server receives messages addressed to wrong domain
antons
Post by antons » 2018-11-01 08:43
Hello!
Hmailserver on Windows Server 2003R2, one mail domain.
All works as expected, but I have issue related to spam messages.
The my domain users receives spam messages addressed to nonexisting user on server. Messages addressed to ANOTHER domain user. May it is some spam technology, I don't know.
For instance- user@mydomain.com receives message originally addressed to someanotheruser@anotherdomain.com.
May be somebody can explain this? What is remedy?
SpamAssasin score in my configuration not always to enough to mark these messages as spam.
______________________________
X-Spam-Status: No, score=2.4 required=5.0 tests=BAYES_00,HK_NAME_DRUGS,
HTML_FONT_FACE_BAD,HTML_IMAGE_ONLY_24,HTML_IMAGE_RATIO_02,HTML_MESSAGE,
MAILING_LIST_MULTI,RCVD_IN_MSPIKE_H2,URIBL_BLACK autolearn=no
autolearn_force=no version=3.4.0
Received: from mail.oxizone.eu (mail.oxizone.eu [46.249.59.89])
by mail.mydomain.com with ESMTP
; Tue, 30 Oct 2018 19:34:40 +0200
Received: from oxizone.eu (p1009.serv-dns.ru [5.188.204.57])
by mail.oxizone.eu (Postfix) with ESMTPA id 89FAE236B3;
Tue, 30 Oct 2018 19:32:41 +0200 (EET)
Message-ID: <adridrt27744576.72562082@mail.oxizone.eu>
Reply-To: "Sieviesu Viagra" <adridrt@oxizone.eu>
To: <d.nikitjuk@anotherdomain.com>
Subject: =?utf-8?B?S8SBIHNpZXZpZXRpIHBhdmVzdCB0aWthaSAxNSBtaW7Fq3Rlcw==?=
Date: Tue, 30 Oct 2018 19:31:13 +0200
MIME-Version: 1.0
___________________________________
Thank You.
Re: server receives messages addressed to wrong domain
Post by jimimaseye » 2018-11-01 08:49
run this and post the results: viewtopic.php?f=20&t=30914
antons
Post by antons » 2018-11-01 09:26
Thank You for fast response.
I will do it later, because I'm not on server's location right now.
antons
Post by antons » 2018-11-01 18:56
Diagnostics report:
2018-11-01   Hmailserver: 5.6.4-B2283
DOMAINS
   "Domain1.com" - baxxxxxx.lv                    Enabled: True
      |- "Alias1.com" - maxx.baxxxxxx.lv
                   Max size of accounts:    0
        Greylisting: !! ENABLED BUT
NOT ACTIVATED!!
IP RANGES
IP: 89.46.77.51 - 89.46.77.51     Priority: 1000     Name: block 3
     SMTP:  False                              Antispam :  False
     POP3:  False                              Antivirus:  False
IP: 185.165.173.17 - 185.165.173.17     Priority: 1000     Name: block 31
IP: 23.227.199.123 - 23.227.199.123     Priority: 1000     Name: block2
IP: 192.168.3.1 - 192.168.3.254     Priority: 100     Name: local
     POP3:   True                              Antivirus:  False
IP: 84.241.26.240 - 84.241.26.240     Priority: 25     Name: 84.241.26.240
     SMTP:  False                              Antispam :   True
     POP3:  False                              Antivirus:   True
     IMAP:  False                              SSL/TLS:     True
IP: 91.200.12.13 - 91.200.12.13     Priority: 25     Name: 91.200.12.13
IP: 91.200.12.203 - 91.200.12.204     Priority: 25     Name: 91.200.12.203
IP: 185.77.131.195 - 185.77.131.195     Priority: 25     Name: block
IP: 157.122.148.249 - 157.122.148.249     Priority: 25     Name: blocl
IP: 78.6.17.238 - 78.6.17.238     Priority: 25     Name: spams
IP: 93.109.247.74 - 93.109.247.74     Priority: 25     Name: spams2
IP: 113.168.66.183 - 113.168.66.183     Priority: 25     Name: spams3
IP: 51.174.217.114 - 51.174.217.114     Priority: 25     Name: test
IP: 91.200.12.65 - 91.200.12.130     Priority: 25     Name: test1
     External To External - False
IP: 157.122.148.150 - 157.122.148.150     Priority: 0     Name: block1
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain1.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      5
There is a total of 3 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Host: Alias1.com          Empty sender:       True  Batch recipients:   100
Max Msg Size: 35000  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
                                               Max number commands: 100  Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Subject: False    Verify DKIM:       False        Use SA score:        True
DNSBL ENTRIES:
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
              0.0.0.0            to    255.255.255.255
edgarsgabranovs[@t]inbox[dot]lv
              0.0.0.0            to    255.255.255.255              logjuzino[@t]inbox[dot]lv
              0.0.0.0            to    255.255.255.255              serdolik9[@t]mail[dot]ru
              0.0.0.0            to    255.255.255.255              rekava-anita[@t]inbox[dot]lv
valentina[dot]fedulova[@t]balvi[dot]lv
              0.0.0.0            to    255.255.255.255              orders[@t]janus[dot]lv
