IMAP folder with dot in folder name
Stevanovitch
Post by Stevanovitch » 2015-12-20 18:54
I use hmail 5.6.4-B2283
I meet a problem with folder's name, we often use "." in them , and seem to be "bad" !
i found this topic wich talking about that : viewtopic.php?t=9303
is there any kind of way to get it work.
thank
best regards.
Sorry for my "english school" .
Re: IMAP folder with dot in folder name
Post by jimimaseye » 2015-12-20 21:57
SETTINGS - PROTOCOL - IMAP - Advanced tells you what the hierarchy delimiter is. If you have a character of the same in your folder names then you will have a problem (and DOT is default). The only way around is to not use DOT in the folder name OR change the hierarchy delimiter.
