Log shows spam score but no results
mtalent
Post by mtalent » 2017-03-28 23:28
Ok, new to hmailserver just moved one of our domains over for testing purposes.
Right away I was informed that people were getting unusual emails that they didn't get before.
So I implemented some of the spam options in the server. check spf, check host in the helo command and check dns mx record (also checked the boxes to have information added to the header). We cannot lose emails so I just opted for hmailserver to add the default [spam] to the subject and asked the people to report to me with the results.
So today we have an email that shouldn't be there. Nothing was added to the header and nothing added to the subject line. I searched the logs for the ip and found the transaction ----Below------- (changed mail server name, mail account name and local ip) if I left something that could cause me problems admins feel free to edit it out or let me know.
"DEBUG" 3740 "2017-03-27 23:20:17.255" "Creating session 110"
"TCPIP" 3740 "2017-03-27 23:20:17.271" "TCP - 138.99.204.14 connected to 172.xxx.xxx.xxx:xx."
"DEBUG" 3740 "2017-03-27 23:20:17.271" "TCP connection started for session 109"
"SMTPD" 3740 109 "2017-03-27 23:20:17.271" "138.99.204.14" "SENT: 220 mail.nunya.com ESMTP"
"SMTPD" 3692 109 "2017-03-27 23:20:17.505" "138.99.204.14" "RECEIVED: ehlo gregmar.pl"
"SMTPD" 3692 109 "2017-03-27 23:20:17.505" "138.99.204.14" "SENT: 250-mail.nunya.com[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 3740 109 "2017-03-27 23:20:17.724" "138.99.204.14" "RECEIVED: mail from:<info@IMPERIL.com>"
"DEBUG" 3740 "2017-03-27 23:20:17.990" "Spam test: SpamTestHeloHost, Score: 2"
"DEBUG" 3740 "2017-03-27 23:20:18.412" "Spam test: SpamTestMXRecords, Score: 2"
"DEBUG" 3740 "2017-03-27 23:20:18.521" "Spam test: SpamTestSPF, Score: 0"
"DEBUG" 3740 "2017-03-27 23:20:18.521" "Total spam score: 4"
"SMTPD" 3740 109 "2017-03-27 23:20:18.537" "138.99.204.14" "SENT: 250 OK"
"SMTPD" 3716 109 "2017-03-27 23:20:18.755" "138.99.204.14" "RECEIVED: rcpt to:<account@domain.com>"
"SMTPD" 3716 109 "2017-03-27 23:20:18.771" "138.99.204.14" "SENT: 250 OK"
"SMTPD" 3704 109 "2017-03-27 23:20:19.427" "138.99.204.14" "RECEIVED: data"
"SMTPD" 3704 109 "2017-03-27 23:20:19.537" "138.99.204.14" "SENT: 354 OK, send."
"DEBUG" 3740 "2017-03-27 23:20:20.255" "Could not retrieve PTR record for IP (false)! 138.99.204.14"
"DEBUG" 3740 "2017-03-27 23:20:20.271" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 3548 "2017-03-27 23:20:20.271" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 3548 "2017-03-27 23:20:20.271" "Total spam score: 0"
"DEBUG" 3548 "2017-03-27 23:20:20.271" "Saving message: {CEF10E2E-A385-4E90-A7EF-2DB21AD855FB}.eml"
"DEBUG" 3548 "2017-03-27 23:20:20.287" "Requesting SMTPDeliveryManager to start message delivery"
"DEBUG" 3560 "2017-03-27 23:20:20.287" "Adding task DeliveryTask to work queue SMTP delivery queue"
"SMTPD" 3548 109 "2017-03-27 23:20:20.287" "138.99.204.14" "SENT: 250 Queued (0.734 seconds)"
"DEBUG" 3608 "2017-03-27 23:20:20.287" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 3608 "2017-03-27 23:20:20.302" "Delivering message..."
