We're under attack
MarHMS
We're under attack
Post by MarHMS » 2018-05-22 21:04
I require assistance on how to deal with the below mess.
We have 4 accounts that are constantly being locked out and that's due to hMailServer.
The accounts are authenticated via a domain controller.
Upon inspection of the logs, I've identified quite a few of our accounts that are being "drilled" by over 20 IP addresses.
These IP addresses are blacklisted IP addresses.
We utilize SpamAssassin.
What do you recommend?
Thanks in advance.
Apologies for the theatrics subject
Sample of the log below:
"IMAPD"	2036	64410	"2018-05-22 06:10:17.861"	"92.63.193.20"	"RECEIVED: 2 emailaddress ***"
"IMAPD"	2036	64410	"2018-05-22 06:10:17.861"	"92.63.193.20"	"SENT: 2 NO Invalid user name or password."
"IMAPD"	2004	64409	"2018-05-22 06:10:18.380"	"5.188.9.185"	"RECEIVED: 2 login emailaddress ***"
"IMAPD"	2004	64409	"2018-05-22 06:10:18.380"	"5.188.9.185"	"SENT: 2 NO Invalid user name or password."
"IMAPD"	2000	62097	"2018-05-22 01:51:07.446"	"94.100.178.104"	"RECEIVED: 6 MYRIGHTS "Junk E-mail""
"IMAPD"	2000	62097	"2018-05-22 01:51:07.446"	"94.100.178.104"	"SENT: * MYRIGHTS "Junk E-mail" lrswipkxtea[nl]6 OK Myrights complete"
"SMTPD"	1028	64357	"2018-05-22 06:05:49.332"	"185.234.218.134"	"RECEIVED: ***"
"SMTPD"	1028	64357	"2018-05-22 06:05:49.332"	"185.234.218.134"	"SENT: 535 Authentication failed. Restarting authentication process."
Re: We're under attack
Post by jimimaseye » 2018-05-22 22:56
Ensure passwords are strong and your autoban settings are strong.
If you want them reviewed then run this and post the results: viewtopic.php?f=20&t=30914
Post by mattg » 2018-05-23 01:19
MarHMS wrote:
2018-05-22 21:04
I get heaps of these too
I routinely block all logon attempts from outside Australia.
MarHMS wrote:
2018-05-22 21:04
Using Autoban or IP ranges in hMailserver? At your firewall? Using SPamAssassin? how are they blackilisted? (it seems clear that what you are doing isn't working if they are still connecting to your hmailserver)
MarHMS wrote:
2018-05-22 21:04
Is this using AD integration in hMailserver?
MarHMS
Post by MarHMS » 2018-05-23 13:51
2018-05-22 22:56
I will perform the test tomorrow. It's now a holiday here: Labour Day.
MarHMS
Post by MarHMS » 2018-05-23 13:55
2018-05-23 01:19
MarHMS wrote:
2018-05-22 21:04
MarHMS wrote:
2018-05-22 21:04
MarHMS wrote:
2018-05-22 21:04
Yes, we're utilizing the AD integration in hMailServer..
I've made a list of majority of the IP addresses, particularly the ones that are causing the AD user account lockouts. I tested each on mxtoolbox and they were blacklisted.
For now, the account lockouts have ended (maybe temporarily), because I have blocked traffic from all those addresses in our main firewall.
Post by jimimaseye » 2018-05-23 23:25
Let's see your settings.
MarHMS
Post by MarHMS » 2018-05-24 14:02
2018-05-24   Hmailserver: 5.6.4-B2283
DOMAINS
   "Domain1.com" - emxxxxxxxx.com                 Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - fixxxxxxxxxxxxx.com            Enabled: True
        Greylisting:     False
   "Domain3.com" - fixxxxxxxxxx.com               Enabled: True
        Greylisting:     False
   "Domain4.com" - otxxxxxx.com                   Enabled: True
        Greylisting:     False
   "Domain5.com" - pixxxxxxx.com                  Enabled: True
        Greylisting:     False
RULES
  1, Global Spam Rule             Criteria:  Use AND
     Custom: X-Spam-Level              Contains        *********
                                  -----Actions-----
             Move To Folder                            Spam
  2, whereareyounow.net Spam      Criteria:  Use AND
             From                      Contains        whereareyounow.net
                                  -----Actions-----
             Forward                                   ITDEPARTMENT@Domain3.com
IP RANGES
     POP3:   True !! Protocol DISABLED !!      Antivirus:   True
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
There is a total of 2 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries: 30 Mins:  5   Plain Text:        False  Bind:
                     Host: EXTERNAL.TLD        Empty sender:       True  Batch recipients:    10
Max Msg Size: 25600  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
                                               Max number commands:  50  Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
 !! Service Not Enabled !!
