Installing on Windows 8.1 : Ordinal 312 not found
fkuchta
Post by fkuchta » 2015-10-21 17:59
I wanted to install administrative tools (hMailServer-5.6.4-B2283) on a workstation with Win 8.1 Pro but I have a problem at the end :
In french : "L'ordinal 312 est introuvable dans la bibliothèque de liens dynamiques C:\Program Files(x86)\hMailServer\Bin\hMailServer.exe"
In english (approximate translation) : "Ordinal 312 is not found in DLL C:\Program Files(x86)\hMailServer\Bin\hMailServer.exe"
The problem appears at the end, when the wizard is installing .Net Framework 2.0 (or may be the wizard has not been refreshed and Net 2.0 Framework is not the problem).
Then, I cannot login to my server :
In french : "La valeur ne pas être null. Nom du paramètre : type"
In english (approximate translation) : "The value cannot be null. Name of the parameter : type"
Info I know :
* On another computer with Win 7, no problem to install, nor to access the server
* User is admin
* I installed Framework 4.5.2 manually (and rebooted of course)
I dont know where I must look for the problem.
See attachments for more informations.
Thank you for your help ;-)
Fabrice, Toulouse
Trying to access the server problem
End of the installation problem
Re: Installing on Windows 8.1 : Ordinal 312 not found
Post by katip » 2015-10-22 07:55
pls see this : https://github.com/hmailserver/hmailserver/issues/122
try to copy those dlls manually to bin folder. HTH
Post by jimimaseye » 2015-10-22 08:27
Also take a read of this and you may find the answer in there too. https://github.com/hmailserver/hmailserver/issues/75
fkuchta
Post by fkuchta » 2015-10-22 08:52
Thank you Katip, it solves my problem : installing the complete setup, instead of only administrative tools.
Thank you too for jimimaseye for the help.
Fabrice, Toulouse
Post by jimimaseye » 2015-10-22 09:13
Good.
:D For what its worth, the link I posted wasnt the one I was looking for. I meant this one with a more complete explanation: viewtopic.php?f=10&t=27890 Not sure it would have helped you though (it seems it is for people compiling rather than installing)
fkuchta
Post by fkuchta » 2015-10-22 09:21
Yes, jimimaseye, it is not for my problem ;-)
But can be usefull for others.
Thx
