hMailServer - Github Fork and Contributionanalysis
Post by Dravion » 2018-10-27 14:41
There exists 144 Forks of hMailServer on Github (see: https://github.com/hmailserver/hmailser ... rk/members)
I reviewed any single fork and extracted the 11 Forks (of total 144) which contributed, modified or changed something.
Github - hMailServer Fork and Contributionanalysis (10/27/2018)
94ivana/hmailserver
# Implemented per-user flags for public folders (SQL-Script only modifications)
https://github.com/94ivana/hmailserver/ ... 5ddd7b3c2b
baa-archieve/hmailserver
#Created a Tuerkish Language INI-File but never filled it was translations
https://github.com/baa-archieve/hmailserver
Bagu/hmailserver
#Created a French Language INI-File but never filled it was translations
https://github.com/Bagu/hmailserver
Bill48105/hmailserver
#Added a try catch block to hmailserver/source/Server/COM/InterfaceClient.cpp (7 Aug 2014)
https://github.com/Bill48105/hmailserver
cuichengji/hmailserver
#Most active, changes DB-Scripts, VM-Path, SQL-Performance tweaks
https://github.com/cuichengji/hmailserver
dswartz/hmailserver
#Errormessage and text cosmetics (typos and a misleading error messages)
https://github.com/dswartz/hmailserver
eburkitt/hmailserver
#Released a undocumented Source ZIP-Archive but no binaries (Exe, no Installer, no hMailServer.exe ect)
https://github.com/eburkitt/hmailserver
bholliger/hmailserver
#Accepted Patch by Martin - Installer, MS-SQL-CE related
https://github.com/gicldk/hmailserver/c ... 7439f37a7b
sprintman/hmailserver
#Modified IMAP DELE and RETR commands - Fix ExternalFetcher DELE when no RETR
https://github.com/sprintman/hmailserver
OutbackMatt/hmailserver <- Second active, private development
#Changed PHP-Script hmailserver/source/WebAdmin/hm_status.php array index order
https://github.com/OutbackMatt/hmailserver
RvdHout/hmailserver <- Most active, private development
#Various custome customizations, tests for integrating OpenSSL 1.1.x (heavy API Changes) but no releases so far
https://github.com/RvdHout/hmailserver
Summary:
From 144 Forks, 2 Releases (1 Functional for Endusers with Setup/Instalelr)
prisma
Re: hMailServer - Github Fork and Contributionanalysis
Post by prisma » 2018-11-15 12:11
Good work! THX a lot.
Hmmm, which knowledge (actions?) can we derive from it? I'm personally not sure, that's why I'm asking.
Post by SorenR » 2018-11-15 13:53
Dravion wrote:
2018-10-27 14:41
Ahem...
https : / / d-fault . nl / files
Post by mattg » 2018-11-16 00:40
And if I am second most active, everyone else is doing nothing...
I haven't played with hMailserver code for years
Post by Dravion » 2018-11-16 12:38
Its like Linus Torvalds (inventor of Linux) said a few years ago.Most active OpenSource Projects are
less then 5 People and a lot are inactive or abandoned.Of course, there are a few wxceptions like Apache or Linux.
I think we need to join forces.
Nobody can do all Development work allone.
Right now hMailServer has 250.000 Lines of code, most of it C/C++, the rest C# and SQL-Scripts plus Installer scripting. I think we could attract more OpenSource Developers if hMailServer runs also on Linux because most OpenSource Developers are active on Linux or some flavor of **nix.