              0.0.0.0            to    255.255.255.255              konivalei[@t]inbox[dot]lv
kupravasbiblioteka[@t]inbox[dot]lv
tilzasbiblioteka[@t]inbox[dot]lv
lazdukalnabiblioteka[@t]inbox[dot]lv
inese[dot]kocane[@t]inbox[dot]lv
              0.0.0.0            to    255.255.255.255              ineska9[@t]inbox[dot]lv
              0.0.0.0            to    255.255.255.255              ainabis[@t]inbox[dot]lv
              0.0.0.0            to    255.255.255.255              santexrekini[@t]apollo[dot]lv
              0.0.0.0            to    255.255.255.255              li/_git[@t]inbox[dot]lv
anna[dot]griestina[@t]inbox[dot]lv
kubulubiblioteka[@t]inbox[dot]lv
sandra[dot]locmele[@t]inbox[dot]lv
              0.0.0.0            to    255.255.255.255              aparesilvija[@t]inbox[dot]lv
              0.0.0.0            to    255.255.255.255              inwestsport[@t]tut[dot]by
              0.0.0.0            to    255.255.255.255              kkp[@t]kkplatvija[dot]lv
peipsi_project[@t]yahoo[dot]com
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: True,  Notify Receiver: False
  Max Message Size: 1024
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: True
               *.cab             Cab pielikumi
               *.com             Command
               *.csh             CSH script
               *.doc.zip         Banku viruss
               *.inf             Setup file
               *docm             Cryptovirus
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               192.168.3.54    / 25    / SMTP   -   None
               192.168.3.54    / 110   / POP3   -   None
               192.168.3.54    / 5900  / IMAP   -   None
  Paths:-
    Current:  C:\Program Files\hMailServer\Logs\hmailserver_2018-11-01.log
    Error:    C:\Program Files\hMailServer\Logs\ERROR_hmailserver_2018-11-01.log
    Event:    C:\Program Files\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  C:\Program Files\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
IPv6 support is not available in operating system.
ERROR: Backup directory E:\hmailserver is not writable.
HMAILSERVER.INI
Program folder:  C:\Program Files\hMailServer\
Database folder: C:\Program Files\hMailServer\Database
Data folder:     C:\Program Files\hMailServer\Data
Log folder:      C:\Program Files\hMailServer\Logs
Temp folder:     C:\Program Files\hMailServer\Temp
Event folder:    C:\Program Files\hMailServer\Events
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v1.92, Hmailserver
Forum.
Post by jimimaseye » 2018-11-01 21:13
This
Set authentication to true.
Also unless you have a valid reason you should remove the default domain too
antons
Post by antons » 2018-11-07 08:35
OK.
Great Thanks for assistance!
I was a blind :-)
The main problem remains is SPAM messages with BCC.
Is there a remedy for it?
I would like to block them all.
Post by mattg » 2018-11-07 10:00
antons wrote:
2018-11-07 08:35
As would we all
It is a continuous battle fighting SPAMMERs
antons
Post by antons » 2018-11-07 10:37
Retoric:
In nowadays most valuable Internet users skill is maximally quick close spam message in browser or delete in email. Who reads SPAM? It's a social behaviouir?
Post by SorenR » 2018-11-07 11:03
antons wrote:
2018-11-07 10:37
Retoric:
There is no difference in TO, CC or BCC addressed SPAM. You will soon learn that TO/FROM headers are NEVER to be trusted and that the only true sender, is the sender shown in MAIL FROM in your SMTP logs. That sender is not immediately available for testing but the code below will make it accessible in the header "X-Envelope-From". Same with "X-Envelope-To". "X-Envelope-OriginalTo" is there in case recipient is an alias.
SPAM scoring is key. Low score SPAM the user can handle themselves. High score SPAM should be kept from the user.
My users NEVER see all the SPAM sent to them.
I've just been hit with a SPAM storm beyond normal for little over one week and about 65% of all received SPAM is kept from the users, the rest goes into their SPAM folder. My SPAMTrap user keep it for learning and reference and my users will never know it exists.
   Call XEnvelope(oMessage)
Sub XEnvelope(oMessage)
   Dim i, strEnvelope1, strEnvelope2
      If (i = 0) Then
         strEnvelope1 = oMessage.Recipients(i).Address
         strEnvelope2 = oMessage.Recipients(i).OriginalAddress
         strEnvelope1 = strEnvelope1 & ", " & oMessage.Recipients(i).Address
         strEnvelope2 = strEnvelope2 & ", " & oMessage.Recipients(i).OriginalAddress
   oMessage.HeaderValue("X-Envelope-To") = strEnvelope1
   oMessage.HeaderValue("X-Envelope-OriginalTo") = strEnvelope2
