Powershell Script to export all e-mail address transmitted by the server (To and From).
pauloroberto
Post by pauloroberto » 2018-06-15 16:25
Hello people,
Here's my first post, hope this helps someone and forgive my bad english.
A costumer asked me to export every e-mail that pass on the server,
I made a script that filter the log and export the result on a CSV file.
Requirement:
At least Powershell V3
Application log enabled on the Logging options.
Script criado por Paulo Roberto (pauloroberto [arroba] conectadores [ponto] com [ponto] br)
Filtra o log do servidor de e-mail.
#Edit the folder to save the CSV files.
$Planilha="D:\Folder to save\Log-$(get-date -Format yyyyMMdd).csv"
#Edit if not installed on default Folder
$ArquivoLog="C:\Program Files (x86)\HMailServer\Logs\hmailserver_$(get-date -format yyyy-MM-dd).log"
if (!(Test-Path $Planilha))
    "`"From`",`"To`"" | Out-File $Planilha
gc $ArquivoLog | where {$_ -like "`"APPLICATION`"*SMTPDeliverer*Delivering message*"} | ForEach-Object `
    $log=$_
    $de=([regex]::Match($log,"(?<= from )(.*)(?= to )")).value
    $para=([regex]::Match($log,"(?<= to )(.*)(?=\. File)")).value
    "`"$From`",`"$To`"" | Out-File $Planilha -Append
You can make this script run daily via Schedule Task.
You can read the result with any CSV compatible reader, including the following Powershell line: import-csv "File.csv" | out-gridview
Next post I will create a script that read the generated file and shows you the number of e-mail sent by any account on the server,
and, if desired, disable that account after a pre-defined value.
See you.
Re: Powershell Script to export all e-mail address transmitted by the server (To and From).
Post by SorenR » 2018-06-15 17:30
hMailServer can log traffic in AWStat format. Check it out, it could have saved you a lot of work :mrgreen:
pauloroberto
Post by pauloroberto » 2018-06-15 20:30
It wasn't hard...
Anyway, good tip, I will check, thanks.