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Subject:  True    Verify DKIM:       False        Use SA score: False -   5
              Subject Text: "[Possible Spam]"
  Spam delete threshold: 8         Maximum message size: 1024
DNSBL ENTRIES:
                  zen.spamhaus.org      Score: 5     Result: 127.0.0.2-8|127.0.0.10-11
     hostkarma.junkemailfilter.com      Score: 2     Result: 127.0.0.2|127.0.0.4
            b.barracudacentral.org      Score: 2     Result: 127.0.0.2|127.0.0.4
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: False,  Notify Receiver: True
  Max Message Size: 26214
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.js              JavaScript files
               *.pif             Program information file
               *.rar             Winrar archives
               *.vbs             VBScript
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 465   / SMTP   -   None
  Paths:-
    Current:  E:\HMAIL\Logs\hmailserver_2018-05-24.log
    Error:    E:\HMAIL\Logs\ERROR_hmailserver_2018-05-24.log - !! ERRORS PRESENT !!
    Event:    E:\HMAIL\Logs\hmailserver_events.log - Not present
    Awstats:  E:\HMAIL\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory E:\Backup is writable.
ERROR: Messages exists which are located outside of the data directory E:\HMAIL\Data.
HMAILSERVER.INI
Data folder:     E:\HMAIL\Data
Log folder:      E:\HMAIL\Logs
Temp folder:     E:\HMAIL\Temp
Event folder:    E:\HMAIL\Events
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v1.92, Hmailserver Forum.
MarHMS
Post by MarHMS » 2018-05-24 14:07
Now that I am seeing this, I realize that auto-ban is disabled.
I believed we had disabled same due to the warning that our webmail could be blocked too. This is likely if staff's AD passwords have expired and they continue the log in attempt. Our approach is to lock user accounts for 1 hour after 5 invalid attempts. We should whitelist the webmail's IP, or is it the IP staff uses to access the webmail?
Post by jimimaseye » 2018-05-24 14:13
So set an individual IP RANGE that covers the webmail server, set it priority 25 or more then re-enable autoban.
BTW this:
Leaves you open to receiving spam.
ie,
from fictional@yourdomain TO you@yourdomain
Subject: do you want bigger tits?
MarHMS
Post by MarHMS » 2018-05-24 15:09
2018-05-24 14:13
BTW this:
ie,
Thanks a lot! Will do.
Should I enable authentication for Local To Local?
Post by jimimaseye » 2018-05-24 15:11
yes
MarHMS
Post by MarHMS » 2018-05-24 18:29
Here are the new settings
DOMAINS
        Greylisting:     False
        Greylisting:     False
        Greylisting:     False
        Greylisting:     False
        Greylisting:     False
RULES
                                  -----Actions-----
             Move To Folder                            Spam
                                  -----Actions-----
IP RANGES
IP: x.x.x.x - x.x.x.x 		Priority: 25     Name: Webmail1
IP: x.x.x.x - x.x.x.x  		Priority: 25     Name: Webmail2
IP: x.x.x.x - x.x.x.x 		Priority: 25     Name: Webmail3
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:     10
There is a total of 3 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
ANTIVIRUS
GENERAL:
     CLAMWIN:   False
     CUSTOMAV:  False
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.vbs             VBScript
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Also, can I untick the POP within the IP ranges?
Post by jimimaseye » 2018-05-24 23:08
Yes, untick pop3 in the ranges (the protocol is disabled).
This is high:
Mine is set at 1. Why have more? Allowed clients will already be configured so Invalid attempts will be deliberate attacks from unauthorised people.
(And, for what its worth, the GLOBAL SPAM rule has 9 asterix: I consider 3 as spam to spam folder on 3. I delete without trace on 7. I think your 9 is too high and you could improve by lowering assuming you are using standard scoring.)
