Help needed [SpamAssassin, still much spam]
PCE|Christian
Post by PCE|Christian » 2018-05-22 12:15
Hey there,
i think i again hit the point where i need some help from you guys ;)
I'm running several hMailserver installations for me and my clients. They are configured very similar why i use my own testserver-config for example here.
I have trouble with a sepcific type of spam, all mails are looking quite similar. 95% are including bitcoin/crypto topics. I can't manage to get rid of them.
Example Screenshot from a spam-mail:
https://img2.picload.org/image/dolrllrl/mails.png
hMailServer diagnostic report:
2018-05-22   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - pcxxxxxxxxxxxx.de              Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
Max Msg Size:120480  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
                      EXTERNAL.TLD  (ok)       Disc. on invalid:   True  Delivered-To hdr: False
                     Port:  25                 Max number commands: 100  Loop limit:           5
                     Con. Sec.: StartTLS Required
  Routes:
    Domain1.com              - S: Local   R: Local  - Addr: All         (ok)
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 2    Use Spamassassin:    True
  Add X-HmailServer-Spam:     True    Check HELO host:   False        Hostname:       127.0.0.1
  Add X-HmailServer-Subject: False    Verify DKIM:       False        Use SA score:        True
  Spam delete threshold: 20         Maximum message size: 99999
DNSBL ENTRIES:
                  zen.spamhaus.org      Score: 5     Result: 127.0.0.*
                    bl.spamcop.net      Score: 5     Result: 127.0.0.*
                  psbl.surriel.com      Score: 1     Result: 127.0.0.*
                virbl.dnsbl.bit.nl      Score: 1     Result: 127.0.0.*
            b.barracudacentral.org      Score: 2     Result: 127.0.0.*
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: False,  Notify Receiver: False
  Max Message Size: 0
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: False
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 155   / POP3   -   SSL/TLS
               0.0.0.0         / 225   / SMTP   -   SSL/TLS
               0.0.0.0         / 243   / IMAP   -   None
               0.0.0.0         / 687   / SMTP   -   None
    !! No SMTP Port 25 defined. Direct external SMTP inbound not possible !!
  Paths:-
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2018-05-22.log - !! ERRORS PRESENT !!
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\Mailserver Backup is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
[size=80]Generated by HMSSettingsDiagnostics v1.92, Hmailserver [url=https://www.hmailserver.com/forum/viewtopic.php?f=20&t=30914]Forum[/url].[/size]
Here are my questions google could not really help me with:
1) How does SpamAssassin learning works? Do i need to store spam anywhere for that? It's pretty unclear for me how that works
2) How can i try to get rid of these spam mails?
3) Is it possible to use any sort of content filter, maybe that i could declare this mail als spam and the filter learns from it (or ist that the point SA will do?)?
Maybe i just read too much within the last days. I've read so many guides how to delete spam with hMailServer and every post/blog/etc. said "You're done now!", i think i'm just too confused for now. To prevent making any mistakes in the hMailSever config i think it's a good idea to ask here :)
Kind regards
Christian
Regards, Christian
hMailserver 5.6-B2145 on Windows Server 2012 R2 Datacenter
Re: Help needed [SpamAssassin, still much spam]
Post by jimimaseye » 2018-05-22 13:08
Hello again. (Long time no see... but I guess thats a good thing for you).
A few observations and questions:
1, Your 'Spam DELETE' threshold is VERY high. Im surprised anything gets removed (even with your extra HMS check scoring). You are using SA scoring - I myself consider anything over SA score 3 as spam and anything over 6 gets deleted immediately (definitely unwanted).
2, What do the Spamassassin headers in an email say? Can you post an example from one of the spam emails please.
3, BAYES - when you train the database with idetifiable spam emails it learns and then increases the probability of future emails being seen as spam (using the BAYES PROBABILITY rules/scoring). You will need to have a 'data base of both spam and Ham emails to begin with though. This will help you get started: viewtopic.php?f=20&t=26866 (read the thread for updates/modifications to the initial scripts)
4, FWIW My recommendations for SA setup and scoring is here: viewtopic.php?p=174991#p174991 Its a slightly different approach (I dont use the SA scoring directly and I use rules to control what gets deleted when) but I find extremely effective.
PCE|Christian
Post by PCE|Christian » 2018-05-22 13:52
Hi jimimaseye!
Yeah it was a good thing, everything works perfectly :) Nice to see you :)
Yeah, you got me. No idea why i set it to 20. It's down to 6 now.
Will do this with the next spam :)
Thank you, i will give it a try :)
FWIW My recommendations for SA setup and scoring is ghere: viewtopic.php?p=174991#p174991 Its a slightly different approach but I find extremely effective.
