Database version: 5700, Required database version: 5601
charleso
Post by charleso » 2019-01-28 03:21
After battling with this error for long:
[DBNETLIB][ConnectionOpen (SECDoClientHandshake()).]SSL Security error.
I followed the steps and advice from here viewtopic.php?t=33269#p207910
and upgraded to this version: download/file.php?id=4203
The initial Error is gone. I can now log into hMailAdmin, and i see my domains listed.
On clicking Status, i get the following erorr:
An error occurred processing the request.
ExceptionType: COMException
HelpLine:
Message: An error occurred processing the request.
Source: hMailServer COM library
StackTrace:    at hMailServer.SettingsClass.get_HostName()
   at hMailServer.Administrator.ucStatus.DisplayWarnings()
   at hMailServer.Administrator.ucStatus.LoadData()
   at hMailServer.Administrator.formMain.ShowNodeRepresentation(INode node)
   at hMailServer.Administrator.formMain.treeNodes_AfterSelect(Object sender, TreeViewEventArgs e)
   at System.Windows.Forms.TreeView.TvnSelected(NMTREEVIEW* nmtv)
   at System.Windows.Forms.TreeView.WmNotify(Message& m)
   at System.Windows.Forms.TreeView.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
TargetSite: System.String get_HostName()
Also on clicking Settings > Advanced i now get this:
You do not have access to this property / method. Ensure that hMailServer.Application.Authenticate() is called with proper login credentials.
HelpLine:
Message: You do not have access to this property / method. Ensure that hMailServer.Application.Authenticate() is called with proper login credentials.
StackTrace:    at hMailServer.SSLCertificatesClass.get_Count()
   at hMailServer.Administrator.Nodes.NodeSSLCertificates.get_SubNodes()
   at hMailServer.Administrator.formMain.LoadNodeChildren(TreeNode node, Int32 recursionDepth)
   at hMailServer.Administrator.formMain.treeNodes_BeforeExpand(Object sender, TreeViewCancelEventArgs e)
   at System.Windows.Forms.TreeView.TvnExpanding(NMTREEVIEW* nmtv)
TargetSite: Int32 get_Count()
hmailserver-webadmin (with errors: On) shows this:
Severity: 1 (Critical), Code: HM5011, Source: Application::OnDatabaseConnected, Description: The database is too new for this version of hMailServer. Please upgrade hMailServer. Database version: 5700, Required database version: 5601
Please has anyone else tried the suggested fix for [DBNETLIB][ConnectionOpen (SECDoClientHandshake()) Error?
Are you experiencing any of these?
Re: Database version: 5700, Required database version: 5601
Post by mattg » 2019-01-28 03:44
Which database are you using?
That error/ solution should be specific to the MS SQL database mentioned in that initial thread that you link to
The errors you are getting now look like DCOM errors, and could be caused by you running the hMailserver service as a non-standard user
charleso
Post by charleso » 2019-01-28 04:18
MSSQL Server 2017
I have Local Admin Access on that machine.
I'll try the service on Local Admin.
Post by mattg » 2019-01-28 07:18
What user was the hMailserver service running under?
charleso
Post by charleso » 2019-01-28 10:26
Local system Account, I did not need to change it.
Post by mattg » 2019-01-28 11:35
charleso
Post by charleso » 2019-01-28 12:09
i have downgraded back to 5601 (hMailServer version 5.6.7-B2425)
and re-enabled TLS 1.0 for peace of mind. That seems to be the only way out for now, sadly :(
Post by mattg » 2019-01-29 00:55
Or you can use a different database type
The TLSv1.0 checkbox in hMailserver should NOT effect database connections, and should only impact on mail connections
Post by Dravion » 2019-01-29 07:12
Do you use the my hMailServer Patch for TLSv1.2 Support for MS-SQL Server which i attached for a other Support Case?
Anyhow.
The Error you receive haa to do with the Database Table hm_version. It has only 1 Fiield which is the Database version Number. As quick fix you can update it to 5700 but you should update again to 5601 before you apply an official hMailServer Update again.
