Force TLS1.2 on Windows 7 and Server 2008
Post by mattg » 2018-10-16 02:47
As originally linked here >> http://www.hmailserver.com/forum/viewto ... ry#p182717
This is the single easiest way to ensure that only TLS v1.2 is used by Outlook when connection to your hMailserver (or to Office365 servers)
http://www.rainingforks.com/blog/2015/h ... sv1-2.html
I've not seen this elsewhere and the official whitepaper from Microsoft is just a jumble about informing your business clients that you intend to change to TLS v1.2 (which is not needed in my view).
A really, really easy Registry Edit, if there is such a thing
On the client machine with Outlook on it, check this registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\Schannel\Protocols
Under the Protocols key, add new keys, if not already there: called "SSL 3.0", "TLS 1.0", “TLS 1.1” and “TLS 1.2“
Inside each of these keys, add another key called “Client“.
(See the existing key "SSL 2.0" for an example)
Now create a DWORD value in each Client key called “DisabledByDefault”
For each of "SSL 3.0", "TLS 1.0" and “TLS 1.1” set this to value to 00000001 (or just 1)
For the "TLS 1.2\Client" key leave as the default value of 00000000 (or just 0).
Restart the machine
hMailserver by default accepts connections via TLS v1.2, so no changes should be required in Hmailserver
Re: Force TLS1.2 on Windows 7 and Server 2008
Post by mattg » 2018-10-27 00:10
From an elevated command prompt (if these are NOT currently in place, ie default)
reg add "HKLM\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\SSL 3.0\Client" /v DisabledByDefault /t REG_DWORD /d 1
reg add "HKLM\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0\Client" /v DisabledByDefault /t REG_DWORD /d 1
reg add "HKLM\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\Client" /v DisabledByDefault /t REG_DWORD /d 1
reg add "HKLM\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client" /v DisabledByDefault /t REG_DWORD /d 0
Post by mattg » 2018-10-27 04:48
I've found that
- Machines that were Windows 7 and were upgraded to Windows 10 need this
- simply enabling TLS v1.2 isn't enough. You actively need to disable all of the other protocols
- This matters for email sent from scripts
- this matters for multiple mail clients, including Outlook and Thunderbird
mikedibella
Post by mikedibella » 2018-10-28 17:10
Post by Dravion » 2018-11-17 14:53
mikedibella wrote:
2018-10-28 17:10
This is the tool I use: https://www.nartac.com/Products/IISCrypto
This little Utility works verry well, thanks :)
I just applied it to my Windows 10 x64 1803 (fully updated) and MS-SQL-Server 2017 x64 (Cummulative Update 12) installed which
has "Encryption enforced" in the TCP/IP-Settings for SQL-Server on Port 1433
Nartac settings
Hint: Triple DES 128 should be desabled because its vulnerable to SWEET32 attack
Nmap + TSQL proof TLS 1.2 only is installed and only previous allowed Protocols and Ciphers are in effect
With theese settings in place, any non TLS 1.2 or non allowed Cipher connection attemp to this Windows 10 or SQL-Server version will
be logged into the Windows System log as Error. Only succeeded TLS 1.2 + allowed Cipjers will NOT logged.