Thanks, looks like i have some work to do :)
BTW: Your backup-script still works fine :) Still running every night at a customers server proceeding backups with a size of ~45 GB without any problems :)
Regards, Christian
PCE|Christian
Post by PCE|Christian » 2018-05-22 14:23
Mailheader from a spammail:
Return-Path: info@quanpro.network
X-Spam-Checker-Version: SpamAssassin 3.4.1 (2015-04-28) on brutus
X-Spam-Level:
X-Spam-Status: No, score=0.8 required=5.0 tests=DKIM_SIGNED,DKIM_VALID,
	DKIM_VALID_AU,HEADER_FROM_DIFFERENT_DOMAINS,HTML_MESSAGE,JAM_DO_STH_HERE,
	JAM_LONG_LINK,RCVD_IN_DNSWL_NONE,SPF_HELO_PASS,SPF_PASS,URIBL_BLOCKED
	autolearn=no autolearn_force=no version=3.4.1
X-hMailServer-ExternalAccount: XXX
Return-Path: <SRS1=XsPT=ha01s008.org-dns.com==wISe=IJ=quanpro.network=bounce@ha01s021.org-dns.com>
X-Original-To: XXX
Delivered-To: XXX
Received: from sm-r-015.org-dns.com (sm-r-015.org-dns.com [92.79.61.110])
	by ha01s021.org-dns.com (Postfix) with ESMTPS id 9D57C1E8CBAD
	for <XXX>; Tue, 22 May 2018 11:28:39 +0200 (CEST)
Authentication-Results: ha01s021;
	spf=pass (sender IP is 92.79.61.110) smtp.mailfrom=srs0=wise=ij=quanpro.network=bounce@ha01s008.org-dns.com smtp.helo=sm-r-015.org-dns.com
Received-SPF: pass (ha01s021: domain of ha01s008.org-dns.com designates 92.79.61.110 as permitted sender) client-ip=92.79.61.110; envelope-from=srs0=wise=ij=quanpro.network=bounce@ha01s008.org-dns.com; helo=sm-r-015.org-dns.com;
Received: from smh01.org-dns.com (localhost [127.0.0.1])
	by smh01.org-dns.com (Postfix) with ESMTP id 383BC844EF
Received: by smh01.org-dns.com (Postfix, from userid 1001)
	id 29150844E5; Tue, 22 May 2018 11:28:39 +0200 (CEST)
Received: from ha01s008.org-dns.com (ha01s008.org-dns.com [62.108.32.128])
	by smh01.org-dns.com (Postfix) with ESMTPS id 2B7BE844EF
	for <XXX>; Tue, 22 May 2018 11:28:38 +0200 (CEST)
Received: by ha01s008.org-dns.com (Postfix, from userid 30)
	id 3057B1920AC0; Tue, 22 May 2018 11:28:38 +0200 (CEST)
X-Original-To: XXX
Delivered-To: XXX
Received: from finds5.ccccc.me (finds5.ccccc.me [179.61.162.164])
 by ha01s008.org-dns.com (Postfix) with ESMTP id C12CB1920AC0
 for <XXX>; Tue, 22 May 2018 11:28:33 +0200 (CEST)
Received-SPF: pass (ha01s008.org-dns.com: domain of quanpro.network designates
 179.61.162.164 as permitted sender) client-ip=179.61.162.164;
 envelope-from=bounce@quanpro.network; helo=finds5.ccccc.me;
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; s=mail; d=quanpro.network;
 h=To:Subject:Message-ID:Date:From:Reply-To:MIME-Version:List-Unsubscribe:
 Content-Type:Content-Transfer-Encoding; i=info@quanpro.network;
 bh=2NhdZ2nrsoZ8p1sOjVslwl/IE3PURXZtYx/wy8V8Rvk=;
 b=IGPxDJe1thbFsvBrYSfDL5lO+IMxQwO4vS+uvNpGP9hAyGBaysBEwaxYnR/BbIpneI1IeffQyrDA
 smVRdAhuDHgiF3HOALT7WQO3qA9Tm5t5xFZF9fYovPraUlm0kBIu2k2D4Zb1I5hONK4hBRbMUPBu
 gkLqHoN+CEn9R3bYEBY=
Received: from quanpro.network (172.16.238.4) by finds5.ccccc.me for
 <XXX>;
 Tue, 22 May 2018 09:28:33 +0000 (envelope-from <bounce@quanpro.network>)
To: XXX
Subject: Cryptocurrencies Continue to Surge
Message-ID: <b048939993af7fbb864340fd08988c72@official-iphone-giveaway.com>
Date: Tue, 22 May 2018 09:27:04 +0000
Reply-To: support@quanpro.network
MIME-Version: 1.0
X-Mailer-LID: 1,6
List-Unsubscribe: <http://official-iphone-giveaway.com/rb/7wx2U235003.d85M40d8f80168dacbf5313d805d6afcf99b/vYCW6/a9oB39.html>
X-Mailer-RecptId: 235003
X-Mailer-SID: 39
X-Mailer-Sent-By: 1
Content-Type: multipart/alternative; charset="UTF-8";
 boundary="b1_1d1cba9298d5b988f05da1b83ebfc7ec"
Content-Transfer-Encoding: 8bit
X-PPP-Message-ID: <20180522092837.9357.44914@ha01s008.org-dns.com>
X-PPP-Vhost: XXX
X-POWERED-BY: WIRCON - AV:CLEAN SPAM:OK
Regards, Christian
Post by jimimaseye » 2018-05-22 14:38
From the tests performed it looks like that this email would already have been caught in the SURBL checks within HMS - it has already been caught in SA under 'URIBL' test. However, the rest of the SA tests have resulted in a low score (0.8) so I suspect the source of this was quite new. Are you running the full complete set of SA rules? If so, you might want to add/increase the score for URIBL_BLOCKED test to something like +3 more than it is already. This will surely have pushed the score over 6 and the email would have been deleted now that you have lowered your delete threshold score. (Having it at 20 will undoubtedly be the reason you saw so many spams so now lowering it will help a lot).
