The user does not see in outlook the email caught in spam
00_00
Post by 00_00 » 2017-06-09 15:37
Please help!
The user does not see in outlook the email caught in spam, and they are visible in roundcube web interface. If you move into the web interface rouncube from spam to the Inbox, then the user in outlook receives the email. How to fix so that emails caught in spam, and visible in Web interface roundcube was visible also in Junk in outlook?
Systems: Hmailserver + Spamassassin (JAM Software) + MS SQL + IIS + PHP.
tunis
Re: The user does not see in outlook the email caught in spam
Post by tunis » 2017-06-09 16:05
The user use POP3 and that only fetch mail from INBOX folder.
Also you must have a rule that moves spam to spam folder.
If you delete this or add a new user rule that move it back to the INBOX folder.
HMS 5.6.8 B2538.30 on Windows Server 2016 Core VM.
00_00
Post by 00_00 » 2017-06-09 16:16
tunis wrote:The user use POP3 and that only fetch mail from INBOX folder.
In Hmailserver I have a rule to move spam to IMAP folder Junk. And that rule is fulfilled. However, Outlook is configured for POP3 mail in IMAP Junk folder was transferred are not displayed. How to fix?
00_00
Post by 00_00 » 2017-06-09 16:20
How to create a rule in addition to move to IMAP folder Junk, a copy of the letter moved in the POP3 Junk folder?
Post by SorenR » 2017-06-09 16:22
Configure outlook to use IMAP!
tunis
Post by tunis » 2017-06-09 16:32
Best is like SorenR says, configure outlook to IMAP.
00_00 wrote:Outlook is configured for POP3 mail in IMAP Junk folder was transferred are not displayed.
POP3 can NOT fetch folders, only mail from the INBOX!
00_00
Post by 00_00 » 2017-06-09 16:37
tunis wrote:Best is like SorenR says, configure outlook to IMAP.
I do not have to reconfigure outlook to IMAP otherwise you will break the whole folder structure and it will be very bad.
I have copies of spam emails moved to IMAP folder, move to Inbox POP3. How to do it?
tunis
Post by tunis » 2017-06-09 17:01
If it is a single user just add a rule on that account in hmailserver.
If x-hMailServer-Spam = YES move to INBOX
Then add a rule in Outlook to move it to Junk.
Post by mattg » 2017-06-09 22:47
00_00 wrote:In Hmailserver I have a rule to move spam to IMAP folder Junk. And that rule is fulfilled. However, Outlook is configured for POP3 mail in IMAP Junk folder was transferred are not displayed. How to fix?
00_00 wrote:I do not have to reconfigure outlook to IMAP otherwise you will break the whole folder structure and it will be very bad.
if you don't want the mail in the junk folder, then don't move it there in the first place :shock: :shock:
