mailer-daemon
james2607
mailer-daemon
Post by james2607 » 2016-07-26 14:00
We are currently evaluating Hmailserver and everything is currently running as expected. But we have one question: The non-delivery notifications are sent with from address "mailer-daemon@<Local host name>". For internal usage we would like to have "postmaster@<default domain>". Is there any way to change the from address - maybe via a rule or script?
Re: mailer-daemon
Post by mattg » 2016-07-26 14:34
You can catch these with a global rule, and the run a custom function to change the from.
I use FROM contains 'mailer-daemon' to catch them on my system (I send a copy to a specific address)
Re: mailer-daemon
Post by percepts » 2016-07-26 14:58
+1
except for a very simple action such as only changing the From address you can do it all in the rule without the need for a script function.
You just use the "Set header Value" action and specify "From" and in value put the full email address of what you want it to be.
So you have
criteria:
From / contains / mailer-daemon
X-hMailServer-LoopCount / equals / 1
action:
Set header Value / From / postmaster@domain.com
Re: mailer-daemon
Post by mattg » 2016-07-26 15:38
Percepts, that is a great idea.
I've never seen that before
james2607
Re: mailer-daemon
Post by james2607 » 2016-07-26 16:15
Hi percepts,
Works perfect. Thank you very much for your quick help.
Re: mailer-daemon
Post by percepts » 2016-07-26 16:33
mattg wrote:Percepts, that is a great idea.
Well yes but it is very dependant on exactly what you want to do and if the rule actions can do it without a script function. And possible conflicts between rules. I also have several rule actions which run functions but always try to avoid using script if I can.
