sa-update SHA1 calculation bug
rstarkov
Post by rstarkov » 2017-09-21 00:30
I've decided to update my ancient SpamAssassin installation and ran into a problem: the latest version has a buggy sa-update that calculates the SHA1 hash incorrectly!
Here's an extract from a debug (-D) run of sa-update:
downloading to: C:\SpamAssassin\Bin\share\3.004001\updates_spamassassin_org\1799552.tar.gz, update
http: (curl.exe) GET http://sa-update.ena.com/1799552.tar.gz, success
downloading to: C:\SpamAssassin\Bin\share\3.004001\updates_spamassassin_org\1799552.tar.gz.sha1, update
http: (curl.exe) GET http://sa-update.ena.com/1799552.tar.gz.sha1, success
dbg: sha1: verification wanted: 10801ca581564e652a009e80f6195c4bb8532a94
dbg: sha1: verification result: 74ea7198eb78c4a33c420a7cb7c399bce2f372d2
channel: SHA1 verification failed, channel failed
Here's a non-buggy SHA1 calculation on the downloaded file:
%%%% HASHDEEP-1.0
%%%% size,sha1,filename
## hashdeep64.EXE -c sha1 C:\SpamAssassin\Bin\share\3.004001\updates_spamassassin_org\1799552.tar.gz
274927,10801ca581564e652a009e80f6195c4bb8532a94,C:\SpamAssassin\Bin\share\3.004001\updates_spamassassin_org\1799552.tar.gz
Fail... This is v3.41 downloaded from https://www.jam-software.de/customers/d ... anguage=EN and I tried both 32 and 64 builds, both had this problem.
Any tips on how to get this version of SpamAssassin to update?
Re: sa-update SHA1 calculation bug
Post by mattg » 2017-09-21 00:32
What does Jam Software say about this updating issue with their product?
rstarkov
Post by rstarkov » 2017-09-21 00:54
I've only emailed them just now. This forum is the best place I know for community support related to SpamAssassin for windows so... I was hoping someone running hMailServer may have experienced this and knows how to deal with it.
Post by mattg » 2017-09-21 01:01
That's OK and I agree, I was just making sure that you have contacted them.
Personally I run SpamAssassin on a virtual Ubuntu server install, so it is a little different for me. Updates etc all just happen without my intervention.
rstarkov
Post by rstarkov » 2017-09-24 17:39
The response from Jam Software was almost immediate and very helpful! Apparently this happens if there is a "curl.exe" on the path. Removing it fixed the problem for me.
Jam Software say that it's a bug in the SpamAssassin's Perl code.
Post by mattg » 2017-09-25 00:44
Thanks for the post back with the solution.
(and Yes, Jam software are normally very responsive)
attwoodw
Post by attwoodw » 2018-07-03 21:23
I know I'm a little late to this party but have just run into this problem today, could anyone please tell me in which file the problematic path resides?
Post by mattg » 2018-07-03 23:51
2017-09-21 00:32
attwoodw
Post by attwoodw » 2018-07-13 20:43
>>>>>>>>>>>>>>Paste of email<<<<<<<<<<<<<<<<<
Dear Mr. Attwood,
The problem is caused by the program curl.exe resisting in several locations on your system.
In case “Curl.exe” exists in some directory that is also listed in your systems PATH environment variable, sa-update will use this version, instead of using the version that was shipped with SpamAssassin.
Please save the attached file as „sa-update“ and copy it to the directory and replace the original file:
C:\Program Files (x86)\Common Files\JAM Software\SpamAssassin\runtime\
This should fix the issue.
Best regards
>>>>>>>>>>>>>>end of Paste<<<<<<<<<<<<<<<<<
The email has answered my question and I have resolved the more than one curl.exe in the PATH environment variable, however there was no attached file to the email. I suspect the replacement "sa-update" has an additional absolute PATH variable to the SpamAssassin curl.exe
I found the additional curl.exe in my C:\Windows\System32\ folder "Windows 10 [Version 10.0.17134.165]"
I will update this when I receive the script from JAM
attwoodw
Post by attwoodw » 2018-07-17 13:01
Rerplacement sa-update file link
https://fileshare.jam-software.de/share ... cedownload
I have also attached it as a compressed file should the link expire
Save the file as „sa-update“ and copy it to the directory and replace the original file:
The attached compressed file contains the JAM replacement sa-update
sa-update.7z
(19.23 KiB) Downloaded 152 times
I hope someone finds this useful
Best Wishes
Wayne
KooiInc
Post by KooiInc » 2018-07-20 09:38
Hi Wayne, thanks for your efforts and the file. It made my day!
Regards /Renzo Kooi
PVi1
Post by PVi1 » 2019-02-01 18:41
Hi all,
in my case, archive file with rules was only partially downloaded - eg its size was about 55KB instead of cca 290KB.
So I started sa-update with -D args and watched the output. I have tried to download that archive from my PC and it worked fine, so it was clear that it is not a server issue. So I have started to remove unessessary arguments from curl command responsible for downloading that archive.
That way I have found that problem was caused by curl -z argument! :oops:
So I have edited sa-update file, on line 1472 and commented statement responsible or adding -z argument:
    #push(@args, '-z', $out_fname_short)  if $out_fname_exists && !$force_reload;
Saved and restarted sa-update via:
. /opt/zimbra/.bashrc; /opt/zimbra/libexec/zmsaupdate
All is working fine now and amavisd started successfully!
Enjoy zimbra with antispam protection enabled.... :P
It tooks me 3 hours to figure it :evil:
Regards,
Peter
