolverComponent_1.3.1.2 uses UDP and requires .NET 3.5 (using HeijdenDNS)
DNSResolverComponent_1.4.1.2 uses TCP and requires .NET 4.5 (using HeijdenDNS)
DNSResolverComponent_1.4.5.0 is a complete rewrite with more options, eg: you can choose bewteen UDP and TCP, TCP fallback, set UDP packet size and requires .NET 4.5 (using DnsClient.NET)
(i think
1.4.5.0
Example:This object has 28 public functions:
-- SetTimeout(<int [1-10]>) * default 1
-- SetRetries(<int [1-10]>) * default 3
-- SetRecursion(<bool>) * default true
-- SetServer(<string IPv4 or IPv6>) * default none
-- SetEdnsPacketSize(<int [512-4096]>) * default 4096
-- SetTcpFallback(<bool>) * default true
-- SetTcpOnly(<bool>) * default false
-- GetTimeout() * returns Timeout value
-- GetRetries() * returns Retries value
-- GetRecursion() * returns Recursion value
-- GetServer() * returns Server value (if any)
-- GetEdnsPacketSize() * returns edns packet size value
-- GetTcpFallback() * returns TCPFallback value
-- GetTcpOnly() * returns TCPOnly value
-- Version() * returns the version number
-- Help() * shows this help
-- IPv4A(<Domain name>) * query IPv4 A-Record(s)
-- A(<Domain name>) * same as IPv4A (deprecated)
-- DNSLookup(<Domain name>) * same as IPv4A (deprecated)
-- IPv6A(<Domain name>) * query IPv6 A-Record(s)
-- AAAA(<Domain name>) * same as IPv6A (deprecated)
-- CAA(<Domain name>) * query CAA-Record
-- CNAME(<Domain name>) * query CNAME-Record(s)
-- MX(<Domain name>) * query MX-Record(s)
-- NS(<Domain name>) * query NS-Record(s)
-- PTR(<IP address>) * query PTR-Record
-- SOA(<Domain name>) * query SOA-Record
-- TXT(<Domain name>) * query TXT-Record(s)
Private Const DnsServer = "127.0.0.1"
Private Const DnsExtendedDnsBufferSize = 1232
Private Const DnsTimeOut = 5
Private Const DnsRetries = 2
.SetServer(DnsServer)
.SetEdnsPacketSize(DnsExtendedDnsBufferSize)
.SetTimeout(DnsTimeOut)
.SetRetries(DnsRetries)
Too sad about countries.nerd.dk, but there seems to be an alternative for country blocking with country.junkemailfilter.com
Unfortunately, I am not as sophisticated as many here so I have to take little baby steps in how I change my setup. I'm gathering that I cannot simply swap out my country-based DNS blacklists in hmailserver by replacing, say "cn.countries.nerd.dk" by "country.junkemailfilter.com". One is testing for a country and if the result is "yes" then the message is rejected whereas with country.junkemailfilter.com there are no predefined IP blocks so the answer to the query is not "yes" nor "no" but "country".
Hm. So what you are doing now is letting a script do the lifting of getting the country first and then checking the result against white- or black-listed countries in your own config? That would be the way for me, unfortunately I cannot simply allow connections from country but need a few more as well as to not shut out Goggle, Hootmail, etc. Perferably, white-listing should be used and all other countries rejected. However, I have no idea how to use external programs for this, like the "resolver". Could someone give me a pointer where I can read up on this? I'm not running hmailserver on Windows server though, just a workstation.
The inbuilt DNS blacklist thing is really great, though, as it let's you use finegrained reactions via scoring. Too bad country.junkemailfilter.com can't be used with that directly!
Edit: Hang on, hang on... I feel a tingle in my toes...
Is this supposed to work?
https://imgur.com/a/siuEk9s
No, that won't work because the answer will be an IP address like 127.0.0.2. The reply will be NX domain always.Jorgo wrote: ↑2022-12-17 23:26The inbuilt DNS blacklist thing is really great, though, as it let's you use finegrained reactions via scoring. Too bad country.junkemailfilter.com can't be used with that directly!