If you plan to do BAYES training using sa-learn then you might want to reconsider what you do with spam emails - instead of deleting them you might want to stash them in a special folder to use against the training script.
PCE|Christian wrote:
2018-05-22 13:52
BTW: Your backup-script still works fine Still running every night at a customers server proceeding backups with a size of ~45 GB without any problems
Good to hear. Thanks. Did you note the recent minor corrections that I made to the script? Check the thread for information. viewtopic.php?f=21&t=28139
2018-05-22 13:52
Its not so bad really - it looks more complicated than it really is. (Im quite verbose in what I write in guides).
PCE|Christian
Post by PCE|Christian » 2018-05-22 15:50
Struggeling a bit here. First i try to explain my infrastructure:
1) Mailserver from my webspace, if a mail arrives there,
2) my hMailServer gets it with POP, then
3) my MailStore Proxy for archiving takes the mail and stores it to my MailStore Archive.
4) My Outlook connects to the proxy (POP), the proxy now grabs all mails from the hMailServer and sends them to Outlook - all with POP because IMAP is not supported/needed in this setup.
So, this is the scenario how i receive mails due to get everything correct for GDPR and local guidelines (i have to archive all mails before any client could touch and modify them).
My thoughts now:
I created a honeypot mailadress. With a rule i will send alle mails declared as spam to that adress. Further i can be sure that all mails which will arrive at this never published adress are 100% spam and unwanted. The point i can't figure out is how to let SpamAssassin learn from this. You linked a topic to me, but it is a solution for IMAP only. The second thing i just thought about: All the spam from my clients could be send to there, so that i could create a big own database which all SpamAssassin installations are using. Is that possible?
Regards, Christian
Post by jimimaseye » 2018-05-22 16:04
Im running out the door right now but a quick look at that script should still be ok. Yes it uses IMAP to move the emails to an IMAP folder but (along with special headers) this is just for the purpose of the 'sorting' script later. also by moving it there it (hopefully) will move it out from being downloaded by the POP from outlook. If this is not required, the script could be changed to COPY the emails across leaving the source in place.
In any case, the pther scripts then read the contents of that folder and sort them in to SPAM and HAM folders physically on disk (from where they will be read an 'learned' from).
IOW this use of IMAP is of no concern to your POP3 clients as it is merely a vehicle for the other scripts that go to use it.
PCE|Christian
Post by PCE|Christian » 2018-05-23 10:02
Good morning everyone :)
Where can i modify the score for URIBL? Tried it with "score URIBL_BLOCKED 3" in local.cf from spamassassin. I think that is wrong because it is not working.
Regards, Christian
Post by mattg » 2018-05-23 13:35
I do this to make the URIBL all score 0 in SpamAssassin ( I check them in hMailserver)
# don't score URIBL
score URIBL_BLACK 0
score URIBL_RED 0
score URIBL_GREY 0
score URIBL_BLOCKED 0
There is also URIBL_SBL and URIBL_SBL_A rule on my system, but I'm not sure where (I can search for them if you need)
http://uribl.com/usage.shtml
Post by jimimaseye » 2018-05-23 23:09
2018-05-23 10:02
Did you restart the spamassassin service after you made the change?
PCE|Christian
Post by PCE|Christian » 2018-05-25 10:45
Hi!
The restart did it :) But the URIBL-Test is quite strange for me. Every mail gets points from URIBL with the flag "URIBL_BLOCKED". Need to investigate why.
Regards, Christian
Post by jimimaseye » 2018-05-25 11:02
Full explanation http://uribl.com/refused.shtml
and solution. Here you go: viewtopic.php?f=22&t=32648.
(In essence, use your own DNS Server or conditional forwarders to access the site directly instead of using your ISP DNS settings.)