Post by mattg » 2018-05-24 23:31
ALSO that latest diagnostic shows that an error log is present
Please show the contents of the error log
(I have my invalid login attepmts in Autoban set to 3. 10 is a lot)
MarHMS
Post by MarHMS » 2018-05-26 00:19
2018-05-24 23:31
See excerpt below:
"ERROR"	1072	"2018-05-24 00:00:00.011"	"Severity: 3 (Medium), Code: HM5050, Source: File::CreateDirectory, Description: Could not create the directory M:\Data\domain.com\Georgia.Bruff\68. Tried 5 times without success., Error code: 3, Message: The system cannot find the path specified"
"ERROR"	1072	"2018-05-24 00:00:00.011"	"Severity: 3 (Medium), Code: HM5026, Source: PersistentMessage::_WriteDataToMessageFile, Description: Message retrieval failed because message file M:\Data\domain.com\Georgia.Bruff\68\{68302791-CCF1-4C79-84ED-8E8DF87B5C68}.eml did not exist."
"ERROR"	1072	"2018-05-24 00:00:00.011"	"Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 42, Data: 23 UID FETCH 222 (RFC822.SIZE BODY.PEEK[]). Remote IP: 94.100.185.204"
"ERROR"	1072	"2018-05-24 00:00:00.011"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask'"
We do not have a M drive. Don't see where one is being referenced to in settings.
Post by mattg » 2018-05-26 00:26
That was exactly at midnight. Any backup going on...?
Check the .ini to confirm it hasn't changed.
Is there only the one group of messages like that? or does it repeat?
Post by jimimaseye » 2018-05-26 00:28
Its related to this:
Run through this procedure: viewtopic.php?f=21&t=28914
MarHMS
Post by MarHMS » 2018-06-11 23:40
2018-05-26 00:28
I remember I had this issue before. I was advised then to run Data Directory Synchroniser. I had, but obviously it wasn't resolved. I believed it had ran for a few days.
Anyways, I'm experiencing difficulties accessing the database file with DatabaseBrowserPortable. I'm getting the error attached.
However, it works with LINQPad. The SQL query doesn't work with it though.
[There was an error parsing the query. Token in error = right]
Post by jimimaseye » 2018-06-11 23:51
Are you using the correct password? (It is not the admin password but the database password, decrypted, as stored in your ini file).
I know it works because i have used it myself.
Also are you using a windows user that had access permissions to the file (the same as your hmailserver service does).
MarHMS
Post by MarHMS » 2018-06-11 23:58
2018-06-11 23:51
Yes, it is the correct password. I followed the procedure to acquire the password, and same was used to access the database in a different application, LINQPad. However, the new issue was with the SQL command.
I'm now getting the below error when I ran it as an Administrator.
I'm aware that this error is related to us using the default database rather than an external one. Same will be addressed soon.
MarHMS
Post by MarHMS » 2018-06-13 00:13
@jimimaseye any word on the SQL query?
Post by jimimaseye » 2018-06-13 00:16
MarHMS wrote:
2018-06-13 00:13
I'm away at the moment so not with computer to test. I will reply when I'm back.
MarHMS
Post by MarHMS » 2018-06-19 15:22
2018-06-13 00:16
MarHMS wrote:
2018-06-13 00:13
Just a simple reminder
Post by jimimaseye » 2018-06-21 00:27
It seems that DatabasePortable has some restrictions on what it accepts as syntax the some rather limited SQL commands.
You can test for the absolute paths using:
SELECT * FROM hm_messages where messagefilename not like '{%' ;
Im not sure how you can update them though (if it returns some results) because the DatabasePortable doesnt like the LEFT() and RIGHT() operators.
Lets hope that all of your paths are relative (ie, the above statement doesnt return any results).
Post by jimimaseye » 2018-06-21 01:08
Here you go:
The guide has been updated with commands that will also work for you using DatabaseBrowser: viewtopic.php?f=21&t=28914
MarHMS
Post by MarHMS » 2018-06-23 10:54
2018-06-21 01:08
Here you go:
Thanks a lot! Will try on Monday.
MarHMS
Post by MarHMS » 2018-06-25 22:09
2018-06-21 01:08
Here you go:
It works on my test environment... thanks a lot...
Now to migrate this database to SQL Server and perform the updates.