If you can make a query work using nslookup, then it will work as a custom dnsbl like you tried to do with it.
Your best bet is to try to make the script above work, or if you prefer using local query with mysql, then you can check this one out: viewtopic.php?f=9&t=34496
Thanks, you seem to be on top of it. Although I'm running MySQL in MariaDB flavour, the thread you referenced unfortunately is very long, still seems to be ongoing and I can't make out which post contains the complete final script. Probably should be in .sql format so it could be imported into the database but all that is a bit over my head.
OK, I've got logging working, same as @udgesbou above. Now I would like to immediately disconnect any country not in my whitelist. In his script I see
that "Only allow Danish Realm" is commented but then it seems to target only "de". I guess I would expand the country list like
Also, for the Call to idsAddIP I guess I have to backtrack to @SorenR 's original concept from 2019 and start experimenting...
Result.Value = 1
Exit Sub
If (InStr("de|us|fr"", GeoLookup(oClient.IPAddress)) = 0) Then
Alright, does anyone spot syntax errors or call nonsense?
Exit Function
' Autoban unwanted countries for 1 day
' 1. Exclude local LAN from test
If (Left(oClient.IPAddress, 10) = "192.168.1.") Then Exit Sub
' 2. Only allow non-SMTP connections from some countries (remember where you might be in your holidays + VPN!)
' Examples: zz = N/A, de = Germany, us = USA, nl = Holland, be = Belgium, fr = France, at = Austria, ch = Switzerland
If (InStr("de|us|at", GeoLookup(oClient.IPAddress)) = 0) Then
Result.Value = 1
EventLog.Write(oClient.IPAddress & vbTab & oClient.Port)
Call AutoBan(oClient.IPAddress, "InStr" & oClient.Port, 1, "d")
Exit Sub
' 3. Only allow SMTP connections from some countries (breaking RFC)
If (oClient.Port = (25|587|465)) Then
If (InStr("de|us|be|nl|fr|at|ch)", GeoLookup(oClient.IPAddress)) = 0) Then
Result.Value = 1
Exit Sub
Call oApp.Authenticate(ADMINISTRATOR, MYPASSWORD)
With LockFile(oApp.Settings.Directories.TempDirectory & "\autoban.lck")
On Error Resume Next
If (oApp.Settings.SecurityRanges.ItemByName("Auto-ban: (" & sReason & ") " & sIPAddress) Is Nothing) Then
.Name = "Auto-ban: (" & sReason & ") " & IPAddress
.LowerIP = sIPAddress
.UpperIP = sIPAddress
.Priority = 20
.Expires = True
.Save
On Error Goto 0
.Close
my experience, country.junkemailfilter.com is not that accurate, i had several NL based IP's being blocked
https://github.com/RvdHout/GeoLite2SQL (basically the same as https://github.com/palinkas-jo-reggelt/GeoLite2SQL, but with original database format/column names and MySQL.Data.dll embedded)
https://www.hmailserver.com/forum/viewt ... 67#p244167
I had a peek at your code and noticed something. I was going to post an issue on your github but issues don't seem to be available on this repository. Anyway:
https://github.com/RvdHout/GeoLite2SQL/ ... L.ps1#L210
You should change the url to your own github address because if you make changes, no one that has downloaded it will know. And if I make changes, your downloaders will think there was an update when there wasn't.
Good one, better now?palinka wrote: ↑2022-12-19 09:49I had a peek at your code and noticed something. I was going to post an issue on your github but issues don't seem to be available on this repository. Anyway:
You should change the url to your own github address because if you make changes, no one that has downloaded it will know. And if I make changes, your downloaders will think there was an update when there wasn't.![]()
Yeah, looks good. Address resolves properly. Don't forget to update version.txt when you make updates.RvdH wrote: ↑2022-12-19 10:46Good one, better now?palinka wrote: ↑2022-12-19 09:49I had a peek at your code and noticed something. I was going to post an issue on your github but issues don't seem to be available on this repository. Anyway:
I wonder if there's some github api function that can do this automatically.
