October 2018 64-Bit personal build
Post by Dravion » 2018-10-07 19:57
Non-Official 64-Bit build
*Taken from 5.6.8 official source (Build/Upload date 10/07/2018)
*OpenSSL updated to version 1.0.2p (instead 1.0.2o) see security details https://www.openssl.org/news/vulnerabilities.html
*hMailServer.exe was build with x64 Optimization switches for modern AMD64 CPU's
*Used Visual C/C++ 2013 Update 5 (Visual Studio 2013 Express + WinDDK 7.1
*Uses .NET 4.0 SDK instead 2.0, tested on Windows 10 x64 (required becaue Win10 has no .NET SDK 2.0)
Compiler optimization switches:
Maximize Speed (/O2), Intrinsic Functions (/Ob2), Favor speed (/Ot), Omit Framepointes Yes (/Oy),
Fibersafe Yes (/GT), Whole program optimization Yes (/GL)
#Digital signature of hMailServer-5.6.8-B2431-x64.exe serial is 00b6a2397a5e8abaf6
See: https://github.com/Dravion/hmailserver/ ... /tag/5.6.8
ps: If you want to avoid Smartscreen and Windows Defender preventing the Setup you ca
install the signing Root CA Certificate as trusted signing authority to avoid it.
Downloads
Setup:
https://github.com/Dravion/hmailserver/ ... 31-x64.exe
7Zip Archive no Setup Binaries
https://github.com/Dravion/hmailserver/ ... o_setup.7z
Root CA Cert:
https://github.com/Dravion/hmailserver/ ... ca.cert.7z