"APPLICATION" 3608 "2017-03-27 23:20:20.302" "SMTPDeliverer - Message 13770: Delivering message from info@IMPERIL.com to account@domain.com. File: C:\Program Files (x86)\hMailServer\Data\{CEF10E2E-A385-4E90-A7EF-2DB21AD855FB}.eml"
"DEBUG" 3608 "2017-03-27 23:20:20.302" "Applying rules"
"DEBUG" 3608 "2017-03-27 23:20:20.302" "Performing local delivery"
"DEBUG" 3608 "2017-03-27 23:20:20.318" "Applying rules"
"DEBUG" 3608 "2017-03-27 23:20:20.318" "Saving message: {CEF10E2E-A385-4E90-A7EF-2DB21AD855FB}.eml"
"DEBUG" 3608 "2017-03-27 23:20:20.318" "AWStats::LogDeliverySuccess"
"DEBUG" 3608 "2017-03-27 23:20:20.333" "Local delivery completed"
"APPLICATION" 3608 "2017-03-27 23:20:20.333" "SMTPDeliverer - Message 13770: Message delivery thread completed."
"SMTPD" 3692 109 "2017-03-27 23:20:20.521" "138.99.204.14" "RECEIVED: quit"
"SMTPD" 3692 109 "2017-03-27 23:20:20.521" "138.99.204.14" "SENT: 221 goodbye"
"DEBUG" 3716 "2017-03-27 23:20:20.521" "Ending session 109"
I am going to add my mail config from your script in case you need it.
[code]3/28/2017 2:24:54 PM Hmailserver: 5.6.6-B2383
IP: 172.xxx.xxx.xxx - 172.xxx.xxx.xxx Priority: 15 Name: local
Allow connections Other
SMTP: True Antispam : True
POP3: True Antivirus: True !! ANTIVIRUS NOT CONFIGURED !!
IMAP: True SSL/TLS: True
External To External - False
IMAP: True SSL/TLS: False
AUTOBANNED Local Addresses:
No entries
AUTOBAN
Autoban Enabled: True Max invalid logon attempts: 3
Minutes Before Reset: 30 (0.50 hours, 0.02 days)
Minutes to Autoban: 60 (1.00 hours, 0.04 days)
INCOMING RELAYS
No entries
ANTISPAM
Spam Mark: 5 Use SPF: True - 3 Use Spamassassin: False
Add X-HmailServer-Spam: True Check HELO host: True - 2
Add X-HmailServer-Reason: True Check MX records: True - 2
Add X-HmailServer-Subject: True Verify DKIM: False - 5
Subject Text: "[SPAM]"
GREYLISTING:
Greylisting: False
DNSBL ENTRIES:
No entries
SURBL ENTRIES:
No entries
WHITELISTING
No entries
Block Attachments: False
SSL/TLS
SSL 3.0 : False
TLS 1.0 : True
TLS 1.1 : True
SslCipherList :
RC4-SHA - HIGH - !aNULL
!eNULL - !EXPORT - !DES
!3DES - !MD5 - !PSK;
TCPIP PORTS Connection Sec
0.0.0.0 / 25 / SMTP - None
0.0.0.0 / 110 / POP3 - None
0.0.0.0 / 143 / IMAP - None
0.0.0.0 / 587 / SMTP - None
LOGGING Logging Enabled: True
Paths:- Current: C:\Program Files (x86)\hMailServer\Logs\hmailserver_2017-03-28.log
Error: C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2017-03-28.log
Event: C:\Program Files (x86)\hMailServer\Logs\hmailserver_events.log
APPLICATION - True
SMTP - True
POP3 - True
IMAP - True
TCPIP - True
DEBUG - True
AWSTATS - True
SYSTEM TESTS
Database type: MSSQL Compact
[/code]
Generated by HMSSettingsDiagnostics v1.48, Hmailserver Forum.
Re: Log shows spam score but no results
Post by jimimaseye » 2017-03-28 23:38
You can see from your logs:
Your spam settings are:
Spam Mark: 5
Hence no spam marking (and certainly no deleting. 20 is REALLY too high).
Its not necessary but you could really improve your antispam capabilities by using the integrated spamassassin functionality and setup (eg: viewtopic.php?f=21&t=28133). Alternatively its just a case of tinkering with your scores to suit.
