DKIM on rule 'reply' not applied
Post by jimimaseye » 2016-05-14 13:46
I would like someone to confirm if they get the same results before I log as a bug.
Scenario:
DKIM signing setup and enabled
- Sending an email (normally) signs the email correctly (with the usual "dkim-signature:" header).
Set up an Account Rule with a "REPLY (email)" as an action (all fields filled correctly).
BUT the received reply (sent by the rule) does not get DKIM signed.
Received Headers to show:
NORMAL EMAIL sent from an email client (correct):
X-Apparently-To: geoff@yahoo.net; Sat, 14 May 2016 10:08:15 +0000
Return-Path: <sylvester@mydomain.net>
Received-SPF: pass (domain of mydomain.net designates 123.45.67.89 as permitted sender)
X-Originating-IP: [123.45.67.89]
Authentication-Results: mta1149.mail.gq1.yahoo.net from=mydomain.net; domainkeys=neutral (no sig); from=mydomain.net; dkim=pass (ok)
Received: from 127.0.0.1 (EHLO mydomain.net) (123.45.67.89)
by mta1149.mail.gq1.yahoo.net with SMTPS; Sat, 14 May 2016 10:08:13 +0000
dkim-signature: v=1; a=rsa-sha256; d=mydomain.net; s=dkim;
c=relaxed/relaxed; q=dns/txt; h=From:Subject:Date:Message-ID:To:MIME-Version:Content-Type:Content-Transfer-Encoding;
bh=47DEQpj8HBSa+/TImW+5JCeuQeRkm5NMpJWZG3hSuFU=;
b=Qb/xRWLQtOJ5J4V2yw2KYjmitN8/QnQcP9p52t84YrQ9DxafzfGMekSlGt6Nr+Ug+//eEvEHlcUB2Dj2PL//WDdCqAUiM4et0y1zCYRbgevOgPzF0N92YEXq2fDHzkT/jd2L1VpEOPdUmowaTLMUTh8hFnxop0zV5qamWIulG4o=
Received: from [40.40.40.18] (ppp-15-90.20-151.wind.it [151.20.90.15])
by mydomain.net with ESMTPA
; Sat, 14 May 2016 11:08:07 +0100
Message-ID: <5736F905.9000506@mydomain.net>
Date: Sat, 14 May 2016 12:08:05 +0200
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:31.0) Gecko/20100101 Thunderbird/31.6.0
MIME-Version: 1.0
To: Geoff <geoff@yahoo.net>
Subject: test 2
Content-Type: text/plain; charset=utf-8; format=flowed
Content-Length: 3
RULE REPLY email (failing):
X-Apparently-To: geoff@yahoo.net; Sat, 14 May 2016 11:32:15 +0000
Return-Path: <>
Authentication-Results: mta1231.mail.ne1.yahoo.net from=; domainkeys=neutral (no sig); from=mydomain.net; dkim=neutral (no sig)
by mta1231.mail.ne1.yahoo.net with SMTPS; Sat, 14 May 2016 11:32:14 +0000
MISSING DKIM SIGNATURE HERE
Content-Type: text/plain; charset="utf-8"
MIME-Version: 1.0
Return-Path: <>
Message-ID: <82D2B797-6AE7-4AB4-A592-20CCD3D7D8C5@mydomain.net>
To: geoff@yahoo.net
From: Do Not Reply <bouncednotifications@mydomain.net>
Subject: Out Of Office - please note...
Date: Sat, 14 May 2016 12:31:59 +0100
Auto-Submitted: auto-replied
X-hMailServer-LoopCount: 1
Content-Length: 357
Anyone got comments or confirm please?
Re: DKIM on rule 'reply' not applied
Post by jimimaseye » 2016-05-14 15:16
