suddenly when you log in to the browser, there was an error
Tatti999
Post by Tatti999 » 2018-05-05 21:20
suddenly when I log in to the browser to mail client (mail.dovirent.com), there was an error "Can't connect to IMAP4 server, check IMAP4 server settings."
Please help.
When i did diagnostic on viewtopic.php?f=20&t=30914 , i get error "microsoft vbscript runtime error component can't create object 'getobject'"
Re: suddenly when you log in to the browser, there was an error
Post by jimimaseye » 2018-05-05 22:12
Tatti999 wrote:
2018-05-05 21:20
Check you have the correct port set, the port opened in firewall and that IMAP is enabled and with the port you are stating
Tatti999 wrote:
2018-05-05 21:20
Strange. The section of code that does this is a Windows Management Instrumentation ("WMI") based object (designed to obtain your network card assigned ip address(es). More info here: https://msdn.microsoft.com/en-us/librar ... s.85).aspx) It shouldnt be failing.
What version of windows are you using? You sure your machine isnt failing in some way? Is the network card still functioning?
